[PATCH 01/34] validation: Test sparc/leon3 BSP family
Sebastian Huber
Wed May 31 16:30:36 UTC 2023
spec/build/bsps/arm/imxrt/bspimxrt1052.yml | 2 +-
spec/build/bsps/arm/imxrt/grp.yml | 2 +-
spec/build/bsps/arm/imxrt/obj-mimxrt1052.yml | 2 +-
.../bsps/arm/imxrt/obj-mimxrt1166-cm4.yml | 2 +-
.../bsps/arm/imxrt/obj-mimxrt1166-cm7.yml | 2 +-
spec/build/bsps/arm/imxrt/obj.yml | 2 +-
.../bsps/arm/imxrt/optmemocramorigin.yml | 2 +-
spec/build/bsps/arm/imxrt/optvariant.yml | 2 +-
.../validation/bsp-sparc-leon3-gr712rc.yml | 21 ++
...arc-leon3-cache-snooping-disabled-boot.yml | 24 ++
...eon3-cache-snooping-disabled-secondary.yml | 25 +++
...l-bsp-sparc-leon3-clock-initialization.yml | 21 ++
.../fatal-bsp-sparc-leon3-shutdown.yml | 24 ++
spec/build/testsuites/validation/grp.yml | 10 +
.../validation/tc-bsp-sparc-leon3-gr712rc.c | 124 ++++++++++
.../tc-fatal-bsp-sparc-leon3-shutdown.c | 211 ++++++++++++++++++
...sparc-leon3-cache-snooping-disabled-boot.c | 175 +++++++++++++++
...sparc-leon3-cache-snooping-disabled-boot.h | 84 +++++++
...-leon3-cache-snooping-disabled-secondary.c | 176 +++++++++++++++
...-leon3-cache-snooping-disabled-secondary.h | 84 +++++++
...tal-bsp-sparc-leon3-clock-initialization.c | 190 ++++++++++++++++
...tal-bsp-sparc-leon3-clock-initialization.h | 84 +++++++
.../validation/ts-bsp-sparc-leon3-gr712rc.c | 72 ++++++
...sparc-leon3-cache-snooping-disabled-boot.c | 79 +++++++
...-leon3-cache-snooping-disabled-secondary.c | 82 +++++++
...tal-bsp-sparc-leon3-clock-initialization.c | 79 +++++++
...-fatal-bsp-sparc-leon3-shutdown-response.c | 94 ++++++++
.../ts-fatal-bsp-sparc-leon3-shutdown.c | 170 ++++++++++++++
28 files changed, 1837 insertions(+), 8 deletions(-)
create mode 100644 spec/build/testsuites/validation/bsp-sparc-leon3-gr712rc.yml
create mode 100644 spec/build/testsuites/validation/fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.yml
create mode 100644 spec/build/testsuites/validation/fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.yml
create mode 100644 spec/build/testsuites/validation/fatal-bsp-sparc-leon3-clock-initialization.yml
create mode 100644 spec/build/testsuites/validation/fatal-bsp-sparc-leon3-shutdown.yml
create mode 100644 testsuites/validation/tc-bsp-sparc-leon3-gr712rc.c
create mode 100644 testsuites/validation/tc-fatal-bsp-sparc-leon3-shutdown.c
create mode 100644 testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.c
create mode 100644 testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.h
create mode 100644 testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.c
create mode 100644 testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.h
create mode 100644 testsuites/validation/tr-fatal-bsp-sparc-leon3-clock-initialization.c
create mode 100644 testsuites/validation/tr-fatal-bsp-sparc-leon3-clock-initialization.h
create mode 100644 testsuites/validation/ts-bsp-sparc-leon3-gr712rc.c
create mode 100644 testsuites/validation/ts-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.c
create mode 100644 testsuites/validation/ts-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.c
