[PATCH 01/34] validation: Test sparc/leon3 BSP family
Joel Sherrill
joel at rtems.org
Wed May 31 17:14:33 UTC 2023
This patch has a couple of issues.
(1) It includes modifications to arm files which doesn't seem consistent.
(2) It adds BSP specific tests. There has been on discussion of how BSP
specific
tests should be included in the tree. We have some in this category and I
am pretty
sure Chris has some as well. We need to have a consistent approach to where
they
go.
--joel
On Wed, May 31, 2023 at 11:31 AM Sebastian Huber <
> spec/build/bsps/arm/imxrt/bspimxrt1052.yml | 2 +-
> spec/build/bsps/arm/imxrt/grp.yml | 2 +-
> spec/build/bsps/arm/imxrt/obj-mimxrt1052.yml | 2 +-
> .../bsps/arm/imxrt/obj-mimxrt1166-cm4.yml | 2 +-
> .../bsps/arm/imxrt/obj-mimxrt1166-cm7.yml | 2 +-
> spec/build/bsps/arm/imxrt/obj.yml | 2 +-
> .../bsps/arm/imxrt/optmemocramorigin.yml | 2 +-
> spec/build/bsps/arm/imxrt/optvariant.yml | 2 +-
> .../validation/bsp-sparc-leon3-gr712rc.yml | 21 ++
> ...arc-leon3-cache-snooping-disabled-boot.yml | 24 ++
> ...eon3-cache-snooping-disabled-secondary.yml | 25 +++
> ...l-bsp-sparc-leon3-clock-initialization.yml | 21 ++
> .../fatal-bsp-sparc-leon3-shutdown.yml | 24 ++
> spec/build/testsuites/validation/grp.yml | 10 +
> .../validation/tc-bsp-sparc-leon3-gr712rc.c | 124 ++++++++++
> .../tc-fatal-bsp-sparc-leon3-shutdown.c | 211 ++++++++++++++++++
> ...sparc-leon3-cache-snooping-disabled-boot.c | 175 +++++++++++++++
> ...sparc-leon3-cache-snooping-disabled-boot.h | 84 +++++++
> ...-leon3-cache-snooping-disabled-secondary.c | 176 +++++++++++++++
> ...-leon3-cache-snooping-disabled-secondary.h | 84 +++++++
> ...tal-bsp-sparc-leon3-clock-initialization.c | 190 ++++++++++++++++
> ...tal-bsp-sparc-leon3-clock-initialization.h | 84 +++++++
> .../validation/ts-bsp-sparc-leon3-gr712rc.c | 72 ++++++
> ...sparc-leon3-cache-snooping-disabled-boot.c | 79 +++++++
> ...-leon3-cache-snooping-disabled-secondary.c | 82 +++++++
> ...tal-bsp-sparc-leon3-clock-initialization.c | 79 +++++++
> ...-fatal-bsp-sparc-leon3-shutdown-response.c | 94 ++++++++
> .../ts-fatal-bsp-sparc-leon3-shutdown.c | 170 ++++++++++++++
> 28 files changed, 1837 insertions(+), 8 deletions(-)
> create mode 100644
> spec/build/testsuites/validation/bsp-sparc-leon3-gr712rc.yml
> create mode 100644
> spec/build/testsuites/validation/fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.yml
> create mode 100644
> spec/build/testsuites/validation/fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.yml
> create mode 100644
> spec/build/testsuites/validation/fatal-bsp-sparc-leon3-clock-initialization.yml
> create mode 100644
> spec/build/testsuites/validation/fatal-bsp-sparc-leon3-shutdown.yml
> create mode 100644 testsuites/validation/tc-bsp-sparc-leon3-gr712rc.c
> create mode 100644
> testsuites/validation/tc-fatal-bsp-sparc-leon3-shutdown.c
> create mode 100644
> testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.c
> create mode 100644
> testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.h
> create mode 100644
> testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.c
> create mode 100644
> testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.h
> create mode 100644
> testsuites/validation/tr-fatal-bsp-sparc-leon3-clock-initialization.c
> create mode 100644
> testsuites/validation/tr-fatal-bsp-sparc-leon3-clock-initialization.h
> create mode 100644 testsuites/validation/ts-bsp-sparc-leon3-gr712rc.c
> create mode 100644
> testsuites/validation/ts-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.c
