[PATCH 12/34] bsp/leon3: Use new IRQ(A)MP register block API
Sebastian Huber
Wed May 31 16:30:47 UTC 2023
bsps/sparc/leon3/clock/ckinit.c | 11 +--
bsps/sparc/leon3/include/bsp/irq.h | 1 +
bsps/sparc/leon3/include/bsp/leon3.h | 35 +++++++-
bsps/sparc/leon3/include/leon.h | 53 +++++-------
bsps/sparc/leon3/start/amba.c | 11 +--
bsps/sparc/leon3/start/bspclean.c | 9 +-
bsps/sparc/leon3/start/bspsmp.c | 16 +++-
bsps/sparc/leon3/start/cpucounter.c | 11 +--
bsps/sparc/leon3/start/eirq.c | 124 +++++++++++++++++++--------
9 files changed, 179 insertions(+), 92 deletions(-)
diff --git a/bsps/sparc/leon3/clock/ckinit.c b/bsps/sparc/leon3/clock/ckinit.c
index 2ec701fe2a..b3761bed35 100644
--- a/bsps/sparc/leon3/clock/ckinit.c
+++ b/bsps/sparc/leon3/clock/ckinit.c
@@ -45,6 +45,7 @@
#include <leon.h>
#include <rtems/rtems/intr.h>
#include <grlib/ambapp.h>
+#include <grlib/irqamp.h>
#include <rtems/score/profiling.h>
#include <rtems/score/sparcimpl.h>
#include <rtems/timecounter.h>
@@ -179,11 +180,11 @@ static void bsp_clock_handler_install(rtems_interrupt_handler isr)
static void leon3_clock_initialize(void)
- volatile struct irqmp_timestamp_regs *irqmp_ts;
+ irqamp_timestamp *irqmp_ts;
volatile struct gptimer_regs *gpt;
struct timecounter *tc;
- irqmp_ts = &LEON3_IrqCtrl_Regs->timestamp[0];
+ irqmp_ts = irqamp_get_timestamp_registers(LEON3_IrqCtrl_Regs);
gpt = LEON3_Timer_Regs;
tc = &leon3_tc;
@@ -201,13 +202,13 @@ static void leon3_clock_initialize(void)
tc->tc_frequency = leon3_up_counter_frequency();
#ifdef RTEMS_PROFILING
- if (!irqmp_has_timestamp(irqmp_ts)) {
+ if (irqmp_ts == NULL) {
bsp_fatal(LEON3_FATAL_CLOCK_NO_IRQMP_TIMESTAMP_SUPPORT);
#endif
leon3_tc_tick = leon3_tc_tick_irqmp_timestamp_init;
- } else if (irqmp_has_timestamp(irqmp_ts)) {
+ } else if (irqmp_ts != NULL) {
/* Use the interrupt controller timestamp counter if available */
tc->tc_get_timecount = _SPARC_Get_timecount_up;
tc->tc_frequency = ambapp_freq_get(ambapp_plb(), LEON3_Timer_Adev);
@@ -218,7 +219,7 @@ static void leon3_clock_initialize(void)
* At least one TSISEL field must be non-zero to enable the timestamp
* counter. Use an arbitrary interrupt source.
- irqmp_ts->control = 0x1;
+ grlib_store_32(&irqmp_ts->itstmpc, IRQAMP_ITSTMPC_TSISEL(1));
} else {
#ifdef RTEMS_SMP
diff --git a/bsps/sparc/leon3/include/bsp/irq.h b/bsps/sparc/leon3/include/bsp/irq.h
index ef0f6245f9..38ea1de1f8 100644
--- a/bsps/sparc/leon3/include/bsp/irq.h
+++ b/bsps/sparc/leon3/include/bsp/irq.h
@@ -37,6 +37,7 @@
#ifndef LIBBSP_LEON3_IRQ_CONFIG_H
#define LIBBSP_LEON3_IRQ_CONFIG_H
+#include <rtems.h>
#include <rtems/score/processormask.h>
#define BSP_INTERRUPT_VECTOR_MAX_STD 15 /* Standard IRQ controller */
diff --git a/bsps/sparc/leon3/include/bsp/leon3.h b/bsps/sparc/leon3/include/bsp/leon3.h
index 7c723de129..6f4c872aab 100644
--- a/bsps/sparc/leon3/include/bsp/leon3.h
+++ b/bsps/sparc/leon3/include/bsp/leon3.h
@@ -37,8 +37,9 @@
#define _BSP_LEON3_H
-#include <grlib/grlib.h>
#include <grlib/apbuart-regs.h>
+#include <grlib/irqamp-regs.h>
+#include <grlib/io.h>
struct ambapp_dev;
@@ -52,15 +53,38 @@ extern "C" {
+ * @brief This object provides the index of the boot processor.
