[PATCH 15/34] bsp/leon3: Use new GPTIMER register block API
Sebastian Huber
Wed May 31 16:30:50 UTC 2023
bsps/shared/grlib/btimer/gptimer.c | 170 +++++++++++++--------------
bsps/sparc/leon3/btimer/btimer.c | 13 +-
bsps/sparc/leon3/btimer/watchdog.c | 27 +++--
bsps/sparc/leon3/clock/ckinit.c | 33 +++---
bsps/sparc/leon3/include/bsp/leon3.h | 44 ++++++-
bsps/sparc/leon3/include/leon.h | 24 ----
bsps/sparc/leon3/start/amba.c | 9 +-
bsps/sparc/leon3/start/bspdelay.c | 8 +-
bsps/sparc/leon3/start/cpucounter.c | 20 ++--
9 files changed, 186 insertions(+), 162 deletions(-)
diff --git a/bsps/shared/grlib/btimer/gptimer.c b/bsps/shared/grlib/btimer/gptimer.c
index f31b7c052f..c5d62a50ab 100644
--- a/bsps/shared/grlib/btimer/gptimer.c
+++ b/bsps/shared/grlib/btimer/gptimer.c
@@ -61,7 +61,7 @@
#include <grlib/tlib.h>
#if defined(LEON3)
-#include <leon.h>
+#include <bsp/leon3.h>
#endif
#ifdef GPTIMER_INFO_AVAIL
@@ -75,49 +75,21 @@
#include <grlib/grlib_impl.h>
-/* GPTIMER Core Configuration Register (READ-ONLY) */
-#define GPTIMER_CFG_TIMERS_BIT 0
-#define GPTIMER_CFG_IRQ_BIT 3
-#define GPTIMER_CFG_SI_BIT 8
-#define GPTIMER_CFG_DF_BIT 9
-#define GPTIMER_CFG_TIMERS (0x7<<GPTIMER_CFG_TIMERS_BIT)
-#define GPTIMER_CFG_IRQ (0x1f<<GPTIMER_CFG_IRQ_BIT)
-#define GPTIMER_CFG_SI (1<<GPTIMER_CFG_SI_BIT)
-#define GPTIMER_CFG_DF (1<<GPTIMER_CFG_DF_BIT)
-/* GPTIMER Timer Control Register */
-#define GPTIMER_CTRL_EN_BIT 0
-#define GPTIMER_CTRL_RS_BIT 1
-#define GPTIMER_CTRL_LD_BIT 2
-#define GPTIMER_CTRL_IE_BIT 3
-#define GPTIMER_CTRL_IP_BIT 4
-#define GPTIMER_CTRL_CH_BIT 5
-#define GPTIMER_CTRL_DH_BIT 6
-#define GPTIMER_CTRL_EN (1<<GPTIMER_CTRL_EN_BIT)
-#define GPTIMER_CTRL_RS (1<<GPTIMER_CTRL_RS_BIT)
-#define GPTIMER_CTRL_LD (1<<GPTIMER_CTRL_LD_BIT)
-#define GPTIMER_CTRL_IE (1<<GPTIMER_CTRL_IE_BIT)
-#define GPTIMER_CTRL_IP (1<<GPTIMER_CTRL_IP_BIT)
-#define GPTIMER_CTRL_CH (1<<GPTIMER_CTRL_CH_BIT)
-#define GPTIMER_CTRL_DH (1<<GPTIMER_CTRL_DH_BIT)
#define DBG(x...)