create mode 100644 testsuites/validation/ts-fatal-bsp-sparc-leon3-clock-initialization.c
create mode 100644 testsuites/validation/ts-fatal-bsp-sparc-leon3-shutdown-response.c
create mode 100644 testsuites/validation/ts-fatal-bsp-sparc-leon3-shutdown.c
diff --git a/spec/build/bsps/arm/imxrt/bspimxrt1052.yml b/spec/build/bsps/arm/imxrt/bspimxrt1052.yml
index 6c2b3339f9..4bcb5801be 100644
--- a/spec/build/bsps/arm/imxrt/bspimxrt1052.yml
+++ b/spec/build/bsps/arm/imxrt/bspimxrt1052.yml
@@ -4,7 +4,7 @@ bsp: imxrt1052
build-type: bsp
cflags: []
copyrights:
-- Copyright (C) 2020-2023 embedded brains GmbH (http://www.embedded-brains.de)
+- Copyright (C) 2020-2023 embedded brains GmbH & Co. KG
cppflags: []
enabled-by: true
family: imxrt
diff --git a/spec/build/bsps/arm/imxrt/grp.yml b/spec/build/bsps/arm/imxrt/grp.yml
index feda472401..52f281c90a 100644
--- a/spec/build/bsps/arm/imxrt/grp.yml
+++ b/spec/build/bsps/arm/imxrt/grp.yml
@@ -2,7 +2,7 @@ SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
build-type: group
cflags: []
copyrights:
cppflags: []
cxxflags: []
enabled-by: true
diff --git a/spec/build/bsps/arm/imxrt/obj-mimxrt1052.yml b/spec/build/bsps/arm/imxrt/obj-mimxrt1052.yml
index 7b7c9d450c..012e41b0f1 100644
--- a/spec/build/bsps/arm/imxrt/obj-mimxrt1052.yml
+++ b/spec/build/bsps/arm/imxrt/obj-mimxrt1052.yml
build-type: objects
cflags: []
copyrights:
-- Copyright (C) 2023 embedded brains GmbH (http://www.embedded-brains.de)
+- Copyright (C) 2023 embedded brains GmbH & Co. KG
cppflags: []
cxxflags: []
enabled-by: true
diff --git a/spec/build/bsps/arm/imxrt/obj-mimxrt1166-cm4.yml b/spec/build/bsps/arm/imxrt/obj-mimxrt1166-cm4.yml
index bd6934be87..b338b2bedc 100644
--- a/spec/build/bsps/arm/imxrt/obj-mimxrt1166-cm4.yml
+++ b/spec/build/bsps/arm/imxrt/obj-mimxrt1166-cm4.yml
build-type: objects
cflags: []
copyrights:
cppflags: []
cxxflags: []
enabled-by: true
diff --git a/spec/build/bsps/arm/imxrt/obj-mimxrt1166-cm7.yml b/spec/build/bsps/arm/imxrt/obj-mimxrt1166-cm7.yml
index dcc664dd41..d37341117d 100644
--- a/spec/build/bsps/arm/imxrt/obj-mimxrt1166-cm7.yml
+++ b/spec/build/bsps/arm/imxrt/obj-mimxrt1166-cm7.yml
build-type: objects
cflags: []
copyrights:
cppflags: []
cxxflags: []
enabled-by: true
diff --git a/spec/build/bsps/arm/imxrt/obj.yml b/spec/build/bsps/arm/imxrt/obj.yml
index 85cb350dd2..57dd91d86e 100644
--- a/spec/build/bsps/arm/imxrt/obj.yml
+++ b/spec/build/bsps/arm/imxrt/obj.yml
build-type: objects
cflags: []
copyrights:
enabled-by: true
cppflags: []
cxxflags: []
diff --git a/spec/build/bsps/arm/imxrt/optmemocramorigin.yml b/spec/build/bsps/arm/imxrt/optmemocramorigin.yml
index c3d08918a7..359f47d933 100644
--- a/spec/build/bsps/arm/imxrt/optmemocramorigin.yml
+++ b/spec/build/bsps/arm/imxrt/optmemocramorigin.yml
@@ -4,7 +4,7 @@ actions:
- env-assign: null
build-type: option
copyrights:
default:
- enabled-by: true
value: 0x20200000
diff --git a/spec/build/bsps/arm/imxrt/optvariant.yml b/spec/build/bsps/arm/imxrt/optvariant.yml
index 3f15034387..1d18b2869e 100644
--- a/spec/build/bsps/arm/imxrt/optvariant.yml
+++ b/spec/build/bsps/arm/imxrt/optvariant.yml
@@ -101,4 +101,4 @@ description: |
MIMXRT1166DVM6A_cm7.