> create mode 100644
> testsuites/validation/ts-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.c
> create mode 100644
> testsuites/validation/ts-fatal-bsp-sparc-leon3-clock-initialization.c
> create mode 100644
> testsuites/validation/ts-fatal-bsp-sparc-leon3-shutdown-response.c
> create mode 100644
> testsuites/validation/ts-fatal-bsp-sparc-leon3-shutdown.c
> diff --git a/spec/build/bsps/arm/imxrt/bspimxrt1052.yml
> b/spec/build/bsps/arm/imxrt/bspimxrt1052.yml
> index 6c2b3339f9..4bcb5801be 100644
> --- a/spec/build/bsps/arm/imxrt/bspimxrt1052.yml
> +++ b/spec/build/bsps/arm/imxrt/bspimxrt1052.yml
> @@ -4,7 +4,7 @@ bsp: imxrt1052
> build-type: bsp
> cflags: []
> copyrights:
> -- Copyright (C) 2020-2023 embedded brains GmbH (
> http://www.embedded-brains.de)
> +- Copyright (C) 2020-2023 embedded brains GmbH & Co. KG
> cppflags: []
> enabled-by: true
> family: imxrt
> diff --git a/spec/build/bsps/arm/imxrt/grp.yml
> b/spec/build/bsps/arm/imxrt/grp.yml
> index feda472401..52f281c90a 100644
> --- a/spec/build/bsps/arm/imxrt/grp.yml
> +++ b/spec/build/bsps/arm/imxrt/grp.yml
> @@ -2,7 +2,7 @@ SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> build-type: group
> cflags: []
> copyrights:
> cppflags: []
> cxxflags: []
> enabled-by: true
> diff --git a/spec/build/bsps/arm/imxrt/obj-mimxrt1052.yml
> b/spec/build/bsps/arm/imxrt/obj-mimxrt1052.yml
> index 7b7c9d450c..012e41b0f1 100644
> --- a/spec/build/bsps/arm/imxrt/obj-mimxrt1052.yml
> +++ b/spec/build/bsps/arm/imxrt/obj-mimxrt1052.yml
> build-type: objects
> cflags: []
> copyrights:
> -- Copyright (C) 2023 embedded brains GmbH (http://www.embedded-brains.de)
> +- Copyright (C) 2023 embedded brains GmbH & Co. KG
> cppflags: []
> cxxflags: []
> enabled-by: true
> diff --git a/spec/build/bsps/arm/imxrt/obj-mimxrt1166-cm4.yml
> b/spec/build/bsps/arm/imxrt/obj-mimxrt1166-cm4.yml
> index bd6934be87..b338b2bedc 100644
> --- a/spec/build/bsps/arm/imxrt/obj-mimxrt1166-cm4.yml
> +++ b/spec/build/bsps/arm/imxrt/obj-mimxrt1166-cm4.yml
> build-type: objects
> cflags: []
> copyrights:
> cppflags: []
> cxxflags: []
> enabled-by: true
> diff --git a/spec/build/bsps/arm/imxrt/obj-mimxrt1166-cm7.yml
> b/spec/build/bsps/arm/imxrt/obj-mimxrt1166-cm7.yml
> index dcc664dd41..d37341117d 100644
> --- a/spec/build/bsps/arm/imxrt/obj-mimxrt1166-cm7.yml
> +++ b/spec/build/bsps/arm/imxrt/obj-mimxrt1166-cm7.yml
> build-type: objects
> cflags: []
> copyrights:
> cppflags: []
> cxxflags: []
> enabled-by: true
> diff --git a/spec/build/bsps/arm/imxrt/obj.yml
> b/spec/build/bsps/arm/imxrt/obj.yml
> index 85cb350dd2..57dd91d86e 100644
> --- a/spec/build/bsps/arm/imxrt/obj.yml
> +++ b/spec/build/bsps/arm/imxrt/obj.yml
> build-type: objects
> cflags: []
> copyrights:
> enabled-by: true
> cppflags: []
> cxxflags: []
> diff --git a/spec/build/bsps/arm/imxrt/optmemocramorigin.yml
> b/spec/build/bsps/arm/imxrt/optmemocramorigin.yml
> index c3d08918a7..359f47d933 100644
> --- a/spec/build/bsps/arm/imxrt/optmemocramorigin.yml
> +++ b/spec/build/bsps/arm/imxrt/optmemocramorigin.yml
> @@ -4,7 +4,7 @@ actions:
> - env-assign: null
> build-type: option
> copyrights:
> default:
> - enabled-by: true
> value: 0x20200000
> diff --git a/spec/build/bsps/arm/imxrt/optvariant.yml
> b/spec/build/bsps/arm/imxrt/optvariant.yml
> index 3f15034387..1d18b2869e 100644
> --- a/spec/build/bsps/arm/imxrt/optvariant.yml
> +++ b/spec/build/bsps/arm/imxrt/optvariant.yml
> @@ -101,4 +101,4 @@ description: |
> MIMXRT1166DVM6A_cm7.