/* GPTIMER timer private */
-struct gptimer_timer {
+struct gptimer_timer_priv {
struct tlib_dev tdev; /* Must be first in struct */
- struct gptimer_timer_regs *tregs;
+ gptimer_timer *tregs;
char index; /* Timer Index in this driver */
char tindex; /* Timer Index In Hardware */
- unsigned char irq_ack_mask;
+ uint32_t irq_ack_mask;
/* GPTIMER Core private */
struct gptimer_priv {
struct drvmgr_dev *dev;
- struct gptimer_regs *regs;
+ gptimer *regs;
unsigned int base_clk;
unsigned int base_freq;
unsigned int widthmask;
@@ -126,7 +98,7 @@ struct gptimer_priv {
/* Structure per Timer unit, the core supports up to 8 timers */
int timer_cnt;
- struct gptimer_timer timers[0];
+ struct gptimer_timer_priv timers[0];
void gptimer_isr(void *data);
@@ -200,14 +172,14 @@ void gptimer_register_drv (void)
int gptimer_init1(struct drvmgr_dev *dev)
struct gptimer_priv *priv;
+ gptimer *regs;
struct amba_dev_info *ambadev;
struct ambapp_core *pnpinfo;
int timer_hw_cnt, timer_cnt, timer_start;
int i, size;
- struct gptimer_timer *timer;
+ struct gptimer_timer_priv *timer;
union drvmgr_key_value *value;
/* Get device information from AMBA PnP information */
ambadev = (struct amba_dev_info *)dev->businfo;
@@ -215,12 +187,12 @@ int gptimer_init1(struct drvmgr_dev *dev)
return -1;
pnpinfo = &ambadev->info;
- regs = (struct gptimer_regs *)pnpinfo->apb_slv->start;
+ regs = (gptimer *)pnpinfo->apb_slv->start;
DBG("GPTIMER[%d] on bus %s\n", dev->minor_drv, dev->parent->dev->name);
/* Get number of Timers */
- timer_hw_cnt = regs->cfg & GPTIMER_CFG_TIMERS;
+ timer_hw_cnt = GPTIMER_CONFIG_TIMERS_GET(grlib_load_32(®s->config));
/* Let user spelect a range of timers to be used. In AMP systems
* it is sometimes neccessary to leave timers for other CPU instances.
@@ -251,7 +223,7 @@ int gptimer_init1(struct drvmgr_dev *dev)
* are present.
size = sizeof(struct gptimer_priv) +
- timer_cnt*sizeof(struct gptimer_timer);
+ timer_cnt*sizeof(struct gptimer_timer_priv);
priv = dev->priv = grlib_calloc(1, size);
if ( !priv )
return DRVMGR_NOMEM;
@@ -277,24 +249,24 @@ int gptimer_init1(struct drvmgr_dev *dev)
value = drvmgr_dev_key_get(priv->dev, "prescaler", DRVMGR_KT_INT);
if ( value )
- regs->scaler_reload = value->i;
+ grlib_store_32(®s->sreload, value->i);
/* Get Frequency that the timers are operating in (after prescaler) */
- priv->base_freq = priv->base_clk / (priv->regs->scaler_reload + 1);
+ priv->base_freq = priv->base_clk / (grlib_load_32(®s->sreload) + 1);
/* Stop Timer and probe Pending bit. In newer hardware the
* timer has pending bit is cleared by writing a one to it,
* whereas older versions it is cleared with a zero.
- priv->regs->timer[timer_start].ctrl = GPTIMER_CTRL_IP;
- if ((priv->regs->timer[timer_start].ctrl & GPTIMER_CTRL_IP) != 0)
- irq_ack_mask = ~GPTIMER_CTRL_IP;
+ grlib_store_32(®s->timer[timer_start].tctrl, GPTIMER_TCTRL_IP);
+ if ((grlib_load_32(®s->timer[timer_start].tctrl) & GPTIMER_TCTRL_IP) != 0)
+ irq_ack_mask = ~GPTIMER_TCTRL_IP;
else
- irq_ack_mask = ~0;
+ irq_ack_mask = ~0U;
/* Probe timer register width mask */
- priv->regs->timer[timer_start].value = 0xffffffff;
