[PATCH v2 1/4] bsps/clock: Import Xilinx TTC hardware definitions
Kinsey Moore kinsey.moore at oarcorp.com
Thu Oct 12 17:01:47 UTC 2023
This imports the TTC hardware definitions for the triple timer counters
on various Xilinx platforms. This was imported as specified in the
VERSION file in this commit.
 bsps/include/dev/clock/VERSION     |  24 ++++
 bsps/include/dev/clock/xttcps_hw.h | 207 +++++++++++++++++++++++++++++
 2 files changed, 231 insertions(+)
 create mode 100644 bsps/include/dev/clock/VERSION
 create mode 100644 bsps/include/dev/clock/xttcps_hw.h
diff --git a/bsps/include/dev/clock/VERSION b/bsps/include/dev/clock/VERSION
new file mode 100644
index 0000000000..1ccbe7c216
--- /dev/null
+++ b/bsps/include/dev/clock/VERSION
@@ -0,0 +1,24 @@
+The information in this file describes the source of
+bsps/include/dev/clock/xttcps_hw.h.
+Import from:
+https://github.com/Xilinx/embeddedsw.git
+commit 5330a64c8efd14f0eef09befdbb8d3d738c33ec2
+Refs: <xilinx_v2022.2>
+Author:     Nicole Baze <nicole.baze at xilinx.com>
+AuthorDate: Mon Oct 3 13:27:19 2022 -0700
+Commit:     Siva Addepalli <sivaprasad.addepalli at xilinx.com>
+CommitDate: Fri Oct 7 10:26:16 2022 +0530
+    xilpm: versal: server: Fix bug in AIE2 zeroization
+    There is a bug in AIE2 zeriozation function when polling for memory
+    zeroization complete. Currently the entire memory register is being
+    checked against zero but instead we need to check the bits specific
+    to the memory tiles. This patch updates the zeroization check by
+    adding a mask so that only the desired bits are checked for zero.
+    Signed-off-by: Nicole Baze <nicole.baze at xilinx.com>
+    Acked-by: Jesus De Haro <jesus.de-haro at xilinx.com>
diff --git a/bsps/include/dev/clock/xttcps_hw.h b/bsps/include/dev/clock/xttcps_hw.h
index 0000000000..0559c4a00c
--- /dev/null
+++ b/bsps/include/dev/clock/xttcps_hw.h
@@ -0,0 +1,207 @@
+* Copyright (C) 2010 - 2021 Xilinx, Inc.  All rights reserved.
+* SPDX-License-Identifier: MIT
+* @file xttcps_hw.h
+* @addtogroup ttcps_v3_15
+* This file defines the hardware interface to one of the three timer counters
+* in the Ps block.
+* <pre>
+* MODIFICATION HISTORY:
+* Ver   Who    Date     Changes
+* 1.00a drg/jz 01/21/10 First release
+* 3.00  kvn    02/13/15 Modified code for MISRA-C:2012 compliance.
+* 3.5   srm    10/06/17 Updated XTTCPS_COUNT_VALUE_MASK,
+*                       XTTCPS_INTERVAL_VAL_MASK, XTTCPS_MATCH_MASK macros to
+*                       mask 16 bit values for zynq and 32 bit values for
+*                       zynq ultrascale+mpsoc "
+* </pre>
+#ifndef XTTCPS_HW_H		/* prevent circular inclusions */
+#define XTTCPS_HW_H		/* by using protection macros */
+#ifdef __cplusplus
+extern "C" {
+#endif
+/***************************** Include Files *********************************/
+#include "xil_types.h"
+#include "xil_assert.h"
+#include "xil_io.h"
+/************************** Constant Definitions *****************************/
+ * Flag for a9 processor
+ #if !defined (ARMR5) && !defined (__aarch64__) && !defined (ARMA53_32)
+ #define ARMA9
+ #endif
+/** @name Register Map
+ * Register offsets from the base address of the device.