> type: build
> copyrights:
> -- Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
> +- Copyright (C) 2021 embedded brains GmbH & Co. KG
> diff --git a/spec/build/testsuites/validation/bsp-sparc-leon3-gr712rc.yml
> b/spec/build/testsuites/validation/bsp-sparc-leon3-gr712rc.yml
> new file mode 100644
> index 0000000000..d0924c9fb0
> --- /dev/null
> +++ b/spec/build/testsuites/validation/bsp-sparc-leon3-gr712rc.yml
> @@ -0,0 +1,21 @@
> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
> +build-type: test-program
> +cflags: []
> +copyrights:
> +cppflags: []
> +cxxflags: []
> +enabled-by: sparc/gr712rc
> +features: c cprogram
> +includes: []
> +ldflags: []
> +links: []
> +source:
> +- testsuites/validation/tc-bsp-sparc-leon3-gr712rc.c
> +- testsuites/validation/ts-bsp-sparc-leon3-gr712rc.c
> +stlib: []
> +target: testsuites/validation/ts-bsp-sparc-leon3-gr712rc.exe
> +type: build
> +use-after:
> +- validation
> +use-before: []
> diff --git
> a/spec/build/testsuites/validation/fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.yml
> b/spec/build/testsuites/validation/fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.yml
> index 0000000000..21543b96b3
> --- /dev/null
> @@ -0,0 +1,24 @@
> +cflags: []
> +copyrights:
> +cppflags: []
> +cxxflags: []
> +enabled-by:
> + and:
> + - RTEMS_SMP
> + - bsps/sparc/leon3
> +includes: []
> +ldflags: []
> +links: []
> +source:
> +stlib: []
> +target:
> testsuites/validation/ts-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.exe
> +type: build
> +use-after:
> +- validation
> +use-before: []
> diff --git
> a/spec/build/testsuites/validation/fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.yml
> b/spec/build/testsuites/validation/fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.yml
> index 0000000000..8b3259ee88
> --- /dev/null
> @@ -0,0 +1,25 @@
> +cflags: []
> +copyrights:
> +cppflags: []
> +cxxflags: []
> +enabled-by:
> + and:
> + - RTEMS_SMP
> +includes: []
> +ldflags:
> +- -Wl,--wrap=bsp_start_on_secondary_processor
> +links: []
> +source:
> +stlib: []
> +target:
> testsuites/validation/ts-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.exe
> +type: build
> +use-after:
> +- validation
> +use-before: []
> diff --git
> a/spec/build/testsuites/validation/fatal-bsp-sparc-leon3-clock-initialization.yml
> b/spec/build/testsuites/validation/fatal-bsp-sparc-leon3-clock-initialization.yml
> index 0000000000..657dde00af
> --- /dev/null
> @@ -0,0 +1,21 @@
> +cflags: []
> +copyrights:
> +cppflags: []
> +cxxflags: []
> +enabled-by: bsps/sparc/leon3
> +includes: []
> +ldflags: []
> +links: []
> +source:
> +- testsuites/validation/tr-fatal-bsp-sparc-leon3-clock-initialization.c
> +- testsuites/validation/ts-fatal-bsp-sparc-leon3-clock-initialization.c
> +stlib: []
> +target:
> testsuites/validation/ts-fatal-bsp-sparc-leon3-clock-initialization.exe
> +type: build
> +use-after:
> +- validation
> +use-before: []
> diff --git
> a/spec/build/testsuites/validation/fatal-bsp-sparc-leon3-shutdown.yml
> b/spec/build/testsuites/validation/fatal-bsp-sparc-leon3-shutdown.yml
> index 0000000000..fff8a48f9c
> --- /dev/null
> +++ b/spec/build/testsuites/validation/fatal-bsp-sparc-leon3-shutdown.yml
> @@ -0,0 +1,24 @@
> +cflags: []
> +copyrights:
> +- Copyright (C) 2022 embedded brains GmbH & Co. KG
> +cppflags: []
> +cxxflags: []
> +enabled-by:
> + and:
> + - RTEMS_SMP
> +includes: []
> +ldflags: []
> +links: []
> +source:
> +- testsuites/validation/tc-fatal-bsp-sparc-leon3-shutdown.c
> +- testsuites/validation/ts-fatal-bsp-sparc-leon3-shutdown.c
> +stlib: []
> +target: testsuites/validation/ts-fatal-bsp-sparc-leon3-shutdown.exe
> +type: build
> +use-after:
> +- validation
> +use-before: []
> diff --git a/spec/build/testsuites/validation/grp.yml
> b/spec/build/testsuites/validation/grp.yml
> index 9aa9daff44..2c4b4f4b03 100644
> --- a/spec/build/testsuites/validation/grp.yml
> +++ b/spec/build/testsuites/validation/grp.yml
> @@ -15,8 +15,18 @@ ldflags: []
> links:
> - role: build-dependency
> uid: libvalidation
> +- role: build-dependency
> + uid: bsp-sparc-leon3-gr712rc
> uid: fatal-boot-processor-not-assigned-to-scheduler
> + uid: fatal-bsp-sparc-leon3-cache-snooping-disabled-boot
> + uid: fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary
> + uid: fatal-bsp-sparc-leon3-clock-initialization
> + uid: fatal-bsp-sparc-leon3-shutdown
> uid: fatal-idle-thread-create-failed
> diff --git a/testsuites/validation/tc-bsp-sparc-leon3-gr712rc.c
> b/testsuites/validation/tc-bsp-sparc-leon3-gr712rc.c
> index 0000000000..50629443c5
> --- /dev/null
> +++ b/testsuites/validation/tc-bsp-sparc-leon3-gr712rc.c
> @@ -0,0 +1,124 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup BspSparcLeon3ValGr712rc
> + * Copyright (C) 2021 embedded brains GmbH & Co. KG
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + * notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + * notice, this list of conditions and the following disclaimer in the
> + * documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> + * POSSIBILITY OF SUCH DAMAGE.