type: build
copyrights:
-- Copyright (C) 2021 embedded brains GmbH (http://www.embedded-brains.de)
+- Copyright (C) 2021 embedded brains GmbH & Co. KG
diff --git a/spec/build/testsuites/validation/bsp-sparc-leon3-gr712rc.yml b/spec/build/testsuites/validation/bsp-sparc-leon3-gr712rc.yml
new file mode 100644
index 0000000000..d0924c9fb0
--- /dev/null
+++ b/spec/build/testsuites/validation/bsp-sparc-leon3-gr712rc.yml
@@ -0,0 +1,21 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: sparc/gr712rc
+features: c cprogram
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/validation/tc-bsp-sparc-leon3-gr712rc.c
+- testsuites/validation/ts-bsp-sparc-leon3-gr712rc.c
+stlib: []
+target: testsuites/validation/ts-bsp-sparc-leon3-gr712rc.exe
+type: build
+use-after:
+- validation
+use-before: []
diff --git a/spec/build/testsuites/validation/fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.yml b/spec/build/testsuites/validation/fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.yml
index 0000000000..21543b96b3
--- /dev/null
+++ b/spec/build/testsuites/validation/fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.yml
@@ -0,0 +1,24 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+ and:
+ - RTEMS_SMP
+ - bsps/sparc/leon3
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.c
+- testsuites/validation/ts-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.c
+stlib: []
+target: testsuites/validation/ts-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.exe
+type: build
+use-after:
+- validation
+use-before: []
diff --git a/spec/build/testsuites/validation/fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.yml b/spec/build/testsuites/validation/fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.yml
index 0000000000..8b3259ee88
--- /dev/null
+++ b/spec/build/testsuites/validation/fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.yml
@@ -0,0 +1,25 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by:
+ and:
+ - RTEMS_SMP
+includes: []
+ldflags:
+- -Wl,--wrap=bsp_start_on_secondary_processor
+links: []
+source:
+- testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.c
+- testsuites/validation/ts-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.c
+stlib: []
+target: testsuites/validation/ts-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.exe
+type: build
+use-after:
+- validation
+use-before: []
diff --git a/spec/build/testsuites/validation/fatal-bsp-sparc-leon3-clock-initialization.yml b/spec/build/testsuites/validation/fatal-bsp-sparc-leon3-clock-initialization.yml
index 0000000000..657dde00af
--- /dev/null
+++ b/spec/build/testsuites/validation/fatal-bsp-sparc-leon3-clock-initialization.yml
@@ -0,0 +1,21 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: bsps/sparc/leon3
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/validation/tr-fatal-bsp-sparc-leon3-clock-initialization.c
+- testsuites/validation/ts-fatal-bsp-sparc-leon3-clock-initialization.c
+stlib: []
+target: testsuites/validation/ts-fatal-bsp-sparc-leon3-clock-initialization.exe
+type: build
+use-after:
+- validation
+use-before: []
diff --git a/spec/build/testsuites/validation/fatal-bsp-sparc-leon3-shutdown.yml b/spec/build/testsuites/validation/fatal-bsp-sparc-leon3-shutdown.yml
index 0000000000..fff8a48f9c
--- /dev/null
+++ b/spec/build/testsuites/validation/fatal-bsp-sparc-leon3-shutdown.yml
@@ -0,0 +1,24 @@
+cflags: []
+copyrights:
+- Copyright (C) 2022 embedded brains GmbH & Co. KG
+cppflags: []
+cxxflags: []
+enabled-by:
+ and:
+ - RTEMS_SMP
+includes: []
+ldflags: []
+links: []
+source:
+- testsuites/validation/tc-fatal-bsp-sparc-leon3-shutdown.c
+- testsuites/validation/ts-fatal-bsp-sparc-leon3-shutdown.c
+stlib: []
+target: testsuites/validation/ts-fatal-bsp-sparc-leon3-shutdown.exe
+type: build
+use-after:
+- validation
+use-before: []
diff --git a/spec/build/testsuites/validation/grp.yml b/spec/build/testsuites/validation/grp.yml
index 9aa9daff44..2c4b4f4b03 100644
--- a/spec/build/testsuites/validation/grp.yml
+++ b/spec/build/testsuites/validation/grp.yml
@@ -15,8 +15,18 @@ ldflags: []
links:
- role: build-dependency
uid: libvalidation
+- role: build-dependency
+ uid: bsp-sparc-leon3-gr712rc
uid: fatal-boot-processor-not-assigned-to-scheduler
+ uid: fatal-bsp-sparc-leon3-cache-snooping-disabled-boot
+ uid: fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary
+ uid: fatal-bsp-sparc-leon3-clock-initialization
+ uid: fatal-bsp-sparc-leon3-shutdown
uid: fatal-idle-thread-create-failed
diff --git a/testsuites/validation/tc-bsp-sparc-leon3-gr712rc.c b/testsuites/validation/tc-bsp-sparc-leon3-gr712rc.c
index 0000000000..50629443c5
--- /dev/null
+++ b/testsuites/validation/tc-bsp-sparc-leon3-gr712rc.c
@@ -0,0 +1,124 @@
+ * @file
+ * @ingroup BspSparcLeon3ValGr712rc
+ * Copyright (C) 2021 embedded brains GmbH & Co. KG
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * This file is part of the RTEMS quality process and was automatically
+ * generated. If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual. The manual is provided as a part of
+ * a release. For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <bsp.h>
+#include "tx-support.h"
+#include <rtems/test.h>
+ * @defgroup BspSparcLeon3ValGr712rc spec:/bsp/sparc/leon3/val/gr712rc
+ * @ingroup TestsuitesBspSparcLeon3Gr712rc
+ * @brief This test case collection provides validation test cases for the
+ * ``sparc/gr712rc`` BSP.
+ * This test case performs the following actions:
+ * - Validate the use of the ``-mfix-gr712rc`` compiler option.
+ * - Check that the compiler built-in define ``__FIX_LEON3FT_B2BST`` is
+ * defined.
+ * - Check that the compiler built-in define ``__FIX_LEON3FT_TN0018`` is
+ * defined.
+ * - Check that the ``SPARC_LEON3FT_B2BST_NOP`` define expands to a ``nop``
+ * instruction.
+ * @brief Validate the use of the ``-mfix-gr712rc`` compiler option.