+ * This object should be read-only after initialization.
+extern uint32_t LEON3_Cpu_Index;
* @brief This lock serializes the interrupt controller access.
extern rtems_interrupt_lock LEON3_IrqCtrl_Lock;
+ * @brief Acquires the interrupt controller lock.
+ * @param[out] _lock_context is the lock context.
+#define LEON3_IRQCTRL_ACQUIRE( _lock_context ) \
+ rtems_interrupt_lock_acquire( &LEON3_IrqCtrl_Lock, _lock_context )
+ * @brief Releases the interrupt controller lock.
+ * @param[in, out] _lock_context is the lock context.
+#define LEON3_IRQCTRL_RELEASE( _lock_context ) \
+ rtems_interrupt_lock_release( &LEON3_IrqCtrl_Lock, _lock_context )
* @brief This pointer provides the IRQ(A)MP register block address.
-extern volatile struct irqmp_regs *LEON3_IrqCtrl_Regs;
+extern irqamp *LEON3_IrqCtrl_Regs;
* @brief This pointer provides the IRQ(A)MP device information block.
@@ -80,7 +104,7 @@ extern uint32_t LEON3_IrqCtrl_EIrq;
* @param[in, out] regs is the IRQ(A)MP register block address.
-void leon3_ext_irq_init( volatile struct irqmp_regs *regs );
+void leon3_ext_irq_init( irqamp *regs );
* @brief Acknowledges and maps extended interrupts if this feature is
@@ -91,12 +115,15 @@ void leon3_ext_irq_init( volatile struct irqmp_regs *regs );
static inline uint32_t bsp_irq_fixup( uint32_t irq )
uint32_t eirq;
+ uint32_t cpu_self;
if ( irq != LEON3_IrqCtrl_EIrq ) {
return irq;
- eirq = LEON3_IrqCtrl_Regs->intid[ _LEON3_Get_current_processor() ] & 0x1f;
+ cpu_self = _LEON3_Get_current_processor();
+ eirq = grlib_load_32( &LEON3_IrqCtrl_Regs->pextack[ cpu_self ] );
+ eirq = IRQAMP_PEXTACK_EID_4_0_GET( eirq );
if ( eirq < 16 ) {
return irq;
diff --git a/bsps/sparc/leon3/include/leon.h b/bsps/sparc/leon3/include/leon.h
index 82e93ddb41..69ae455f55 100644
--- a/bsps/sparc/leon3/include/leon.h
+++ b/bsps/sparc/leon3/include/leon.h
@@ -44,6 +44,7 @@
#include <amba.h>
#include <bsp/leon3.h>
#ifdef __cplusplus
@@ -151,9 +152,6 @@ extern "C" {
extern volatile struct gptimer_regs *LEON3_Timer_Regs;
extern struct ambapp_dev *LEON3_Timer_Adev;
-/* LEON3 CPU Index of boot CPU */
-extern uint32_t LEON3_Cpu_Index;
/* Macros used for manipulating bits in LEON3 GP Timer Control Register */
#define LEON3_IRQMPSTATUS_CPUNR 28
@@ -172,21 +170,11 @@ extern uint32_t LEON3_Cpu_Index;
* store the result back are vulnerable.