> + * This file is part of the RTEMS quality process and was automatically
> + * generated. If you find something that needs to be fixed or
> + * worded better please post a report or patch to an RTEMS mailing list
> + * or raise a bug report:
> + * https://www.rtems.org/bugs.html
> + * For information on updating and regenerating please refer to the How-To
> + * section in the Software Requirements Engineering chapter of the
> + * RTEMS Software Engineering manual. The manual is provided as a part of
> + * a release. For development sources please refer to the online
> + * documentation at:
> + * https://docs.rtems.org
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <bsp.h>
> +#include "tx-support.h"
> +#include <rtems/test.h>
> + * @defgroup BspSparcLeon3ValGr712rc spec:/bsp/sparc/leon3/val/gr712rc
> + * @ingroup TestsuitesBspSparcLeon3Gr712rc
> + * @brief This test case collection provides validation test cases for the
> + * ``sparc/gr712rc`` BSP.
> + * This test case performs the following actions:
> + * - Validate the use of the ``-mfix-gr712rc`` compiler option.
> + * - Check that the compiler built-in define ``__FIX_LEON3FT_B2BST`` is
> + * defined.
> + * - Check that the compiler built-in define ``__FIX_LEON3FT_TN0018`` is
> + * defined.
> + * - Check that the ``SPARC_LEON3FT_B2BST_NOP`` define expands to a
> ``nop``
> + * instruction.
> + * @brief Validate the use of the ``-mfix-gr712rc`` compiler option.
> +static void BspSparcLeon3ValGr712rc_Action_0( void )
> + const char *s;
> + * Check that the compiler built-in define ``__FIX_LEON3FT_B2BST`` is
> + * defined.
> + #if !defined(__FIX_LEON3FT_B2BST)
> + #error "__FIX_LEON3FT_B2BST is not defined"
> + #endif
> + * Check that the compiler built-in define ``__FIX_LEON3FT_TN0018`` is
> + * defined.
> + #if !defined(__FIX_LEON3FT_TN0018)
> + #error "__FIX_LEON3FT_TN0018 is not defined"
> + #endif
> + * Check that the ``SPARC_LEON3FT_B2BST_NOP`` define expands to a
> ``nop``
> + * instruction.
> + s = RTEMS_XSTRING( SPARC_LEON3FT_B2BST_NOP );
> + T_true( IsEqualIgnoreWhiteSpace( s, "nop" ) );
> + * @fn void T_case_body_BspSparcLeon3ValGr712rc( void )
> +T_TEST_CASE( BspSparcLeon3ValGr712rc )
> + BspSparcLeon3ValGr712rc_Action_0();
> diff --git a/testsuites/validation/tc-fatal-bsp-sparc-leon3-shutdown.c
> b/testsuites/validation/tc-fatal-bsp-sparc-leon3-shutdown.c
> index 0000000000..3da1360129
> --- /dev/null
> +++ b/testsuites/validation/tc-fatal-bsp-sparc-leon3-shutdown.c
> @@ -0,0 +1,211 @@
> + * @file
> + * @ingroup BspSparcLeon3ValFatalShutdown
> + * Copyright (C) 2021, 2022 embedded brains GmbH & Co. KG
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#endif
> +#include <bsp/leon3.h>
> +#include <rtems/sysinit.h>
> +#include <rtems/score/smpimpl.h>
> + * @defgroup BspSparcLeon3ValFatalShutdown \
> + * spec:/bsp/sparc/leon3/val/fatal-shutdown
> + * @ingroup TestsuitesFatalBspSparcLeon3Shutdown
> + * @brief Tests the leon3 BSP family shutdown procedure.
> + * - Check the effects of the leon3 BSP family shutdown procedure.
> + * - Check that the second processor was not powered down during system
> + * initialization.
> + * - Wait until the second processor is powered down.
> + * - Check that the RTEMS_FATAL_SOURCE_SMP with
> SMP_FATAL_SHUTDOWN_RESPONSE
> + * fatal error occurred exactly once.
> + * fatal error occurred on the second processor.
> + * - Check that no dynamic fatal error extension was invoked. This
> shows
> + * that the leon3 BSP family shutdown procedure called the wrapped
> + * _CPU_Fatal_halt() function of the test suite.
> +static uint32_t mpstat_during_sysinit;
> +static Atomic_Uint shutdown_response_counter;
> +static uint32_t shutdown_response_cpu_index = UINT32_MAX;
> +static Atomic_Uint dynamic_fatal_extension_counter;
> +static rtems_status_code status;
> +static unsigned int Add( Atomic_Uint *a, unsigned int b )
> + return _Atomic_Fetch_add_uint( a, b, ATOMIC_ORDER_RELAXED );
> +static void ShutdownFatalHandler(
> + rtems_fatal_source source,
> + rtems_fatal_code code,
> + void *arg
> + T_null( arg );
> + if (
> + source == RTEMS_FATAL_SOURCE_SMP &&
> + code == SMP_FATAL_SHUTDOWN_RESPONSE
> + (void) Add( &shutdown_response_counter, 1 );
> + shutdown_response_cpu_index = rtems_scheduler_get_processor();
> +static void DynamicFatalHandler(
> + bool always_set_to_false,
> + (void) source;
> + (void) code;
> + (void) always_set_to_false;
> + (void) Add( &dynamic_fatal_extension_counter, 1 );
> +static void InitTestCase( void )
> + rtems_extensions_table table = { .fatal = DynamicFatalHandler };
> + irqamp *regs;
> + rtems_id id;
> + regs = LEON3_IrqCtrl_Regs;
> + mpstat_during_sysinit = grlib_load_32( ®s->mpstat );
> + SetFatalHandler( ShutdownFatalHandler, NULL );
> + status = rtems_extension_create( OBJECT_NAME, &table, &id );
> +RTEMS_SYSINIT_ITEM(
> + InitTestCase,
> + RTEMS_SYSINIT_DEVICE_DRIVERS,
> + RTEMS_SYSINIT_ORDER_MIDDLE
> + * @brief Check the effects of the leon3 BSP family shutdown procedure.
