[PATCH v2 2/4] bsps/xil: Import Xilinx Cortex-R5 support
Kinsey Moore
kinsey.moore at oarcorp.com
Thu Oct 12 17:01:48 UTC 2023
This imports Xilinx support code for the MPU and cache on Cortex-R5
cores. This was imported as specified in bsps/shared/xil/VERSION.
bsps/include/xil/arm/cortexr5/xil_mpu.h | 117 +++++
bsps/shared/xil/arm/cortexr5/xil_cache.c | 561 ++++++++++++++++++++
bsps/shared/xil/arm/cortexr5/xil_mpu.c | 641 +++++++++++++++++++++++
3 files changed, 1319 insertions(+)
create mode 100644 bsps/include/xil/arm/cortexr5/xil_mpu.h
create mode 100644 bsps/shared/xil/arm/cortexr5/xil_cache.c
create mode 100644 bsps/shared/xil/arm/cortexr5/xil_mpu.c
diff --git a/bsps/include/xil/arm/cortexr5/xil_mpu.h b/bsps/include/xil/arm/cortexr5/xil_mpu.h
new file mode 100644
index 0000000000..af3d52d795
--- /dev/null
+++ b/bsps/include/xil/arm/cortexr5/xil_mpu.h
@@ -0,0 +1,117 @@
+* Copyright (c) 2014 - 2022 Xilinx, Inc. All rights reserved.
+* SPDX-License-Identifier: MIT
+* @file xil_mmu.h
+* @addtogroup r5_mpu_apis Cortex R5 Processor MPU specific APIs
+* MPU functions provides access to MPU operations such as enable MPU, disable
+* MPU and set attribute for section of memory.
+* Boot code invokes Init_MPU function to configure the MPU. A total of 10 MPU
+* regions are allocated with another 6 being free for users. Overview of the
+* memory attributes for different MPU regions is as given below,
+*| | Memory Range | Attributes of MPURegion |
+*| DDR | 0x00000000 - 0x7FFFFFFF | Normal write-back Cacheable |
+*| PL | 0x80000000 - 0xBFFFFFFF | Strongly Ordered |
+*| QSPI | 0xC0000000 - 0xDFFFFFFF | Device Memory |
+*| PCIe | 0xE0000000 - 0xEFFFFFFF | Device Memory |
+*| STM_CORESIGHT | 0xF8000000 - 0xF8FFFFFF | Device Memory |
+*| RPU_R5_GIC | 0xF9000000 - 0xF90FFFFF | Device memory |
+*| FPS | 0xFD000000 - 0xFDFFFFFF | Device Memory |
+*| LPS | 0xFE000000 - 0xFFFFFFFF | Device Memory |
+*| OCM | 0xFFFC0000 - 0xFFFFFFFF | Normal write-back Cacheable |
+* @note
+* For a system where DDR is less than 2GB, region after DDR and before PL is
+* marked as undefined in translation table. Memory range 0xFE000000-0xFEFFFFFF is
+* allocated for upper LPS slaves, where as memory region 0xFF000000-0xFFFFFFFF is
+* allocated for lower LPS slaves.
+* <pre>
+* MODIFICATION HISTORY:
+* Ver Who Date Changes
+* 5.00 pkp 02/10/14 Initial version
+* 6.4 asa 08/16/17 Added many APIs for MPU access to make MPU usage
+* user-friendly. The APIs added are: Xil_UpdateMPUConfig,
+* Xil_GetMPUConfig, Xil_GetNumOfFreeRegions,
+* Xil_GetNextMPURegion, Xil_DisableMPURegionByRegNum,
+* Xil_GetMPUFreeRegMask, Xil_SetMPURegionByRegNum, and
+* Xil_InitializeExistingMPURegConfig.
+* Added a new array of structure of type XMpuConfig to
+* represent the MPU configuration table.
+* 7.7 sk 01/10/22 Modify Xil_SetTlbAttributes function argument name to fix
+* misra_c_2012_rule_8_3 violation.
+* </pre>
+ *@cond nocomments
+#ifndef XIL_MPU_H
+#define XIL_MPU_H
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+#include "xil_types.h"
+/***************************** Include Files *********************************/
+/***************** Macros (Inline Functions) Definitions *********************/
+#define MPU_REG_DISABLED 0U
+#define MPU_REG_ENABLED 1U
+#define MAX_POSSIBLE_MPU_REGS 16U
+/**************************** Type Definitions *******************************/
+struct XMpuConfig{
+ u32 RegionStatus; /* Enabled or disabled */
+ INTPTR BaseAddress;/* MPU region base address */
+ u64 Size; /* MPU region size address */
+ u32 Attribute; /* MPU region size attribute */
+typedef struct XMpuConfig XMpu_Config[MAX_POSSIBLE_MPU_REGS];
+extern XMpu_Config Mpu_Config;
+/************************** Constant Definitions *****************************/
+/************************** Variable Definitions *****************************/
+/************************** Function Prototypes ******************************/
+ *@endcond
+void Xil_SetTlbAttributes(INTPTR addr, u32 attrib);
+void Xil_EnableMPU(void);
+void Xil_DisableMPU(void);
+u32 Xil_SetMPURegion(INTPTR addr, u64 size, u32 attrib);
+u32 Xil_UpdateMPUConfig(u32 reg_num, INTPTR address, u32 size, u32 attrib);
+void Xil_GetMPUConfig (XMpu_Config mpuconfig);
+u32 Xil_GetNumOfFreeRegions (void);
+u32 Xil_GetNextMPURegion(void);
+u32 Xil_DisableMPURegionByRegNum (u32 reg_num);
+u16 Xil_GetMPUFreeRegMask (void);
+u32 Xil_SetMPURegionByRegNum (u32 reg_num, INTPTR addr, u64 size, u32 attrib);
+void* Xil_MemMap(UINTPTR Physaddr, size_t size, u32 flags);
+#ifdef __cplusplus
+#endif /* XIL_MPU_H */
+* @} End of "addtogroup r5_mpu_apis".
diff --git a/bsps/shared/xil/arm/cortexr5/xil_cache.c b/bsps/shared/xil/arm/cortexr5/xil_cache.c
index 0000000000..631d02f648
--- /dev/null
+++ b/bsps/shared/xil/arm/cortexr5/xil_cache.c
@@ -0,0 +1,561 @@
+* @file xil_cache.c
+* Contains required functions for the ARM cache functionality.