-#define LEON3_IRQCTRL_ACQUIRE( _lock_context ) \
- rtems_interrupt_lock_acquire( &LEON3_IrqCtrl_Lock, _lock_context )
-#define LEON3_IRQCTRL_RELEASE( _lock_context ) \
- rtems_interrupt_lock_release( &LEON3_IrqCtrl_Lock, _lock_context )
#define LEON_Clear_interrupt( _source ) \
- do { \
- LEON3_IrqCtrl_Regs->iclear = (1U << (_source)); \
- } while (0)
+ grlib_store_32(&LEON3_IrqCtrl_Regs->iclear, 1U << (_source))
#define LEON_Force_interrupt( _source ) \
- do { \
- LEON3_IrqCtrl_Regs->iforce = (1U << (_source)); \
- } while (0)
+ grlib_store_32(&LEON3_IrqCtrl_Regs->iforce0, 1U << (_source))
#define LEON_Enable_interrupt_broadcast( _source ) \
do { \
@@ -207,24 +195,30 @@ extern uint32_t LEON3_Cpu_Index;
} while (0)
#define LEON_Is_interrupt_pending( _source ) \
- (LEON3_IrqCtrl_Regs->ipend & (1U << (_source)))
+ (grlib_load_32(&LEON3_IrqCtrl_Regs->ipend) & (1U << (_source)))
#define LEON_Cpu_Is_interrupt_masked( _source, _cpu ) \
- (!(LEON3_IrqCtrl_Regs->mask[_cpu] & (1U << (_source))))
+ (!(grlib_load_32(&LEON3_IrqCtrl_Regs->pimask[_cpu]) & (1U << (_source))))
#define LEON_Cpu_Mask_interrupt( _source, _cpu ) \
do { \
rtems_interrupt_lock_context _lock_context; \
+ uint32_t _pimask; \
LEON3_IRQCTRL_ACQUIRE( &_lock_context ); \
- LEON3_IrqCtrl_Regs->mask[_cpu] &= ~(1U << (_source)); \
+ _pimask = grlib_load_32(&LEON3_IrqCtrl_Regs->pimask[_cpu ]); \
+ _pimask &= ~(1U << (_source)); \
+ grlib_store_32(&LEON3_IrqCtrl_Regs->pimask[_cpu ], _pimask); \
LEON3_IRQCTRL_RELEASE( &_lock_context ); \
} while (0)
#define LEON_Cpu_Unmask_interrupt( _source, _cpu ) \
do { \
- LEON3_IrqCtrl_Regs->mask[_cpu] |= (1U << (_source)); \
+ _pimask |= 1U << (_source); \
} while (0)
@@ -233,8 +227,8 @@ extern uint32_t LEON3_Cpu_Index;
uint32_t _mask = 1U << (_source); \
- (_previous) = LEON3_IrqCtrl_Regs->mask[_cpu]; \
- LEON3_IrqCtrl_Regs->mask[_cpu] = _previous & ~_mask; \
+ (_previous) = grlib_load_32(&LEON3_IrqCtrl_Regs->pimask[_cpu ]); \
+ grlib_store_32(&LEON3_IrqCtrl_Regs->pimask[_cpu ], (_previous) & ~_mask); \
(_previous) &= _mask; \
} while (0)
@@ -242,10 +236,12 @@ extern uint32_t LEON3_Cpu_Index;
#define LEON_Cpu_Restore_interrupt( _source, _previous, _cpu ) \
do { \
- uint32_t _mask = 1U << (_source); \
- LEON3_IrqCtrl_Regs->mask[_cpu] = \
- (LEON3_IrqCtrl_Regs->mask[_cpu] & ~_mask) | (_previous); \
+ _pimask |= _previous; \
} while (0)