> +static void BspSparcLeon3ValFatalShutdown_Action_0( void )
> + irqamp *regs;
> + uint32_t counter;
> + * Check that the second processor was not powered down during system
> + * initialization.
> + T_step_eq_u32( 0, mpstat_during_sysinit & 0x2, 0 );
> + * Wait until the second processor is powered down.
> + while ( ( grlib_load_32( ®s->mpstat ) & 0x2 ) != 0x2U ) {
> + /* Wait */
> + * Check that the RTEMS_FATAL_SOURCE_SMP with
> + counter = Add( &shutdown_response_counter, 0 );
> + T_step_eq_uint( 1, counter, 1 );
> + T_step_eq_u32( 2, shutdown_response_cpu_index, 1 );
> + * Check that no dynamic fatal error extension was invoked. This shows
> that
> + * the leon3 BSP family shutdown procedure called the wrapped
> + T_step_rsc_success( 3, status );
> + counter = Add( &dynamic_fatal_extension_counter, 0 );
> + T_step_eq_u32( 4, dynamic_fatal_extension_counter, 0 );
> + * @fn void T_case_body_BspSparcLeon3ValFatalShutdown( void )
> +T_TEST_CASE( BspSparcLeon3ValFatalShutdown )
> + T_plan( 5 );
> + BspSparcLeon3ValFatalShutdown_Action_0();
> diff --git
> a/testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.c
> b/testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.c
> index 0000000000..dafe47eb91
> --- /dev/null
> @@ -0,0 +1,175 @@
> + * @file
> + * @ingroup BspSparcLeon3ValFatalCacheSnoopingDisabledBoot
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#endif
> +#include <bsp/fatal.h>
> +#include "tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.h"
> + * @defgroup BspSparcLeon3ValFatalCacheSnoopingDisabledBoot \
> + * spec:/bsp/sparc/leon3/val/fatal-cache-snooping-disabled-boot
> + * @ingroup TestsuitesFatalBspSparcLeon3CacheSnoopingDisabledBoot
> + * @brief Tests a fatal error.
> + * - The test action is carried out by the DisableCacheSnooping() system
> + * initialization handler.
> + * - Check that the expected fatal source is present.
> + * - Check that the expected fatal code is present.
> + * @brief Test context for
> + * spec:/bsp/sparc/leon3/val/fatal-cache-snooping-disabled-boot test
> case.
> +typedef struct {
> + * @brief This member contains a copy of the corresponding
> + * BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Run() parameter.
> + rtems_fatal_source source;
> + rtems_fatal_code code;
> +} BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Context;
> +static BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Context
> + BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Instance;
> +static void DisableCacheSnooping( void )
> + uint32_t control;
> + control = leon3_get_cache_control_register();
> + control &= ~LEON3_REG_CACHE_CTRL_DS;
> + leon3_set_cache_control_register( control );
> + DisableCacheSnooping,
> + RTEMS_SYSINIT_BSP_EARLY,
> + RTEMS_SYSINIT_ORDER_FIRST
> +static T_fixture BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Fixture =
> + .setup = NULL,
> + .stop = NULL,
> + .teardown = NULL,
> + .scope = NULL,
> + .initial_context =
> &BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Instance
> + * @brief The test action is carried out by the DisableCacheSnooping()
> system
> +static void BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Action_0(
> + BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Context *ctx
> + /* Nothing to do */
> + * Check that the expected fatal source is present.
> + T_step_eq_int( 0, ctx->source, RTEMS_FATAL_SOURCE_BSP );
> + * Check that the expected fatal code is present.
> + T_step_eq_ulong(
> + 1,
> + ctx->code,
> + LEON3_FATAL_INVALID_CACHE_CONFIG_BOOT_PROCESSOR
> +void BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Run(
> + BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Context *ctx;
> + ctx = &BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Instance;
> + ctx->source = source;
> + ctx->code = code;
> + ctx = T_case_begin(
> + "BspSparcLeon3ValFatalCacheSnoopingDisabledBoot",
> + &BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Fixture
> + T_plan( 2 );
> + BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Action_0( ctx );
> + T_case_end();
> diff --git
> a/testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.h
> b/testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.h
> index 0000000000..b3fd1e10cb
> --- /dev/null
> @@ -0,0 +1,84 @@
> + * @file
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#ifndef _TR_FATAL_BSP_SPARC_LEON3_CACHE_SNOOPING_DISABLED_BOOT_H
> +#define _TR_FATAL_BSP_SPARC_LEON3_CACHE_SNOOPING_DISABLED_BOOT_H
> +#include <rtems.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> + * @addtogroup BspSparcLeon3ValFatalCacheSnoopingDisabledBoot
> + * @brief Runs the parameterized test case.