+static void BspSparcLeon3ValGr712rc_Action_0( void )
+ const char *s;
+ * Check that the compiler built-in define ``__FIX_LEON3FT_B2BST`` is
+ * defined.
+ #if !defined(__FIX_LEON3FT_B2BST)
+ #error "__FIX_LEON3FT_B2BST is not defined"
+ #endif
+ * Check that the compiler built-in define ``__FIX_LEON3FT_TN0018`` is
+ * defined.
+ #if !defined(__FIX_LEON3FT_TN0018)
+ #error "__FIX_LEON3FT_TN0018 is not defined"
+ #endif
+ * Check that the ``SPARC_LEON3FT_B2BST_NOP`` define expands to a ``nop``
+ * instruction.
+ s = RTEMS_XSTRING( SPARC_LEON3FT_B2BST_NOP );
+ T_true( IsEqualIgnoreWhiteSpace( s, "nop" ) );
+ * @fn void T_case_body_BspSparcLeon3ValGr712rc( void )
+T_TEST_CASE( BspSparcLeon3ValGr712rc )
+ BspSparcLeon3ValGr712rc_Action_0();
diff --git a/testsuites/validation/tc-fatal-bsp-sparc-leon3-shutdown.c b/testsuites/validation/tc-fatal-bsp-sparc-leon3-shutdown.c
index 0000000000..3da1360129
--- /dev/null
+++ b/testsuites/validation/tc-fatal-bsp-sparc-leon3-shutdown.c
@@ -0,0 +1,211 @@
+ * @file
+ * @ingroup BspSparcLeon3ValFatalShutdown
+ * Copyright (C) 2021, 2022 embedded brains GmbH & Co. KG
+ * are met:
+#endif
+#include <bsp/leon3.h>
+#include <rtems/sysinit.h>
+#include <rtems/score/smpimpl.h>
+ * @defgroup BspSparcLeon3ValFatalShutdown \
+ * spec:/bsp/sparc/leon3/val/fatal-shutdown
+ * @ingroup TestsuitesFatalBspSparcLeon3Shutdown
+ * @brief Tests the leon3 BSP family shutdown procedure.
+ * - Check the effects of the leon3 BSP family shutdown procedure.
+ * - Check that the second processor was not powered down during system
+ * initialization.
+ * - Wait until the second processor is powered down.
+ * - Check that the RTEMS_FATAL_SOURCE_SMP with SMP_FATAL_SHUTDOWN_RESPONSE
+ * fatal error occurred exactly once.
+ * fatal error occurred on the second processor.
+ * - Check that no dynamic fatal error extension was invoked. This shows
+ * that the leon3 BSP family shutdown procedure called the wrapped
+ * _CPU_Fatal_halt() function of the test suite.
+static uint32_t mpstat_during_sysinit;
+static Atomic_Uint shutdown_response_counter;
+static uint32_t shutdown_response_cpu_index = UINT32_MAX;
+static Atomic_Uint dynamic_fatal_extension_counter;
+static rtems_status_code status;
+static unsigned int Add( Atomic_Uint *a, unsigned int b )
+ return _Atomic_Fetch_add_uint( a, b, ATOMIC_ORDER_RELAXED );
+static void ShutdownFatalHandler(
+ rtems_fatal_source source,
+ rtems_fatal_code code,
+ void *arg
+ T_null( arg );
+ if (
+ source == RTEMS_FATAL_SOURCE_SMP &&
+ code == SMP_FATAL_SHUTDOWN_RESPONSE
+ (void) Add( &shutdown_response_counter, 1 );
+ shutdown_response_cpu_index = rtems_scheduler_get_processor();
+static void DynamicFatalHandler(
+ bool always_set_to_false,
+ (void) source;
+ (void) code;
+ (void) always_set_to_false;
+ (void) Add( &dynamic_fatal_extension_counter, 1 );
+static void InitTestCase( void )
+ rtems_extensions_table table = { .fatal = DynamicFatalHandler };
+ irqamp *regs;
+ rtems_id id;
+ regs = LEON3_IrqCtrl_Regs;
+ mpstat_during_sysinit = grlib_load_32( ®s->mpstat );
+ SetFatalHandler( ShutdownFatalHandler, NULL );
+ status = rtems_extension_create( OBJECT_NAME, &table, &id );
+RTEMS_SYSINIT_ITEM(
+ InitTestCase,
+ RTEMS_SYSINIT_DEVICE_DRIVERS,
+ RTEMS_SYSINIT_ORDER_MIDDLE
+ * @brief Check the effects of the leon3 BSP family shutdown procedure.
+static void BspSparcLeon3ValFatalShutdown_Action_0( void )
+ irqamp *regs;
+ uint32_t counter;
+ * Check that the second processor was not powered down during system
+ * initialization.
+ T_step_eq_u32( 0, mpstat_during_sysinit & 0x2, 0 );
+ * Wait until the second processor is powered down.