- priv->widthmask = priv->regs->timer[timer_start].value;
+ grlib_store_32(®s->timer[timer_start].tcntval, 0xffffffff);
+ priv->widthmask = grlib_load_32(®s->timer[timer_start].tcntval);
priv->timer_cnt = timer_cnt;
for (i=0; i<timer_cnt; i++) {
@@ -314,7 +286,7 @@ int gptimer_init1(struct drvmgr_dev *dev)
* B. Each Timer have an individual IRQ. The number is:
* BASE_IRQ + timer_index
- priv->separate_interrupt = (regs->cfg & GPTIMER_CFG_SI) != 0;
+ priv->separate_interrupt = (grlib_load_32(®s->config) & GPTIMER_CONFIG_SI) != 0;
return DRVMGR_OK;
@@ -326,7 +298,7 @@ static int gptimer_info(
void *p, int argc, char *argv[])
struct gptimer_priv *priv = dev->priv;
char buf[64];
int i;
@@ -337,7 +309,7 @@ static int gptimer_info(
print_line(p, buf);
sprintf(buf, "REGS: 0x%08x", (unsigned int)priv->regs);
print_line(p, buf);
- sprintf(buf, "BASE SCALER: %d", priv->regs->scaler_reload);
+ sprintf(buf, "BASE SCALER: %d", grlib_load_32(&priv->regs->sreload));
print_line(p, buf);
sprintf(buf, "BASE FREQ: %dkHz", priv->base_freq / 1000);
print_line(p, buf);
@@ -350,9 +322,9 @@ static int gptimer_info(
print_line(p, buf);
sprintf(buf, " TLIB Index: %d", timer->index);
print_line(p, buf);
- sprintf(buf, " RELOAD REG: %d", timer->tregs->reload);
+ sprintf(buf, " RELOAD REG: %d", grlib_load_32(&timer->tregs->trldval));
print_line(p, buf);
- sprintf(buf, " CTRL REG: %d", timer->tregs->ctrl);
+ sprintf(buf, " CTRL REG: %d", grlib_load_32(&timer->tregs->tctrl));
print_line(p, buf);
@@ -360,24 +332,28 @@ static int gptimer_info(
#endif
-static inline struct gptimer_priv *priv_from_timer(struct gptimer_timer *t)
+static inline struct gptimer_priv *priv_from_timer(struct gptimer_timer_priv *t)
return (struct gptimer_priv *)
((unsigned int)t -
sizeof(struct gptimer_priv) -
- t->index * sizeof(struct gptimer_timer));
+ t->index * sizeof(struct gptimer_timer_priv));
static int gptimer_tlib_int_pend(struct tlib_dev *hand, int ack)
- struct gptimer_timer *timer = (struct gptimer_timer *)hand;
- unsigned int ctrl = timer->tregs->ctrl;
+ struct gptimer_timer_priv *timer = (struct gptimer_timer_priv *)hand;
+ uint32_t tctrl;
+ tctrl = grlib_load_32(&timer->tregs->tctrl);
- if ((ctrl & (GPTIMER_CTRL_IP | GPTIMER_CTRL_IE)) ==
- (GPTIMER_CTRL_IP | GPTIMER_CTRL_IE)) {
+ if ((tctrl & (GPTIMER_TCTRL_IP | GPTIMER_TCTRL_IE)) ==
+ (GPTIMER_TCTRL_IP | GPTIMER_TCTRL_IE)) {
/* clear Pending IRQ ? */
- if (ack)
- timer->tregs->ctrl = ctrl & timer->irq_ack_mask;
+ if (ack) {
+ tctrl &= timer->irq_ack_mask;
+ grlib_store_32(&timer->tregs->tctrl, tctrl);
return 1; /* timer generated IRQ */
} else
return 0; /* was not timer causing IRQ */
@@ -406,12 +382,14 @@ void gptimer_isr(void *data)
static void gptimer_tlib_reset(struct tlib_dev *hand)
- timer->tregs->ctrl = (timer->tregs->ctrl & timer->irq_ack_mask) &
- GPTIMER_CTRL_IP;
- timer->tregs->reload = 0xffffffff;
- timer->tregs->ctrl = GPTIMER_CTRL_LD;
+ uint32_t tctrl;
+ tctrl &= timer->irq_ack_mask | GPTIMER_TCTRL_IP;
+ grlib_store_32(&timer->tregs->trldval, 0xffffffff);
+ grlib_store_32(&timer->tregs->tctrl, GPTIMER_TCTRL_LD);
static void gptimer_tlib_get_freq(
@@ -419,24 +397,24 @@ static void gptimer_tlib_get_freq(