+#define XTTCPS_CLK_CNTRL_OFFSET		0x00000000U  /**< Clock Control Register */
+#define XTTCPS_CNT_CNTRL_OFFSET		0x0000000CU  /**< Counter Control Register*/
+#define XTTCPS_COUNT_VALUE_OFFSET	0x00000018U  /**< Current Counter Value */
+#define XTTCPS_INTERVAL_VAL_OFFSET	0x00000024U  /**< Interval Count Value */
+#define XTTCPS_MATCH_0_OFFSET		0x00000030U  /**< Match 1 value */
+#define XTTCPS_MATCH_1_OFFSET		0x0000003CU  /**< Match 2 value */
+#define XTTCPS_MATCH_2_OFFSET		0x00000048U  /**< Match 3 value */
+#define XTTCPS_ISR_OFFSET			0x00000054U  /**< Interrupt Status Register */
+#define XTTCPS_IER_OFFSET			0x00000060U  /**< Interrupt Enable Register */
+/** @name Clock Control Register
+ * Clock Control Register definitions
+#define XTTCPS_CLK_CNTRL_PS_EN_MASK		0x00000001U  /**< Prescale enable */
+#define XTTCPS_CLK_CNTRL_PS_VAL_MASK	0x0000001EU  /**< Prescale value */
+#define XTTCPS_CLK_CNTRL_PS_VAL_SHIFT			 1U  /**< Prescale shift */
+#define XTTCPS_CLK_CNTRL_PS_DISABLE				16U  /**< Prescale disable */
+#define XTTCPS_CLK_CNTRL_SRC_MASK		0x00000020U  /**< Clock source */
+#define XTTCPS_CLK_CNTRL_EXT_EDGE_MASK	0x00000040U  /**< External Clock edge */
+/** @name Counter Control Register
+ * Counter Control Register definitions
+#define XTTCPS_CNT_CNTRL_DIS_MASK		0x00000001U /**< Disable the counter */
+#define XTTCPS_CNT_CNTRL_INT_MASK		0x00000002U /**< Interval mode */
+#define XTTCPS_CNT_CNTRL_DECR_MASK		0x00000004U /**< Decrement mode */
+#define XTTCPS_CNT_CNTRL_MATCH_MASK		0x00000008U /**< Match mode */
+#define XTTCPS_CNT_CNTRL_RST_MASK		0x00000010U /**< Reset counter */
+#define XTTCPS_CNT_CNTRL_EN_WAVE_MASK	0x00000020U /**< Enable waveform */
+#define XTTCPS_CNT_CNTRL_POL_WAVE_MASK	0x00000040U /**< Waveform polarity */
+#define XTTCPS_CNT_CNTRL_RESET_VALUE	0x00000021U /**< Reset value */
+/** @name Current Counter Value Register
+ * Current Counter Value Register definitions
+#if defined(ARMA9)
+#define XTTCPS_COUNT_VALUE_MASK		0x0000FFFFU /**< 16-bit counter value */
+#else
+#define XTTCPS_COUNT_VALUE_MASK		0xFFFFFFFFU /**< 32-bit counter value */
+#endif
+/** @name Interval Value Register
+ * Interval Value Register is the maximum value the counter will count up or
+ * down to.
+#if defined(ARMA9)
+#define XTTCPS_INTERVAL_VAL_MASK	0x0000FFFFU /**< 16-bit Interval value*/
+#else
+#define XTTCPS_INTERVAL_VAL_MASK	0xFFFFFFFFU /**< 32-bit Interval value*/
+#endif
+/** @name Match Registers
+ * Definitions for Match registers, each timer counter has three match
+ * registers.
+#if defined(ARMA9)
+#define XTTCPS_MATCH_MASK		0x0000FFFFU /**< 16-bit Match value */
+#else
+#define XTTCPS_MATCH_MASK		0xFFFFFFFFU /**< 32-bit Match value */
+#endif
+#define XTTCPS_NUM_MATCH_REG			 3U /**< Num of Match reg */
+/** @name Interrupt Registers
+ * Following register bit mask is for all interrupt registers.
+#define XTTCPS_IXR_INTERVAL_MASK	0x00000001U  /**< Interval Interrupt */
+#define XTTCPS_IXR_MATCH_0_MASK		0x00000002U  /**< Match 1 Interrupt */
+#define XTTCPS_IXR_MATCH_1_MASK		0x00000004U  /**< Match 2 Interrupt */
+#define XTTCPS_IXR_MATCH_2_MASK		0x00000008U  /**< Match 3 Interrupt */
+#define XTTCPS_IXR_CNT_OVR_MASK		0x00000010U  /**< Counter Overflow */
+#define XTTCPS_IXR_ALL_MASK			0x0000001FU  /**< All valid Interrupts */
+/***************** Macros (Inline Functions) Definitions *********************/
+* Read the given Timer Counter register.
+* @param	BaseAddress is the base address of the timer counter device.
+* @param	RegOffset is the register offset to be read
+* @return	The 32-bit value of the register
+* @note		C-style signature:
+*		u32 XTtcPs_ReadReg(u32 BaseAddress, u32 RegOffset)
+#define XTtcPs_ReadReg(BaseAddress, RegOffset) \
+    (Xil_In32((BaseAddress) + (u32)(RegOffset)))
+* Write the given Timer Counter register.
+* @param	RegOffset is the register offset to be written
+* @param	Data is the 32-bit value to write to the register
+* @return	None.
+*		void XTtcPs_WriteReg(XTtcPs BaseAddress, u32 RegOffset,
+*		u32 Data)
+#define XTtcPs_WriteReg(BaseAddress, RegOffset, Data) \
+    (Xil_Out32((BaseAddress) + (u32)(RegOffset), (u32)(Data)))
+* Calculate a match register offset using the Match Register index.
+* @param	MatchIndex is the 0-2 value of the match register
+* @return	MATCH_N_OFFSET.
+*		u32 XTtcPs_Match_N_Offset(u8 MatchIndex)
+#define XTtcPs_Match_N_Offset(MatchIndex) \
+		((u32)XTTCPS_MATCH_0_OFFSET + ((u32)(12U) * (u32)(MatchIndex)))
+/************************** Function Prototypes ******************************/
+/************************** Variable Definitions *****************************/
+#ifdef __cplusplus
+#endif
+#endif /* end of protection macro */
2.39.2