+ while ( ( grlib_load_32( ®s->mpstat ) & 0x2 ) != 0x2U ) {
+ /* Wait */
+ * Check that the RTEMS_FATAL_SOURCE_SMP with SMP_FATAL_SHUTDOWN_RESPONSE
+ counter = Add( &shutdown_response_counter, 0 );
+ T_step_eq_uint( 1, counter, 1 );
+ T_step_eq_u32( 2, shutdown_response_cpu_index, 1 );
+ * Check that no dynamic fatal error extension was invoked. This shows that
+ * the leon3 BSP family shutdown procedure called the wrapped
+ T_step_rsc_success( 3, status );
+ counter = Add( &dynamic_fatal_extension_counter, 0 );
+ T_step_eq_u32( 4, dynamic_fatal_extension_counter, 0 );
+ * @fn void T_case_body_BspSparcLeon3ValFatalShutdown( void )
+T_TEST_CASE( BspSparcLeon3ValFatalShutdown )
+ T_plan( 5 );
+ BspSparcLeon3ValFatalShutdown_Action_0();
diff --git a/testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.c b/testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.c
index 0000000000..dafe47eb91
--- /dev/null
+++ b/testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.c
@@ -0,0 +1,175 @@
+ * @file
+ * @ingroup BspSparcLeon3ValFatalCacheSnoopingDisabledBoot
+ * are met:
+#endif
+#include <bsp/fatal.h>
+#include "tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.h"
+ * @defgroup BspSparcLeon3ValFatalCacheSnoopingDisabledBoot \
+ * spec:/bsp/sparc/leon3/val/fatal-cache-snooping-disabled-boot
+ * @ingroup TestsuitesFatalBspSparcLeon3CacheSnoopingDisabledBoot
+ * @brief Tests a fatal error.
+ * - The test action is carried out by the DisableCacheSnooping() system
+ * initialization handler.
+ * - Check that the expected fatal source is present.
+ * - Check that the expected fatal code is present.
+ * @brief Test context for
+ * spec:/bsp/sparc/leon3/val/fatal-cache-snooping-disabled-boot test case.
+typedef struct {
+ * @brief This member contains a copy of the corresponding
+ * BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Run() parameter.
+ rtems_fatal_source source;
+ rtems_fatal_code code;
+} BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Context;
+static BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Context
+ BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Instance;
+static void DisableCacheSnooping( void )
+ uint32_t control;
+ control = leon3_get_cache_control_register();
+ control &= ~LEON3_REG_CACHE_CTRL_DS;
+ leon3_set_cache_control_register( control );
+ DisableCacheSnooping,
+ RTEMS_SYSINIT_BSP_EARLY,
+ RTEMS_SYSINIT_ORDER_FIRST
+static T_fixture BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Fixture = {
+ .setup = NULL,
+ .stop = NULL,
+ .teardown = NULL,
+ .scope = NULL,
+ .initial_context = &BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Instance
+ * @brief The test action is carried out by the DisableCacheSnooping() system
+static void BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Action_0(
+ BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Context *ctx
+ /* Nothing to do */
+ * Check that the expected fatal source is present.
+ T_step_eq_int( 0, ctx->source, RTEMS_FATAL_SOURCE_BSP );
+ * Check that the expected fatal code is present.
+ T_step_eq_ulong(
+ 1,
+ ctx->code,
+ LEON3_FATAL_INVALID_CACHE_CONFIG_BOOT_PROCESSOR
+void BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Run(
+ BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Context *ctx;
+ ctx = &BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Instance;
+ ctx->source = source;
+ ctx->code = code;
+ ctx = T_case_begin(
+ "BspSparcLeon3ValFatalCacheSnoopingDisabledBoot",
+ &BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Fixture
+ T_plan( 2 );
+ BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Action_0( ctx );
+ T_case_end();
diff --git a/testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.h b/testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.h
index 0000000000..b3fd1e10cb
--- /dev/null
+++ b/testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.h
@@ -0,0 +1,84 @@
+ * @file
+ * are met:
+#ifndef _TR_FATAL_BSP_SPARC_LEON3_CACHE_SNOOPING_DISABLED_BOOT_H
+#define _TR_FATAL_BSP_SPARC_LEON3_CACHE_SNOOPING_DISABLED_BOOT_H
+#include <rtems.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @addtogroup BspSparcLeon3ValFatalCacheSnoopingDisabledBoot
+ * @brief Runs the parameterized test case.
+ * @param source is fatal source.
+ * @param code is fatal code.
+#ifdef __cplusplus
+#endif
+#endif /* _TR_FATAL_BSP_SPARC_LEON3_CACHE_SNOOPING_DISABLED_BOOT_H */
diff --git a/testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.c b/testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.c
index 0000000000..4b22923500
--- /dev/null
+++ b/testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.c
@@ -0,0 +1,176 @@
+ * @file
+ * @ingroup BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary
+ * are met:
+#endif
+#include <bsp/bootcard.h>
+#include "tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.h"
+ * @defgroup BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary \
+ * spec:/bsp/sparc/leon3/val/fatal-cache-snooping-disabled-secondary
+ * @ingroup TestsuitesFatalBspSparcLeon3CacheSnoopingDisabledSecondary
+ * - The test action is carried out by the wrapped
+ * bsp_start_on_secondary_processor() function.