unsigned int *basefreq,
unsigned int *tickrate)
struct gptimer_priv *priv = priv_from_timer(timer);
/* Calculate base frequency from Timer Clock and Prescaler */
if ( basefreq )
*basefreq = priv->base_freq;
if ( tickrate )
- *tickrate = timer->tregs->reload + 1;
+ *tickrate = grlib_load_32(&timer->tregs->trldval) + 1;
static int gptimer_tlib_set_freq(struct tlib_dev *hand, unsigned int tickrate)
- timer->tregs->reload = tickrate - 1;
+ grlib_store_32(&timer->tregs->trldval, tickrate - 1);
/*Check that value was allowed (Timer may not be as wide as expected)*/
- if ( timer->tregs->reload != (tickrate - 1) )
+ if (grlib_load_32(&timer->tregs->trldval) != (tickrate - 1))
return -1;
else
return 0;
@@ -444,8 +422,9 @@ static int gptimer_tlib_set_freq(struct tlib_dev *hand, unsigned int tickrate)
static void gptimer_tlib_irq_reg(struct tlib_dev *hand, tlib_isr_t func, void *data, int flags)
+ uint32_t tctrl;
if ( priv->separate_interrupt ) {
drvmgr_interrupt_register(priv->dev, timer->tindex,
@@ -476,16 +455,21 @@ static void gptimer_tlib_irq_reg(struct tlib_dev *hand, tlib_isr_t func, void *d
#endif
- timer->tregs->ctrl |= GPTIMER_CTRL_IE;
+ tctrl |= GPTIMER_TCTRL_IE;
static void gptimer_tlib_irq_unreg(struct tlib_dev *hand, tlib_isr_t func, void *data)
+ uint32_t tctrl;
/* Turn off IRQ at source, unregister IRQ handler */
- timer->tregs->ctrl &= ~GPTIMER_CTRL_IE;
+ tctrl &= ~GPTIMER_TCTRL_IE;
drvmgr_interrupt_unregister(priv->dev, timer->tindex,
@@ -502,46 +486,54 @@ static void gptimer_tlib_irq_unreg(struct tlib_dev *hand, tlib_isr_t func, void
static void gptimer_tlib_start(struct tlib_dev *hand, int once)
- unsigned int ctrl;
+ uint32_t tctrl;
/* Load the selected frequency before starting Frequency */
- ctrl = GPTIMER_CTRL_LD | GPTIMER_CTRL_EN;
+ tctrl &= ~GPTIMER_TCTRL_RS;
+ tctrl |= GPTIMER_TCTRL_LD | GPTIMER_TCTRL_EN;
if ( once == 0 )
- ctrl |= GPTIMER_CTRL_RS; /* Restart Timer */
- timer->tregs->ctrl = ctrl | (timer->tregs->ctrl & timer->irq_ack_mask &
- ~GPTIMER_CTRL_RS);
+ tctrl |= GPTIMER_TCTRL_RS; /* Restart Timer */
static void gptimer_tlib_stop(struct tlib_dev *hand)
+ uint32_t tctrl;
/* Load the selected Frequency */
- timer->tregs->ctrl &= ~(GPTIMER_CTRL_EN|GPTIMER_CTRL_IP);
+ tctrl &= ~(GPTIMER_TCTRL_EN|GPTIMER_TCTRL_IP);
static void gptimer_tlib_restart(struct tlib_dev *hand)
+ uint32_t tctrl;
- timer->tregs->ctrl |= GPTIMER_CTRL_LD | GPTIMER_CTRL_EN;
static void gptimer_tlib_get_counter(
unsigned int *counter)
- *counter = timer->tregs->value;
+ *counter = grlib_load_32(&timer->tregs->tcntval);
static void gptimer_tlib_get_widthmask(
unsigned int *widthmask)
*widthmask = priv->widthmask;
diff --git a/bsps/sparc/leon3/btimer/btimer.c b/bsps/sparc/leon3/btimer/btimer.c
index 9e9f2b02fc..9f2a7ede74 100644
--- a/bsps/sparc/leon3/btimer/btimer.c
+++ b/bsps/sparc/leon3/btimer/btimer.c
@@ -33,23 +33,21 @@ bool benchmark_timer_find_average_overhead;
bool benchmark_timer_is_initialized = false;
-extern volatile struct gptimer_regs *LEON3_Timer_Regs;
void benchmark_timer_initialize(void)
* Timer runs long and accurate enough not to require an interrupt.