@@ -389,15 +385,6 @@ extern unsigned int leon3_timer_prescaler;
RTEMS_NO_RETURN void leon3_power_down_loop(void);
-static inline uint32_t leon3_get_cpu_count(
- volatile struct irqmp_regs *irqmp
- uint32_t mpstat = irqmp->mpstat;
- return ((mpstat >> LEON3_IRQMPSTATUS_CPUNR) & 0xf) + 1;
static inline void leon3_set_system_register(uint32_t addr, uint32_t val)
__asm__ volatile(
diff --git a/bsps/sparc/leon3/start/amba.c b/bsps/sparc/leon3/start/amba.c
index 5ce3de6bdd..c1e26d316c 100644
--- a/bsps/sparc/leon3/start/amba.c
+++ b/bsps/sparc/leon3/start/amba.c
@@ -116,7 +116,7 @@ RTEMS_SYSINIT_ITEM(
#endif
/* Pointers to Interrupt Controller configuration registers */
-volatile struct irqmp_regs *LEON3_IrqCtrl_Regs;
+irqamp *LEON3_IrqCtrl_Regs;
struct ambapp_dev *LEON3_IrqCtrl_Adev;
@@ -133,7 +133,6 @@ struct ambapp_dev *LEON3_Timer_Adev;
static void amba_initialize(void)
- int icsel;
struct ambapp_dev *adev;
struct ambapp_bus *plb;
@@ -151,15 +150,17 @@ static void amba_initialize(void)
bsp_fatal(LEON3_FATAL_NO_IRQMP_CONTROLLER);
- LEON3_IrqCtrl_Regs = (volatile struct irqmp_regs *)DEV_TO_APB(adev)->start;
+ LEON3_IrqCtrl_Regs = (irqamp *)DEV_TO_APB(adev)->start;
LEON3_IrqCtrl_Adev = adev;
- if ((LEON3_IrqCtrl_Regs->ampctrl >> 28) > 0) {
+ if ((grlib_load_32(&LEON3_IrqCtrl_Regs->asmpctrl) >> 28) > 0) {
+ uint32_t icsel;
/* IRQ Controller has support for multiple IRQ Controllers, each
* CPU can be routed to different Controllers, we find out which
* controller by looking at the IRQCTRL Select Register for this CPU.
* Each Controller is located at a 4KByte offset.
- icsel = LEON3_IrqCtrl_Regs->icsel[LEON3_Cpu_Index/8];
+ icsel = grlib_load_32(&LEON3_IrqCtrl_Regs->icselr[LEON3_Cpu_Index/8]);
icsel = (icsel >> ((7 - (LEON3_Cpu_Index & 0x7)) * 4)) & 0xf;
LEON3_IrqCtrl_Regs += icsel;
diff --git a/bsps/sparc/leon3/start/bspclean.c b/bsps/sparc/leon3/start/bspclean.c
index 8724c38862..7414a61b83 100644
--- a/bsps/sparc/leon3/start/bspclean.c
+++ b/bsps/sparc/leon3/start/bspclean.c
@@ -55,9 +55,9 @@ void bsp_fatal_extension(
(code == SMP_FATAL_SHUTDOWN_RESPONSE)) {
leon3_power_down_loop(); /* CPU didn't start shutdown sequence .. */
} else {
- volatile struct irqmp_regs *irqmp = LEON3_IrqCtrl_Regs;
+ irqamp *regs = LEON3_IrqCtrl_Regs;
- if (irqmp != NULL) {
+ if (regs != NULL) {
* Value was chosen to get something in the magnitude of 1ms on a 200MHz
* processor.