+ * spec:/bsp/sparc/leon3/val/fatal-cache-snooping-disabled-secondary test
+ * case.
+typedef struct {
+ * BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Run() parameter.
+} BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Context;
+static BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Context
+ BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Instance;
+void __real_bsp_start_on_secondary_processor( struct Per_CPU_Control *cpu_self );
+void __wrap_bsp_start_on_secondary_processor( struct Per_CPU_Control *cpu_self );
+ uint32_t control;
+ __real_bsp_start_on_secondary_processor( cpu_self );
+static T_fixture BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Fixture = {
+ .setup = NULL,
+ .stop = NULL,
+ .teardown = NULL,
+ .scope = NULL,
+ .initial_context = &BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Instance
+ * @brief The test action is carried out by the wrapped
+static void BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Action_0(
+ BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Context *ctx
+ T_step_eq_ulong(
+ 1,
+ ctx->code,
+ LEON3_FATAL_INVALID_CACHE_CONFIG_SECONDARY_PROCESSOR
+void BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Run(
+ BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Context *ctx;
+ ctx = &BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Instance;
+ ctx->code = code;
+ "BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary",
+ &BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Fixture
+ T_plan( 2 );
+ BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Action_0( ctx );
+ T_case_end();
diff --git a/testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.h b/testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.h
index 0000000000..14412cdec7
--- /dev/null
+++ b/testsuites/validation/tr-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.h
@@ -0,0 +1,84 @@
+ * @file
+ * are met:
+#ifndef _TR_FATAL_BSP_SPARC_LEON3_CACHE_SNOOPING_DISABLED_SECONDARY_H
+#define _TR_FATAL_BSP_SPARC_LEON3_CACHE_SNOOPING_DISABLED_SECONDARY_H
+#include <rtems.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @addtogroup BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary
+#ifdef __cplusplus
+#endif
+#endif /* _TR_FATAL_BSP_SPARC_LEON3_CACHE_SNOOPING_DISABLED_SECONDARY_H */
diff --git a/testsuites/validation/tr-fatal-bsp-sparc-leon3-clock-initialization.c b/testsuites/validation/tr-fatal-bsp-sparc-leon3-clock-initialization.c
index 0000000000..b74b283985
--- /dev/null
+++ b/testsuites/validation/tr-fatal-bsp-sparc-leon3-clock-initialization.c
@@ -0,0 +1,190 @@
+ * @file
+ * @ingroup BspSparcLeon3ValFatalClockInitialization
+ * are met:
+#endif
+#include <rtems/irq-extension.h>
+#include "tr-fatal-bsp-sparc-leon3-clock-initialization.h"
+ * @defgroup BspSparcLeon3ValFatalClockInitialization \
+ * spec:/bsp/sparc/leon3/val/fatal-clock-initialization
+ * @ingroup TestsuitesFatalBspSparcLeon3ClockInitialization
+ * - The test action is carried out by the OccupyClockInterrupt() system
+ * @brief Test context for spec:/bsp/sparc/leon3/val/fatal-clock-initialization
+ * test case.
+typedef struct {
+ * BspSparcLeon3ValFatalClockInitialization_Run() parameter.
+} BspSparcLeon3ValFatalClockInitialization_Context;
+static BspSparcLeon3ValFatalClockInitialization_Context
+ BspSparcLeon3ValFatalClockInitialization_Instance;
+static void ClockInterrupt( void *arg )
+ (void) arg;
+static rtems_interrupt_entry interrupt_entry = RTEMS_INTERRUPT_ENTRY_INITIALIZER(
+ ClockInterrupt,
+ NULL,
+ "Clock"
+static void OccupyClockInterrupt( void )
+ rtems_vector_number vector;
+ vector = GPTIMER_CONFIG_IRQ_GET( grlib_load_32( &LEON3_Timer_Regs->config ) );
+ (void) rtems_interrupt_entry_install(
+ vector,
+ RTEMS_INTERRUPT_UNIQUE,
+ &interrupt_entry
+ OccupyClockInterrupt,
+static T_fixture BspSparcLeon3ValFatalClockInitialization_Fixture = {
+ .setup = NULL,
+ .stop = NULL,
+ .teardown = NULL,
+ .scope = NULL,
+ .initial_context = &BspSparcLeon3ValFatalClockInitialization_Instance
+ * @brief The test action is carried out by the OccupyClockInterrupt() system
+static void BspSparcLeon3ValFatalClockInitialization_Action_0(
+ BspSparcLeon3ValFatalClockInitialization_Context *ctx
+ T_step_eq_ulong(
+ 1,
+ ctx->code,
+ LEON3_FATAL_CLOCK_INITIALIZATION
+void BspSparcLeon3ValFatalClockInitialization_Run(
+ BspSparcLeon3ValFatalClockInitialization_Context *ctx;