if (LEON3_Timer_Regs) {
+ gptimer_timer *timer = &LEON3_Timer_Regs->timer[LEON3_TIMER_INDEX];
if ( benchmark_timer_is_initialized == false ) {
/* approximately 1 us per countdown */
- LEON3_Timer_Regs->timer[LEON3_TIMER_INDEX].reload = 0xffffff;
- LEON3_Timer_Regs->timer[LEON3_TIMER_INDEX].value = 0xffffff;
+ grlib_store_32( &timer->trldval, 0xffffff );
+ grlib_store_32( &timer->tcntval, 0xffffff );
} else {
benchmark_timer_is_initialized = true;
- LEON3_Timer_Regs->timer[LEON3_TIMER_INDEX].ctrl =
- GPTIMER_TIMER_CTRL_EN | GPTIMER_TIMER_CTRL_LD;
+ grlib_store_32( &timer->tctrl, GPTIMER_TCTRL_EN | GPTIMER_TCTRL_LD );
@@ -62,7 +60,8 @@ benchmark_timer_t benchmark_timer_read(void)
uint32_t total;
- total = LEON3_Timer_Regs->timer[LEON3_TIMER_INDEX].value;
+ total =
+ grlib_load_32( &LEON3_Timer_Regs->timer[LEON3_TIMER_INDEX].tcntval );
total = 0xffffff - total;
diff --git a/bsps/sparc/leon3/btimer/watchdog.c b/bsps/sparc/leon3/btimer/watchdog.c
index 8b875aa2a8..919744496f 100644
--- a/bsps/sparc/leon3/btimer/watchdog.c
+++ b/bsps/sparc/leon3/btimer/watchdog.c
@@ -30,14 +30,12 @@
#include <bsp.h>
#include <bsp/watchdog.h>
-#include <grlib/grlib.h>
struct gptimer_watchdog_priv {
- struct gptimer_timer_regs *timer;
+ gptimer *regs;
+ gptimer_timer *timer;
int timerno;
@@ -60,10 +58,10 @@ int bsp_watchdog_init(void)
* functionality is available or not, we assume that it is if we
* reached this function.
- bsp_watchdogs[0].regs = (struct gptimer_regs *)LEON3_Timer_Regs;
+ bsp_watchdogs[0].regs = LEON3_Timer_Regs;
/* Find Timer that has watchdog functionality */
- timercnt = bsp_watchdogs[0].regs->cfg & 0x7;
+ timercnt = grlib_load_32(&bsp_watchdogs[0].regs->config) & 0x7;
if (timercnt < 2) /* First timer system clock timer */
return 0;
@@ -76,6 +74,9 @@ int bsp_watchdog_init(void)
void bsp_watchdog_reload(int watchdog, unsigned int reload_value)
+ uint32_t tctrl;
if (bsp_watchdog_count == 0)
bsp_watchdog_init();
@@ -83,10 +84,12 @@ void bsp_watchdog_reload(int watchdog, unsigned int reload_value)
return;
/* Kick watchdog, and clear interrupt pending bit */
- bsp_watchdogs[watchdog].timer->reload = reload_value;
- bsp_watchdogs[watchdog].timer->ctrl =
- (GPTIMER_TIMER_CTRL_LD | GPTIMER_TIMER_CTRL_EN) |
- (bsp_watchdogs[watchdog].timer->ctrl & ~(1<<4));
+ timer = bsp_watchdogs[watchdog].timer;
+ grlib_store_32(&timer->trldval, reload_value);
+ tctrl = grlib_load_32(&timer->tctrl);
+ tctrl &= ~GPTIMER_TCTRL_IP;
+ grlib_store_32(&timer->tctrl, tctrl);
void bsp_watchdog_stop(int watchdog)
@@ -98,7 +101,7 @@ void bsp_watchdog_stop(int watchdog)
return;
/* Stop watchdog timer */
- bsp_watchdogs[watchdog].timer->ctrl = 0;
+ grlib_store_32(&bsp_watchdogs[watchdog].timer->tctrl, 0);
/* Use watchdog timer to reset system */
diff --git a/bsps/sparc/leon3/clock/ckinit.c b/bsps/sparc/leon3/clock/ckinit.c
index b3761bed35..eea598dd48 100644
--- a/bsps/sparc/leon3/clock/ckinit.c
+++ b/bsps/sparc/leon3/clock/ckinit.c
@@ -42,7 +42,7 @@
#include <bsp.h>
#include <bsp/fatal.h>
#include <bsp/irq.h>
