[PATCH 14/34] bsp/leon3: Move up-counter support
Wed May 31 16:30:49 UTC 2023
Move, document, and reformat support functions from <leon.h> to
<bsp/leon3.h>.
 bsps/sparc/leon3/include/bsp/leon3.h | 72 ++++++++++++++++++++++++++++
 bsps/sparc/leon3/include/leon.h      | 45 -----------------
 2 files changed, 72 insertions(+), 45 deletions(-)
diff --git a/bsps/sparc/leon3/include/bsp/leon3.h b/bsps/sparc/leon3/include/bsp/leon3.h
index 990628db7a..d1fad2dd19 100644
--- a/bsps/sparc/leon3/include/bsp/leon3.h
+++ b/bsps/sparc/leon3/include/bsp/leon3.h
@@ -41,6 +41,8 @@
 #include <grlib/irqamp-regs.h>
 #include <grlib/io.h>
+#include <grlib/ambapp.h>
 struct ambapp_dev;
 #ifdef __cplusplus
@@ -231,6 +233,76 @@ static inline uint32_t bsp_irq_fixup( uint32_t irq )
   return eirq;
+ * @brief Gets the LEON up-counter low register (%ASR23) value.
+ * @return Returns the register value.
+static inline uint32_t leon3_up_counter_low( void )
+  uint32_t asr23;
+  __asm__ volatile (
+    "mov %%asr23, %0"
+    : "=&r" (asr23)
+  return asr23;
+ * @brief Gets the LEON up-counter high register (%ASR22) value.
+static inline uint32_t leon3_up_counter_high(void)
+  uint32_t asr22;
+    "mov %%asr22, %0"
+    : "=&r" (asr22)
+  return asr22;
+ * @brief Enables the LEON up-counter.
+static inline void leon3_up_counter_enable( void )
+    "mov %g0, %asr22"
+ * @brief Checks if the LEON up-counter is available.
+ * The LEON up-counter must have been enabled.
+ * @return Returns true, if the LEON up-counter is available, otherwise false.
+static inline bool leon3_up_counter_is_available( void )
+  return leon3_up_counter_low() != leon3_up_counter_low();
+ * @brief Gets the LEON up-counter frequency in Hz.
+ * @return Returns the frequency.
+static inline uint32_t leon3_up_counter_frequency( void )
+   * For simplicity, assume that the interrupt controller uses the processor
+   * clock.  This is at least true on the GR740.
+  return ambapp_freq_get( ambapp_plb(), LEON3_IrqCtrl_Adev );
  * @brief This pointer provides the debug APBUART register block address.
diff --git a/bsps/sparc/leon3/include/leon.h b/bsps/sparc/leon3/include/leon.h
index 2856f71816..6fe499989d 100644
--- a/bsps/sparc/leon3/include/leon.h
+++ b/bsps/sparc/leon3/include/leon.h
@@ -379,51 +379,6 @@ extern unsigned int leon3_timer_prescaler;
 RTEMS_NO_RETURN void leon3_power_down_loop(void);
-static inline uint32_t leon3_up_counter_low(void)
-  uint32_t asr23;
-  __asm__ volatile (
-    "mov %%asr23, %0"
-    : "=&r" (asr23)
-  return asr23;
-static inline uint32_t leon3_up_counter_high(void)
-  uint32_t asr22;
-    "mov %%asr22, %0"
-    : "=&r" (asr22)
-  return asr22;
-static inline void leon3_up_counter_enable(void)
-    "mov %g0, %asr22"
-static inline bool leon3_up_counter_is_available(void)
-  return leon3_up_counter_low() != leon3_up_counter_low();
-static inline uint32_t leon3_up_counter_frequency(void)
-   * For simplicity, assume that the interrupt controller uses the processor
-   * clock.  This is at least true on the GR740.
-  return ambapp_freq_get(ambapp_plb(), LEON3_IrqCtrl_Adev);
 #endif /* !ASM */
 #ifdef __cplusplus
2.35.3