> + * @param source is fatal source.
> + * @param code is fatal code.
> +#ifdef __cplusplus
> +#endif
> +#endif /* _TR_FATAL_BSP_SPARC_LEON3_CACHE_SNOOPING_DISABLED_BOOT_H */
> diff --git
> a/testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.c
> b/testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.c
> index 0000000000..4b22923500
> --- /dev/null
> @@ -0,0 +1,176 @@
> + * @file
> + * @ingroup BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#endif
> +#include <bsp/bootcard.h>
> +#include "tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.h"
> + * @defgroup BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary \
> + * spec:/bsp/sparc/leon3/val/fatal-cache-snooping-disabled-secondary
> + * @ingroup TestsuitesFatalBspSparcLeon3CacheSnoopingDisabledSecondary
> + * - The test action is carried out by the wrapped
> + * bsp_start_on_secondary_processor() function.
> test
> + * case.
> +typedef struct {
> + * BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Run()
> parameter.
> parameter.
> +} BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Context;
> +static BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Context
> + BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Instance;
> +void __real_bsp_start_on_secondary_processor( struct Per_CPU_Control
> *cpu_self );
> +void __wrap_bsp_start_on_secondary_processor( struct Per_CPU_Control
> *cpu_self );
> *cpu_self )
> + uint32_t control;
> + __real_bsp_start_on_secondary_processor( cpu_self );
> +static T_fixture
> BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Fixture = {
> + .setup = NULL,
> + .stop = NULL,
> + .teardown = NULL,
> + .scope = NULL,
> &BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Instance
> + * @brief The test action is carried out by the wrapped
> +static void BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Action_0(
> + BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Context *ctx
> + T_step_eq_ulong(
> + 1,
> + ctx->code,
> + LEON3_FATAL_INVALID_CACHE_CONFIG_SECONDARY_PROCESSOR
> +void BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Run(
> + BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Context *ctx;
> + ctx = &BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Instance;
> + ctx->code = code;
> + "BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary",
> + &BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Fixture
> + T_plan( 2 );
> + BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Action_0( ctx );
> + T_case_end();
> diff --git
> a/testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.h
> b/testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.h
> index 0000000000..14412cdec7
> --- /dev/null
> @@ -0,0 +1,84 @@
> + * @file
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#ifndef _TR_FATAL_BSP_SPARC_LEON3_CACHE_SNOOPING_DISABLED_SECONDARY_H
> +#define _TR_FATAL_BSP_SPARC_LEON3_CACHE_SNOOPING_DISABLED_SECONDARY_H
> +#include <rtems.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> + * @addtogroup BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary
> +#ifdef __cplusplus
> +#endif
> +#endif /* _TR_FATAL_BSP_SPARC_LEON3_CACHE_SNOOPING_DISABLED_SECONDARY_H */
> diff --git
> a/testsuites/validation/tr-fatal-bsp-sparc-leon3-clock-initialization.c
> b/testsuites/validation/tr-fatal-bsp-sparc-leon3-clock-initialization.c
> index 0000000000..b74b283985
> --- /dev/null
> +++ b/testsuites/validation/tr-fatal-bsp-sparc-leon3-clock-initialization.c
> @@ -0,0 +1,190 @@
> + * @file
> + * @ingroup BspSparcLeon3ValFatalClockInitialization
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#endif
> +#include <rtems/irq-extension.h>
> +#include "tr-fatal-bsp-sparc-leon3-clock-initialization.h"
> + * @defgroup BspSparcLeon3ValFatalClockInitialization \
> + * spec:/bsp/sparc/leon3/val/fatal-clock-initialization
> + * @ingroup TestsuitesFatalBspSparcLeon3ClockInitialization
> + * - The test action is carried out by the OccupyClockInterrupt() system
> + * test case.
> +typedef struct {
> + * BspSparcLeon3ValFatalClockInitialization_Run() parameter.