-#include <leon.h>
#include <rtems/rtems/intr.h>
#include <grlib/ambapp.h>
#include <grlib/irqamp.h>
@@ -144,7 +144,7 @@ static void leon3_tc_do_tick(void)
do { \
/* Assume timer found during BSP initialization */ \
if (LEON3_Timer_Regs) { \
- clkirq = (LEON3_Timer_Regs->cfg & 0xf8) >> 3; \
+ clkirq = (grlib_load_32(&LEON3_Timer_Regs->config) & 0xf8) >> 3; \
Adjust_clkirq_for_node(); \
@@ -181,19 +181,22 @@ static void bsp_clock_handler_install(rtems_interrupt_handler isr)
static void leon3_clock_initialize(void)
irqamp_timestamp *irqmp_ts;
- volatile struct gptimer_regs *gpt;
struct timecounter *tc;
- irqmp_ts = irqamp_get_timestamp_registers(LEON3_IrqCtrl_Regs);
- gpt = LEON3_Timer_Regs;
- tc = &leon3_tc;
+ timer = &LEON3_Timer_Regs->timer[LEON3_CLOCK_INDEX];
- gpt->timer[LEON3_CLOCK_INDEX].reload =
- rtems_configuration_get_microseconds_per_tick() - 1;
- gpt->timer[LEON3_CLOCK_INDEX].ctrl =
- GPTIMER_TIMER_CTRL_EN | GPTIMER_TIMER_CTRL_RS |
- GPTIMER_TIMER_CTRL_LD | GPTIMER_TIMER_CTRL_IE;
+ grlib_store_32(
+ &timer->trldval,
+ rtems_configuration_get_microseconds_per_tick() - 1
+ grlib_store_32(
+ &timer->tctrl,
+ GPTIMER_TCTRL_EN | GPTIMER_TCTRL_RS | GPTIMER_TCTRL_LD | GPTIMER_TCTRL_IE
+ irqmp_ts = irqamp_get_timestamp_registers(LEON3_IrqCtrl_Regs);
+ tc = &leon3_tc;
leon3_up_counter_enable();
if (leon3_up_counter_is_available()) {
@@ -227,8 +230,10 @@ static void leon3_clock_initialize(void)
* controller. At least on SMP configurations we must use a second timer
* in free running mode for the timecounter.
- gpt->timer[LEON3_COUNTER_GPTIMER_INDEX].ctrl =
- GPTIMER_TIMER_CTRL_EN | GPTIMER_TIMER_CTRL_IE;
+ grlib_store_32(
+ &LEON3_Timer_Regs->timer[LEON3_COUNTER_GPTIMER_INDEX].tctrl,
+ GPTIMER_TCTRL_EN | GPTIMER_TCTRL_IE
tc->tc_get_timecount = _SPARC_Get_timecount_down;
#else
@@ -237,7 +242,7 @@ static void leon3_clock_initialize(void)
counter = &_SPARC_Counter_mutable;
counter->read_isr_disabled = _SPARC_Counter_read_clock_isr_disabled;
counter->read = _SPARC_Counter_read_clock;
- counter->counter_register = &gpt->timer[LEON3_CLOCK_INDEX].value;
+ counter->counter_register = &timer->tcntval;
counter->pending_register = &LEON3_IrqCtrl_Regs->ipend;
counter->pending_mask = UINT32_C(1) << clkirq;
counter->accumulated = rtems_configuration_get_microseconds_per_tick();
diff --git a/bsps/sparc/leon3/include/bsp/leon3.h b/bsps/sparc/leon3/include/bsp/leon3.h
index d1fad2dd19..a8e900eef4 100644
--- a/bsps/sparc/leon3/include/bsp/leon3.h
+++ b/bsps/sparc/leon3/include/bsp/leon3.h
@@ -9,7 +9,7 @@
- * Copyright (C) 2021 embedded brains GmbH & Co. KG
+ * Copyright (C) 2014, 2021 embedded brains GmbH & Co. KG
* modification, are permitted provided that the following conditions
@@ -38,6 +38,7 @@
#include <grlib/apbuart-regs.h>
+#include <grlib/gptimer-regs.h>
#include <grlib/irqamp-regs.h>
#include <grlib/io.h>
@@ -233,6 +234,47 @@ static inline uint32_t bsp_irq_fixup( uint32_t irq )
return eirq;
+ * @brief This constant defines the index of the GPTIMER timer used by the
+ * clock driver.