+ ctx = &BspSparcLeon3ValFatalClockInitialization_Instance;
+ ctx->code = code;
+ "BspSparcLeon3ValFatalClockInitialization",
+ &BspSparcLeon3ValFatalClockInitialization_Fixture
+ T_plan( 2 );
+ BspSparcLeon3ValFatalClockInitialization_Action_0( ctx );
+ T_case_end();
diff --git a/testsuites/validation/tr-fatal-bsp-sparc-leon3-clock-initialization.h b/testsuites/validation/tr-fatal-bsp-sparc-leon3-clock-initialization.h
index 0000000000..32289b43df
--- /dev/null
+++ b/testsuites/validation/tr-fatal-bsp-sparc-leon3-clock-initialization.h
@@ -0,0 +1,84 @@
+ * @file
+ * are met:
+#ifndef _TR_FATAL_BSP_SPARC_LEON3_CLOCK_INITIALIZATION_H
+#define _TR_FATAL_BSP_SPARC_LEON3_CLOCK_INITIALIZATION_H
+#include <rtems.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @addtogroup BspSparcLeon3ValFatalClockInitialization
+#ifdef __cplusplus
+#endif
+#endif /* _TR_FATAL_BSP_SPARC_LEON3_CLOCK_INITIALIZATION_H */
diff --git a/testsuites/validation/ts-bsp-sparc-leon3-gr712rc.c b/testsuites/validation/ts-bsp-sparc-leon3-gr712rc.c
index 0000000000..b844a7f217
--- /dev/null
+++ b/testsuites/validation/ts-bsp-sparc-leon3-gr712rc.c
@@ -0,0 +1,72 @@
+ * @file
+ * are met:
+#endif
+ * @defgroup TestsuitesBspSparcLeon3Gr712rc \
+ * spec:/testsuites/bsp-sparc-leon3-gr712rc
+ * @ingroup RTEMSTestSuitesValidation
+ * @brief This validation test suite contains BSP-specific test cases.
+const char rtems_test_name[] = "TestsuitesBspSparcLeon3Gr712rc";
+#include "ts-default.h"
diff --git a/testsuites/validation/ts-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.c b/testsuites/validation/ts-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.c
index 0000000000..a23139d7b5
--- /dev/null
+++ b/testsuites/validation/ts-fatal-bsp-sparc-leon3-cache-snooping-disabled-boot.c
@@ -0,0 +1,79 @@
+ * @file
+ * are met:
+#endif
+ * @defgroup TestsuitesFatalBspSparcLeon3CacheSnoopingDisabledBoot \
+ * spec:/testsuites/fatal-bsp-sparc-leon3-cache-snooping-disabled-boot
+ * @brief This validation test suite contains a test case which triggers a
+ * fatal error during system initialization.
+const char rtems_test_name[] = "TestsuitesFatalBspSparcLeon3CacheSnoopingDisabledBoot";
+#define FATAL_SYSINIT_RUN BspSparcLeon3ValFatalCacheSnoopingDisabledBoot_Run
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#include "ts-fatal-sysinit.h"
diff --git a/testsuites/validation/ts-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.c b/testsuites/validation/ts-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.c
index 0000000000..b70c128b3d
--- /dev/null
+++ b/testsuites/validation/ts-fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary.c
@@ -0,0 +1,82 @@
+ * @file
+ * are met:
+#endif
+ * @defgroup TestsuitesFatalBspSparcLeon3CacheSnoopingDisabledSecondary \
+ * spec:/testsuites/fatal-bsp-sparc-leon3-cache-snooping-disabled-secondary
+const char rtems_test_name[] = "TestsuitesFatalBspSparcLeon3CacheSnoopingDisabledSecondary";
+#define FATAL_SYSINIT_RUN \
+ BspSparcLeon3ValFatalCacheSnoopingDisabledSecondary_Run
+#define CONFIGURE_MAXIMUM_PROCESSORS 2
diff --git a/testsuites/validation/ts-fatal-bsp-sparc-leon3-clock-initialization.c b/testsuites/validation/ts-fatal-bsp-sparc-leon3-clock-initialization.c
index 0000000000..41c8ca989c
--- /dev/null
+++ b/testsuites/validation/ts-fatal-bsp-sparc-leon3-clock-initialization.c
@@ -0,0 +1,79 @@
+ * @file
+ * are met:
+#endif
+ * @defgroup TestsuitesFatalBspSparcLeon3ClockInitialization \
+ * spec:/testsuites/fatal-bsp-sparc-leon3-clock-initialization
+const char rtems_test_name[] = "TestsuitesFatalBspSparcLeon3ClockInitialization";
+#define FATAL_SYSINIT_RUN BspSparcLeon3ValFatalClockInitialization_Run
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
diff --git a/testsuites/validation/ts-fatal-bsp-sparc-leon3-shutdown-response.c b/testsuites/validation/ts-fatal-bsp-sparc-leon3-shutdown-response.c
index 0000000000..fe38c013f0
--- /dev/null
+++ b/testsuites/validation/ts-fatal-bsp-sparc-leon3-shutdown-response.c
@@ -0,0 +1,94 @@
+ * @file
+ * @ingroup RTEMSTestSuiteTestsuitesFatalBspSparcLeon3ShutdownResponse
+ * are met:
+#endif
+#include "tr-fatal-bsp-sparc-leon3-shutdown-response.h"
+ * @defgroup RTEMSTestSuiteTestsuitesFatalBspSparcLeon3ShutdownResponse \
+ * spec:/testsuites/fatal-bsp-sparc-leon3-shutdown-response
+ * @brief This validation test suite contains a test case which performs a
+ * system shutdown.