> +} BspSparcLeon3ValFatalClockInitialization_Context;
> +static BspSparcLeon3ValFatalClockInitialization_Context
> + BspSparcLeon3ValFatalClockInitialization_Instance;
> +static void ClockInterrupt( void *arg )
> + (void) arg;
> +static rtems_interrupt_entry interrupt_entry =
> RTEMS_INTERRUPT_ENTRY_INITIALIZER(
> + ClockInterrupt,
> + NULL,
> + "Clock"
> +static void OccupyClockInterrupt( void )
> + rtems_vector_number vector;
> + vector = GPTIMER_CONFIG_IRQ_GET( grlib_load_32(
> &LEON3_Timer_Regs->config ) );
> + (void) rtems_interrupt_entry_install(
> + vector,
> + RTEMS_INTERRUPT_UNIQUE,
> + &interrupt_entry
> + OccupyClockInterrupt,
> +static T_fixture BspSparcLeon3ValFatalClockInitialization_Fixture = {
> + .setup = NULL,
> + .stop = NULL,
> + .teardown = NULL,
> + .scope = NULL,
> + .initial_context = &BspSparcLeon3ValFatalClockInitialization_Instance
> + * @brief The test action is carried out by the OccupyClockInterrupt()
> system
> +static void BspSparcLeon3ValFatalClockInitialization_Action_0(
> + BspSparcLeon3ValFatalClockInitialization_Context *ctx
> + T_step_eq_ulong(
> + 1,
> + ctx->code,
> + LEON3_FATAL_CLOCK_INITIALIZATION
> +void BspSparcLeon3ValFatalClockInitialization_Run(
> + BspSparcLeon3ValFatalClockInitialization_Context *ctx;
> + ctx = &BspSparcLeon3ValFatalClockInitialization_Instance;
> + ctx->code = code;
> + "BspSparcLeon3ValFatalClockInitialization",
> + &BspSparcLeon3ValFatalClockInitialization_Fixture
> + T_plan( 2 );
> + BspSparcLeon3ValFatalClockInitialization_Action_0( ctx );
> + T_case_end();
> diff --git
> a/testsuites/validation/tr-fatal-bsp-sparc-leon3-clock-initialization.h
> b/testsuites/validation/tr-fatal-bsp-sparc-leon3-clock-initialization.h
> index 0000000000..32289b43df
> --- /dev/null
> +++ b/testsuites/validation/tr-fatal-bsp-sparc-leon3-clock-initialization.h
> @@ -0,0 +1,84 @@
> + * @file
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#ifndef _TR_FATAL_BSP_SPARC_LEON3_CLOCK_INITIALIZATION_H
> +#define _TR_FATAL_BSP_SPARC_LEON3_CLOCK_INITIALIZATION_H
> +#include <rtems.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> + * @addtogroup BspSparcLeon3ValFatalClockInitialization
> +#ifdef __cplusplus
> +#endif
> +#endif /* _TR_FATAL_BSP_SPARC_LEON3_CLOCK_INITIALIZATION_H */
> diff --git a/testsuites/validation/ts-bsp-sparc-leon3-gr712rc.c
> b/testsuites/validation/ts-bsp-sparc-leon3-gr712rc.c
> index 0000000000..b844a7f217
> --- /dev/null
> +++ b/testsuites/validation/ts-bsp-sparc-leon3-gr712rc.c
> @@ -0,0 +1,72 @@
> + * @file
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#endif
> + * @defgroup TestsuitesBspSparcLeon3Gr712rc \
> + * spec:/testsuites/bsp-sparc-leon3-gr712rc
> + * @ingroup RTEMSTestSuitesValidation
> + * @brief This validation test suite contains BSP-specific test cases.
> +const char rtems_test_name[] = "TestsuitesBspSparcLeon3Gr712rc";
> +#include "ts-default.h"
> diff --git
> a/testsuites/validation/ts-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.c
> b/testsuites/validation/ts-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.c
> index 0000000000..a23139d7b5
> --- /dev/null
> @@ -0,0 +1,79 @@
> + * @file
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#endif
> + * @defgroup TestsuitesFatalBspSparcLeon3CacheSnoopingDisabledBoot \
> + * spec:/testsuites/fatal-bsp-sparc-leon3-cache-snooping-disabled-boot
> + * @brief This validation test suite contains a test case which triggers a
> + * fatal error during system initialization.
> "TestsuitesFatalBspSparcLeon3CacheSnoopingDisabledBoot";
> +#define FATAL_SYSINIT_RUN
> +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
> +#include "ts-fatal-sysinit.h"
> diff --git
> a/testsuites/validation/ts-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.c
> b/testsuites/validation/ts-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.c
> index 0000000000..b70c128b3d
> --- /dev/null
> @@ -0,0 +1,82 @@
> + * @file
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#endif
> + * @defgroup TestsuitesFatalBspSparcLeon3CacheSnoopingDisabledSecondary \
> spec:/testsuites/fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary
> "TestsuitesFatalBspSparcLeon3CacheSnoopingDisabledSecondary";
> +#define FATAL_SYSINIT_RUN \
> + BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Run
> +#define CONFIGURE_MAXIMUM_PROCESSORS 2
> diff --git
> a/testsuites/validation/ts-fatal-bsp-sparc-leon3-clock-initialization.c
> b/testsuites/validation/ts-fatal-bsp-sparc-leon3-clock-initialization.c
> index 0000000000..41c8ca989c
> --- /dev/null
> +++ b/testsuites/validation/ts-fatal-bsp-sparc-leon3-clock-initialization.c
> @@ -0,0 +1,79 @@
> + * @file
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#endif
> + * @defgroup TestsuitesFatalBspSparcLeon3ClockInitialization \
> + * spec:/testsuites/fatal-bsp-sparc-leon3-clock-initialization
> "TestsuitesFatalBspSparcLeon3ClockInitialization";
> +#define FATAL_SYSINIT_RUN BspSparcLeon3ValFatalClockInitialization_Run
> +#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
> diff --git
> a/testsuites/validation/ts-fatal-bsp-sparc-leon3-shutdown-response.c
> b/testsuites/validation/ts-fatal-bsp-sparc-leon3-shutdown-response.c
> index 0000000000..fe38c013f0
> --- /dev/null
> +++ b/testsuites/validation/ts-fatal-bsp-sparc-leon3-shutdown-response.c
> @@ -0,0 +1,94 @@
> + * @file
> + * @ingroup RTEMSTestSuiteTestsuitesFatalBspSparcLeon3ShutdownResponse
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#endif
> +#include "tr-fatal-bsp-sparc-leon3-shutdown-response.h"
> + * @defgroup RTEMSTestSuiteTestsuitesFatalBspSparcLeon3ShutdownResponse \
> + * spec:/testsuites/fatal-bsp-sparc-leon3-shutdown-response
> + * @brief This validation test suite contains a test case which performs a
> + * system shutdown.