+#if defined(RTEMS_MULTIPROCESSING)
+#define LEON3_CLOCK_INDEX \
+ ( rtems_configuration_get_user_multiprocessing_table() ? LEON3_Cpu_Index : 0 )
+#else
+#define LEON3_CLOCK_INDEX 0
+#endif
+ * CPU counter if the CPU counter uses the GPTIMER.
+#if defined(RTEMS_SMP)
+#define LEON3_COUNTER_GPTIMER_INDEX ( LEON3_CLOCK_INDEX + 1 )
+#else
+#define LEON3_COUNTER_GPTIMER_INDEX LEON3_CLOCK_INDEX
+#endif
+ * @brief This constant defines the frequency set by the boot loader of the
+ * first GPTIMER instance.
+ * We assume that a boot loader (usually GRMON) initialized the GPTIMER 0 to
+ * run with 1MHz. This is used to determine all clock frequencies of the PnP
+ * devices. See also ambapp_freq_init() and ambapp_freq_get().
+#define LEON3_GPTIMER_0_FREQUENCY_SET_BY_BOOT_LOADER 1000000
+ * @brief This pointer provides the GPTIMER register block address.
+extern gptimer *LEON3_Timer_Regs;
+ * @brief This pointer provides the GPTIMER device information block.
+extern struct ambapp_dev *LEON3_Timer_Adev;
* @brief Gets the LEON up-counter low register (%ASR23) value.
diff --git a/bsps/sparc/leon3/include/leon.h b/bsps/sparc/leon3/include/leon.h
index 6fe499989d..be3819737a 100644
--- a/bsps/sparc/leon3/include/leon.h
+++ b/bsps/sparc/leon3/include/leon.h
@@ -142,10 +142,6 @@ extern "C" {
#define LEON_REG_UART_CTRL_FA 0x80000000 /* FIFO Available */
#define LEON_REG_UART_CTRL_FA_BIT 31
-/* LEON3 GP Timer */
-extern struct ambapp_dev *LEON3_Timer_Adev;
/* Macros used for manipulating bits in LEON3 GP Timer Control Register */
#define LEON3_IRQMPSTATUS_CPUNR 28
@@ -310,26 +306,6 @@ extern struct ambapp_dev *LEON3_Timer_Adev;
#define LEON_REG_TIMER_COUNTER_DEFINED_MASK 0x00000003
#define LEON_REG_TIMER_COUNTER_CURRENT_MODE_MASK 0x00000003
-#if defined(RTEMS_MULTIPROCESSING)
- #define LEON3_CLOCK_INDEX \
- (rtems_configuration_get_user_multiprocessing_table() ? LEON3_Cpu_Index : 0)
-#else
- #define LEON3_CLOCK_INDEX 0
-#endif
-#if defined(RTEMS_SMP)
-#define LEON3_COUNTER_GPTIMER_INDEX (LEON3_CLOCK_INDEX + 1)
-#else
-#define LEON3_COUNTER_GPTIMER_INDEX LEON3_CLOCK_INDEX
-#endif
- * We assume that a boot loader (usually GRMON) initialized the GPTIMER 0 to
- * run with 1MHz. This is used to determine all clock frequencies of the PnP
- * devices. See also ambapp_freq_init() and ambapp_freq_get().