@@ -76,7 +76,10 @@ void bsp_fatal_extension(
/* Wait some time for secondary processors to halt */
i = 0;
- while ((irqmp->mpstat & halt_mask) != halt_mask && i < max_wait) {
+ while (
+ (grlib_load_32(®s->mpstat) & halt_mask) != halt_mask &&
+ i < max_wait
++i;
diff --git a/bsps/sparc/leon3/start/bspsmp.c b/bsps/sparc/leon3/start/bspsmp.c
index acd932843a..a8ad60b497 100644
--- a/bsps/sparc/leon3/start/bspsmp.c
+++ b/bsps/sparc/leon3/start/bspsmp.c
@@ -17,6 +17,7 @@
#include <bsp/bootcard.h>
#include <bsp/fatal.h>
#include <bsp/irq.h>
+#include <bsp/leon3.h>
#include <leon.h>
#include <rtems/bspIo.h>
#include <rtems/sysinit.h>
@@ -75,6 +76,11 @@ static void leon3_install_inter_processor_interrupt( void )
_Assert_Unused_variable_equals( sc, RTEMS_SUCCESSFUL );
+static uint32_t leon3_get_cpu_count( const irqamp *regs )
+ return IRQAMP_MPSTAT_NCPU_GET( grlib_load_32( ®s->mpstat ) ) + 1;
uint32_t _CPU_SMP_Initialize( void )
if ( !leon3_data_cache_snooping_enabled() )
@@ -89,7 +95,10 @@ bool _CPU_SMP_Start_processor( uint32_t cpu_index )
printk( "Waking CPU %d\n", cpu_index );
#endif
- LEON3_IrqCtrl_Regs->mpstat = 1U << cpu_index;
+ grlib_store_32(
+ &LEON3_IrqCtrl_Regs->mpstat,
+ IRQAMP_MPSTAT_STATUS(1U << cpu_index)
return true;
@@ -111,7 +120,10 @@ void _CPU_SMP_Prepare_start_multitasking( void )
void _CPU_SMP_Send_interrupt(uint32_t target_processor_index)
/* send interrupt to destination CPU */
- LEON3_IrqCtrl_Regs->force[target_processor_index] = 1 << LEON3_mp_irq;
+ grlib_store_32(
+ &LEON3_IrqCtrl_Regs->piforce[target_processor_index],
+ 1U << LEON3_mp_irq
#if defined(RTEMS_DRVMGR_STARTUP)
diff --git a/bsps/sparc/leon3/start/cpucounter.c b/bsps/sparc/leon3/start/cpucounter.c
index b92840abb4..0a54ba9a74 100644
--- a/bsps/sparc/leon3/start/cpucounter.c
+++ b/bsps/sparc/leon3/start/cpucounter.c
@@ -26,6 +26,7 @@
#include <leon.h>
#include <rtems/counter.h>
@@ -40,11 +41,11 @@ uint32_t _CPU_Counter_frequency(void)
static void leon3_counter_initialize(void)
SPARC_Counter *counter;
counter = &_SPARC_Counter_mutable;
@@ -56,14 +57,14 @@ static void leon3_counter_initialize(void)
counter->read = _SPARC_Counter_read_asr23;
leon3_counter_frequency = leon3_up_counter_frequency();
counter->read_isr_disabled = _SPARC_Counter_read_up;
counter->read = _SPARC_Counter_read_up;
- counter->counter_register = &LEON3_IrqCtrl_Regs->timestamp[0].counter;
+ counter->counter_register = &irqmp_ts->itcnt;
/* Enable interrupt timestamping for an arbitrary interrupt line */
leon3_counter_frequency = ambapp_freq_get(ambapp_plb(), LEON3_IrqCtrl_Adev);
} else if (gpt != NULL) {
diff --git a/bsps/sparc/leon3/start/eirq.c b/bsps/sparc/leon3/start/eirq.c
index d9c5402dd0..7f9018cf54 100644
--- a/bsps/sparc/leon3/start/eirq.c
+++ b/bsps/sparc/leon3/start/eirq.c
@@ -31,9 +31,9 @@
-#include <leon.h>
#include <bsp/irq-generic.h>
/* GRLIB extended IRQ controller IRQ number */
@@ -42,12 +42,12 @@ rtems_interrupt_lock LEON3_IrqCtrl_Lock =
RTEMS_INTERRUPT_LOCK_INITIALIZER("LEON3 IrqCtrl");