+const char rtems_test_name[] = "FatalBspSparcLeon3ShutdownResponse";
+#define FATAL_SYSINIT_RUN BspSparcLeon3ValFatalShutdownResponse_Run
+static void FatalSysinitExit( rtems_fatal_code exit_code )
+ if ( exit_code == 0 ) {
+ rtems_fatal( RTEMS_FATAL_SOURCE_SMP, SMP_FATAL_SHUTDOWN );
+ } else {
+ rtems_fatal( RTEMS_FATAL_SOURCE_EXIT, exit_code );
+#define FATAL_SYSINIT_EXIT( exit_code ) FatalSysinitExit( exit_code )
diff --git a/testsuites/validation/ts-fatal-bsp-sparc-leon3-shutdown.c b/testsuites/validation/ts-fatal-bsp-sparc-leon3-shutdown.c
index 0000000000..37bf8dc20a
--- /dev/null
+++ b/testsuites/validation/ts-fatal-bsp-sparc-leon3-shutdown.c
@@ -0,0 +1,170 @@
+ * @file
+ * are met:
+#endif
+#include <rtems.h>
+#include <rtems/bspIo.h>
+#include <rtems/test-info.h>
+#include <rtems/testopts.h>
+#include "ts-config.h"
+ * @defgroup TestsuitesFatalBspSparcLeon3Shutdown \
+ * @brief This validation test suite provides an application configuration to
+ * perform a shutdown.
+const char rtems_test_name[] = "TestsuitesFatalBspSparcLeon3Shutdown";
+static char buffer[ 512 ];
+static const T_action actions[] = {
+ T_report_hash_sha256
+static const T_config test_config = {
+ .name = rtems_test_name,
+ .buf = buffer,
+ .buf_size = sizeof( buffer ),
+ .putchar = rtems_put_char,
+ .verbosity = RTEMS_TEST_VERBOSITY,
+ .now = T_now_tick,
+ .allocate = T_memory_allocate,
+ .deallocate = T_memory_deallocate,
+ .action_count = T_ARRAY_SIZE( actions ),
+ .actions = actions
+void __real__CPU_Fatal_halt( uint32_t source, CPU_Uint32ptr code );
+void __wrap__CPU_Fatal_halt( uint32_t source, CPU_Uint32ptr code );
+ int exit_code;
+ T_register();
+ exit_code = T_main( &test_config );
+ rtems_test_end( rtems_test_name );
+#if defined(RTEMS_GCOV_COVERAGE)
+ rtems_test_gcov_dump_info();
+#endif
+ __real__CPU_Fatal_halt( source, code );
+#include <rtems/score/scheduleredfsmp.h>
+#define CONFIGURE_SCHEDULER_EDF_SMP
+#include <rtems/scheduler.h>
+RTEMS_SCHEDULER_EDF_SMP( a );
+#define CONFIGURE_SCHEDULER_TABLE_ENTRIES \
+ RTEMS_SCHEDULER_TABLE_EDF_SMP( a, TEST_SCHEDULER_A_NAME )
+#define CONFIGURE_SCHEDULER_ASSIGNMENTS \
+ RTEMS_SCHEDULER_ASSIGN( 0, RTEMS_SCHEDULER_ASSIGN_PROCESSOR_MANDATORY ), \
+#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 0
+#define CONFIGURE_MAXIMUM_USER_EXTENSIONS 1
+#define CONFIGURE_DISABLE_NEWLIB_REENTRANCY
+#define CONFIGURE_APPLICATION_DISABLE_FILESYSTEM
+#define CONFIGURE_IDLE_TASK_STORAGE_SIZE RTEMS_MINIMUM_STACK_SIZE
+#define CONFIGURE_IDLE_TASK_INITIALIZES_APPLICATION
+static void *ShutdownIdleBody( uintptr_t arg )
+ if ( rtems_scheduler_get_processor() == 0 ) {
+ rtems_test_begin( rtems_test_name, TEST_STATE );
+ return _CPU_Thread_Idle_body( arg );
+#define CONFIGURE_IDLE_TASK_BODY ShutdownIdleBody
+#define CONFIGURE_INITIAL_EXTENSIONS { .fatal = FatalInitialExtension }
+#include <rtems/confdefs.h>
2.35.3