> +const char rtems_test_name[] = "FatalBspSparcLeon3ShutdownResponse";
> +#define FATAL_SYSINIT_RUN BspSparcLeon3ValFatalShutdownResponse_Run
> +static void FatalSysinitExit( rtems_fatal_code exit_code )
> + if ( exit_code == 0 ) {
> + rtems_fatal( RTEMS_FATAL_SOURCE_SMP, SMP_FATAL_SHUTDOWN );
> + } else {
> + rtems_fatal( RTEMS_FATAL_SOURCE_EXIT, exit_code );
> +#define FATAL_SYSINIT_EXIT( exit_code ) FatalSysinitExit( exit_code )
> diff --git a/testsuites/validation/ts-fatal-bsp-sparc-leon3-shutdown.c
> b/testsuites/validation/ts-fatal-bsp-sparc-leon3-shutdown.c
> index 0000000000..37bf8dc20a
> --- /dev/null
> +++ b/testsuites/validation/ts-fatal-bsp-sparc-leon3-shutdown.c
> @@ -0,0 +1,170 @@
> + * @file
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#endif
> +#include <rtems.h>
> +#include <rtems/bspIo.h>
> +#include <rtems/test-info.h>
> +#include <rtems/testopts.h>
> +#include "ts-config.h"
> + * @defgroup TestsuitesFatalBspSparcLeon3Shutdown \
> + * @brief This validation test suite provides an application
> configuration to
> + * perform a shutdown.
> +const char rtems_test_name[] = "TestsuitesFatalBspSparcLeon3Shutdown";
> +static char buffer[ 512 ];
> +static const T_action actions[] = {
> + T_report_hash_sha256
> +static const T_config test_config = {
> + .name = rtems_test_name,
> + .buf = buffer,
> + .buf_size = sizeof( buffer ),
> + .putchar = rtems_put_char,
> + .verbosity = RTEMS_TEST_VERBOSITY,
> + .now = T_now_tick,
> + .allocate = T_memory_allocate,
> + .deallocate = T_memory_deallocate,
> + .action_count = T_ARRAY_SIZE( actions ),
> + .actions = actions
> +void __real__CPU_Fatal_halt( uint32_t source, CPU_Uint32ptr code );
> +void __wrap__CPU_Fatal_halt( uint32_t source, CPU_Uint32ptr code );
> + int exit_code;
> + T_register();
> + exit_code = T_main( &test_config );
> + rtems_test_end( rtems_test_name );
> +#if defined(RTEMS_GCOV_COVERAGE)
> + rtems_test_gcov_dump_info();
> +#endif
> + __real__CPU_Fatal_halt( source, code );
> +#include <rtems/score/scheduleredfsmp.h>
> +#define CONFIGURE_SCHEDULER_EDF_SMP
> +#include <rtems/scheduler.h>
> +RTEMS_SCHEDULER_EDF_SMP( a );
> +#define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
> + RTEMS_SCHEDULER_TABLE_EDF_SMP( a, TEST_SCHEDULER_A_NAME )
> +#define CONFIGURE_SCHEDULER_ASSIGNMENTS \
> + RTEMS_SCHEDULER_ASSIGN( 0, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY
> + RTEMS_SCHEDULER_ASSIGN( 0, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY )
> +#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 0
> +#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 1
> +#define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
> +#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
> +#define CONFIGURE_IDLE_TASK_STORAGE_SIZE RTEMS_MINIMUM_STACK_SIZE
> +#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
> +static void *ShutdownIdleBody( uintptr_t arg )
> + if ( rtems_scheduler_get_processor() == 0 ) {
> + rtems_test_begin( rtems_test_name, TEST_STATE );
> + return _CPU_Thread_Idle_body( arg );
> +#define CONFIGURE_IDLE_TASK_BODY ShutdownIdleBody
> +#define CONFIGURE_INITIAL_EXTENSIONS { .fatal = FatalInitialExtension }
> +#include <rtems/confdefs.h>
> 2.35.3
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230531/0f797d60/attachment-0001.htm>