/* Initialize Extended Interrupt controller */
-void leon3_ext_irq_init(volatile struct irqmp_regs *regs)
+void leon3_ext_irq_init(irqamp *regs)
- regs->mask[LEON3_Cpu_Index] = 0;
- regs->force[LEON3_Cpu_Index] = 0;
- regs->iclear = 0xffffffff;
- LEON3_IrqCtrl_EIrq = (regs->mpstat >> 16) & 0xf;
+ grlib_store_32(®s->pimask[LEON3_Cpu_Index], 0);
+ grlib_store_32(®s->piforce[LEON3_Cpu_Index], 0);
+ grlib_store_32(®s->iclear, 0xffffffff);
+ LEON3_IrqCtrl_EIrq = IRQAMP_MPSTAT_EIRQ_GET(grlib_load_32(®s->mpstat));
bool bsp_interrupt_is_valid_vector(rtems_vector_number vector)
@@ -112,14 +112,16 @@ rtems_status_code bsp_interrupt_is_pending(
rtems_interrupt_level level;
uint32_t bit;
+ irqamp *regs;
bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
bsp_interrupt_assert(pending != NULL);
bit = 1U << vector;
+ regs = LEON3_IrqCtrl_Regs;
rtems_interrupt_local_disable(level);
- *pending = (LEON3_IrqCtrl_Regs->ipend & bit) != 0 ||
- (LEON3_IrqCtrl_Regs->force[rtems_scheduler_get_processor()] & bit) != 0;
+ *pending = (grlib_load_32(®s->ipend) & bit) != 0 ||
+ (grlib_load_32(®s->piforce[rtems_scheduler_get_processor()]) & bit) != 0;
rtems_interrupt_local_enable(level);
return RTEMS_SUCCESSFUL;
@@ -127,9 +129,11 @@ rtems_status_code bsp_interrupt_is_pending(
rtems_status_code bsp_interrupt_raise(rtems_vector_number vector)
uint32_t bit;
+ irqamp *regs;
bit = 1U << vector;
if ( vector <= BSP_INTERRUPT_VECTOR_MAX_STD ) {
uint32_t cpu_count;
@@ -138,10 +142,11 @@ rtems_status_code bsp_interrupt_raise(rtems_vector_number vector)
cpu_count = rtems_scheduler_get_processor_maximum();
for (cpu_index = 0; cpu_index < cpu_count; ++cpu_index) {
- LEON3_IrqCtrl_Regs->force[cpu_index] = bit;
+ grlib_store_32(®s->piforce[cpu_index], bit);
} else {
rtems_interrupt_lock_context lock_context;
+ uint32_t ipend;
* This is a very dangerous operation and should only be used for test
@@ -149,7 +154,9 @@ rtems_status_code bsp_interrupt_raise(rtems_vector_number vector)
* peripherals with this read-modify-write operation.
LEON3_IRQCTRL_ACQUIRE(&lock_context);
- LEON3_IrqCtrl_Regs->ipend |= bit;
+ ipend = grlib_load_32(®s->ipend);
+ ipend |= bit;
+ grlib_store_32(®s->ipend, ipend);
LEON3_IRQCTRL_RELEASE(&lock_context);
@@ -162,6 +169,8 @@ rtems_status_code bsp_interrupt_raise_on(
uint32_t cpu_index
+ irqamp *regs;
bsp_interrupt_assert(cpu_index < rtems_scheduler_get_processor_maximum());
@@ -169,7 +178,8 @@ rtems_status_code bsp_interrupt_raise_on(
return RTEMS_UNSATISFIED;
- LEON3_IrqCtrl_Regs->force[cpu_index] = 1U << vector;
+ grlib_store_32(®s->piforce[cpu_index], 1U << vector);
#endif
@@ -177,14 +187,16 @@ rtems_status_code bsp_interrupt_raise_on(
rtems_status_code bsp_interrupt_clear(rtems_vector_number vector)
uint32_t bit;
+ irqamp *regs;
bit = 1U << vector;
- LEON3_IrqCtrl_Regs->iclear = bit;
+ grlib_store_32(®s->iclear, bit);
if (vector <= BSP_INTERRUPT_VECTOR_MAX_STD) {
- LEON3_IrqCtrl_Regs->force[rtems_scheduler_get_processor()] = bit << 16;