-#define LEON3_GPTIMER_0_FREQUENCY_SET_BY_BOOT_LOADER 1000000
/* Load 32-bit word by forcing a cache-miss */
static inline unsigned int leon_r32_no_cache(uintptr_t addr)
diff --git a/bsps/sparc/leon3/start/amba.c b/bsps/sparc/leon3/start/amba.c
index c1e26d316c..d4494224c4 100644
--- a/bsps/sparc/leon3/start/amba.c
+++ b/bsps/sparc/leon3/start/amba.c
@@ -118,7 +118,8 @@ RTEMS_SYSINIT_ITEM(
/* Pointers to Interrupt Controller configuration registers */
irqamp *LEON3_IrqCtrl_Regs;
struct ambapp_dev *LEON3_IrqCtrl_Adev;
-volatile struct gptimer_regs *LEON3_Timer_Regs;
+gptimer *LEON3_Timer_Regs;
@@ -170,14 +171,14 @@ static void amba_initialize(void)
VENDOR_GAISLER, GAISLER_GPTIMER,
ambapp_find_by_idx, &leon3_timer_core_index);
if (adev) {
- LEON3_Timer_Regs = (volatile struct gptimer_regs *)DEV_TO_APB(adev)->start;
+ LEON3_Timer_Regs = (gptimer *)DEV_TO_APB(adev)->start;
LEON3_Timer_Adev = adev;
/* Register AMBA Bus Frequency */
ambapp_freq_init(
plb,
LEON3_Timer_Adev,
- (LEON3_Timer_Regs->scaler_reload + 1)
+ (grlib_load_32(&LEON3_Timer_Regs->sreload) + 1)
* LEON3_GPTIMER_0_FREQUENCY_SET_BY_BOOT_LOADER
/* Set user prescaler configuration. Use this to increase accuracy of timer
@@ -186,7 +187,7 @@ static void amba_initialize(void)
* GRTIMER/GPTIMER hardware. See HW manual.
if (leon3_timer_prescaler)
- LEON3_Timer_Regs->scaler_reload = leon3_timer_prescaler;
+ grlib_store_32(&LEON3_Timer_Regs->sreload, leon3_timer_prescaler);
diff --git a/bsps/sparc/leon3/start/bspdelay.c b/bsps/sparc/leon3/start/bspdelay.c
index c4a880be6d..6695f76929 100644
--- a/bsps/sparc/leon3/start/bspdelay.c
+++ b/bsps/sparc/leon3/start/bspdelay.c
@@ -14,15 +14,17 @@
#include <bsp.h>
-#include <leon.h>
void rtems_bsp_delay(int usecs)
uint32_t then;
+ gptimer_timer *regs;
- then =LEON3_Timer_Regs->timer[0].value;
+ regs = &LEON3_Timer_Regs->timer[0];
+ then =grlib_load_32(®s->tcntval);
then += usecs;
- while (LEON3_Timer_Regs->timer[0].value >= then)
+ while (grlib_load_32(®s->tcntval) >= then)
diff --git a/bsps/sparc/leon3/start/cpucounter.c b/bsps/sparc/leon3/start/cpucounter.c
index 0a54ba9a74..5672cbbd45 100644
--- a/bsps/sparc/leon3/start/cpucounter.c
+++ b/bsps/sparc/leon3/start/cpucounter.c
@@ -25,7 +25,7 @@
* POSSIBILITY OF SUCH DAMAGE.
-#include <leon.h>
#include <rtems/counter.h>
@@ -42,7 +42,7 @@ uint32_t _CPU_Counter_frequency(void)
static void leon3_counter_initialize(void)
+ gptimer *gpt;
SPARC_Counter *counter;
@@ -68,19 +68,23 @@ static void leon3_counter_initialize(void)
leon3_counter_frequency = ambapp_freq_get(ambapp_plb(), LEON3_IrqCtrl_Adev);
} else if (gpt != NULL) {
+ uint32_t tctrl;
/* Fall back to the first GPTIMER if available */
+ timer = &gpt->timer[LEON3_COUNTER_GPTIMER_INDEX];
counter->read_isr_disabled = _SPARC_Counter_read_down;
counter->read = _SPARC_Counter_read_down;
- counter->counter_register = &gpt->timer[LEON3_COUNTER_GPTIMER_INDEX].value;
/* Enable timer just in case no clock driver is configured */
- gpt->timer[LEON3_COUNTER_GPTIMER_INDEX].reload = 0xffffffff;
- gpt->timer[LEON3_COUNTER_GPTIMER_INDEX].ctrl |= GPTIMER_TIMER_CTRL_EN |
- GPTIMER_TIMER_CTRL_RS |
- GPTIMER_TIMER_CTRL_LD;
+ grlib_store_32(&timer->trldval, 0xffffffff);
+ tctrl |= GPTIMER_TCTRL_EN | GPTIMER_TCTRL_RS | GPTIMER_TCTRL_LD;
leon3_counter_frequency = ambapp_freq_get(ambapp_plb(), LEON3_Timer_Adev) /
- (gpt->scaler_reload + 1);
+ (grlib_load_32(&gpt->sreload) + 1);
2.35.3