+ grlib_store_32(®s->piforce[rtems_scheduler_get_processor()], bit << 16);
@@ -195,9 +207,16 @@ rtems_status_code bsp_interrupt_vector_is_enabled(
bool *enabled
+ uint32_t bit;
+ irqamp *regs;
+ uint32_t pimask;
- *enabled =
- !BSP_Cpu_Is_interrupt_masked(vector, _LEON3_Get_current_processor());
+ bit = 1U << vector;
+ pimask = grlib_load_32(®s->pimask[_LEON3_Get_current_processor()]);
+ *enabled = (pimask & bit) != 0;
@@ -209,6 +228,8 @@ static void leon3_interrupt_vector_enable(rtems_vector_number vector)
Processor_mask affinity;
uint32_t bit;
uint32_t unmasked;
+ uint32_t brdcst;
+ irqamp *regs;
affinity = leon3_interrupt_affinities[vector];
@@ -218,72 +239,103 @@ static void leon3_interrupt_vector_enable(rtems_vector_number vector)
bit = 1U << vector;
unmasked = 0;
- uint32_t mask;
+ uint32_t pimask;
- mask = LEON3_IrqCtrl_Regs->mask[cpu_index];
+ pimask = grlib_load_32(®s->pimask[cpu_index]);
if (_Processor_mask_Is_set(&affinity, cpu_index)) {
++unmasked;
- mask |= bit;
+ pimask |= bit;
} else {
- mask &= ~bit;
+ pimask &= ~bit;
- LEON3_IrqCtrl_Regs->mask[cpu_index] = mask;
+ grlib_store_32(®s->pimask[cpu_index], pimask);
+ brdcst = grlib_load_32(®s->brdcst);
if (unmasked > 1) {
- LEON3_IrqCtrl_Regs->bcast |= bit;
+ brdcst |= bit;
} else {
- LEON3_IrqCtrl_Regs->bcast &= ~bit;
+ brdcst &= ~bit;
+ grlib_store_32(®s->brdcst, brdcst);
#endif
rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number vector)
-#if defined(RTEMS_SMP)
+#if !defined(RTEMS_SMP)
+ uint32_t bit;
+ irqamp *regs;
+ uint32_t pimask;
+ uint32_t cpu_index;
+#endif
+#endif
+#if defined(RTEMS_SMP)
leon3_interrupt_vector_enable(vector);
- LEON3_IRQCTRL_RELEASE(&lock_context);
#else
- bsp_interrupt_assert(bsp_interrupt_is_valid_vector(vector));
- BSP_Cpu_Unmask_interrupt(vector, _LEON3_Get_current_processor());
+ cpu_index = _LEON3_Get_current_processor();
+ pimask |= bit;
#endif
+ LEON3_IRQCTRL_RELEASE(&lock_context);
rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number vector)
uint32_t bit;
+ irqamp *regs;
+ uint32_t pimask;
uint32_t cpu_index;
uint32_t cpu_count;
+ uint32_t brdcst;
+#endif
bit = 1U << vector;
- cpu_count = rtems_scheduler_get_processor_maximum();
+ cpu_count = rtems_scheduler_get_processor_maximum();
- LEON3_IrqCtrl_Regs->mask[cpu_index] &= ~bit;
+ pimask &= ~bit;
+ brdcst &= ~bit;
#else
- BSP_Cpu_Mask_interrupt(vector, _LEON3_Get_current_processor());
+ pimask &= ~bit;
#endif
@@ -297,6 +349,7 @@ rtems_status_code bsp_interrupt_set_affinity(
uint32_t cpu_count;
uint32_t cpu_index;
uint32_t bit;
+ irqamp *regs;
if (vector >= RTEMS_ARRAY_SIZE(leon3_interrupt_affinities)) {
@@ -304,6 +357,7 @@ rtems_status_code bsp_interrupt_set_affinity(
bit = 1U << vector;
leon3_interrupt_affinities[vector] = *affinity;
@@ -313,7 +367,7 @@ rtems_status_code bsp_interrupt_set_affinity(
* using the new affinity.
- if ((LEON3_IrqCtrl_Regs->mask[cpu_index] & bit) != 0) {
+ if ((grlib_load_32(®s->pimask[cpu_index]) & bit) != 0) {
break;
2.35.3