+* <pre>
+* 5.00 pkp 02/20/14 First release
+* 6.2 mus 01/27/17 Updated to support IAR compiler
+* 7.3 dp 06/25/20 Updated to support armclang compiler
+* 7.7 sk 01/10/22 Update IRQ_FIQ_MASK macro from signed to unsigned
+* to fix misra_c_2012_rule_10_4 violation.
+* 7.7 sk 01/10/22 Typecast to fix wider essential type misra_c_2012_rule_10_7
+* violation.
+* 7.7 mus 02/21/22 Existing note in cache API's says, "bottom 4 bits of input
+* address are forced to 0 as per architecture". As cache line
+* length is of 32 byte, bottom 5 bits of input address would
+* be forced to 0. Updated note to have correct details.
+* It fixes CR#1122561.
+* </pre>
+#include "xil_cache.h"
+#include "xil_io.h"
+#include "xpseudo_asm.h"
+#include "xparameters.h"
+#include "xreg_cortexr5.h"
+#include "xil_exception.h"
+#define IRQ_FIQ_MASK 0xC0U /* Mask IRQ and FIQ interrupts in cpsr */
+#if defined (__clang__)
+extern s32 Image$$ARM_LIB_STACK$$Limit;
+extern s32 Image$$ARM_UNDEF_STACK$$Base;
+#elif defined (__GNUC__)
+extern s32 _stack_end;
+extern s32 __undef_stack;
+#endif
+* @brief Enable the Data cache.
+* @return None.
+void Xil_DCacheEnable(void)
+ register u32 CtrlReg;
+ /* enable caches only if they are disabled */
+#if defined (__GNUC__)
+ CtrlReg = mfcp(XREG_CP15_SYS_CONTROL);
+#elif defined (__ICCARM__)
+ mfcp(XREG_CP15_SYS_CONTROL,CtrlReg);
+#endif
+ if ((CtrlReg & XREG_CP15_CONTROL_C_BIT)==0x00000000U) {
+ /* invalidate the Data cache */
+ Xil_DCacheInvalidate();
+ /* enable the Data cache */
+ CtrlReg |= (XREG_CP15_CONTROL_C_BIT);
+ mtcp(XREG_CP15_SYS_CONTROL, CtrlReg);
+* @brief Disable the Data cache.
+* @return None.
+void Xil_DCacheDisable(void)
+ /* clean and invalidate the Data cache */
+ Xil_DCacheFlush();
+ /* disable the Data cache */
+#endif
+ CtrlReg &= ~(XREG_CP15_CONTROL_C_BIT);
+* @brief Invalidate the entire Data cache.
+* @return None.
+void Xil_DCacheInvalidate(void)
+ u32 currmask;
+ u32 stack_start,stack_end,stack_size;
+ currmask = mfcpsr();
+ mtcpsr(currmask | IRQ_FIQ_MASK);
+ stack_end = (u32 )&Image$$ARM_LIB_STACK$$Limit;
+ stack_start = (u32 )&Image$$ARM_UNDEF_STACK$$Base;
+ stack_end = (u32 )&_stack_end;
+ stack_start = (u32 )&__undef_stack;
+#endif
+#if defined(__GNUC__) || defined(__clang__)
+ stack_size = stack_start-stack_end;
+ /* Flush stack memory to save return address */
+ Xil_DCacheFlushRange(stack_end, stack_size);
+#endif
+ mtcp(XREG_CP15_CACHE_SIZE_SEL, 0);
+ /*invalidate all D cache*/
+ mtcp(XREG_CP15_INVAL_DC_ALL, 0);
+ mtcpsr(currmask);
+* @brief Invalidate a Data cache line. If the byte specified by the
+* address (adr) is cached by the data cache, the cacheline
+* containing that byte is invalidated.If the cacheline is modified
+* (dirty), the modified contents are lost and are NOT written
+* to system memory before the line is invalidated.
+* @param adr: 32bit address of the data to be flushed.
+* @return None.
+* @note The bottom 5 bits are set to 0, forced by architecture.
+void Xil_DCacheInvalidateLine(INTPTR adr)
+ u32 currmask;
+ mtcp(XREG_CP15_INVAL_DC_LINE_MVA_POC, (adr & (~0x1F)));
+ /* Wait for invalidate to complete */
+ dsb();
+ mtcpsr(currmask);
+* @brief Invalidate the Data cache for the given address range.
+* If the bytes specified by the address (adr) are cached by the
+* Data cache,the cacheline containing that byte is invalidated.
+* If the cacheline is modified (dirty), the modified contents are
+* lost and are NOT written to system memory before the line is
+* invalidated.
+* @param adr: 32bit start address of the range to be invalidated.
+* @param len: Length of range to be invalidated in bytes.
+* @return None.
+void Xil_DCacheInvalidateRange(INTPTR adr, u32 len)
+ const u32 cacheline = 32U;
+ u32 end;
+ u32 tempadr = adr;
+ u32 tempend;
+ u32 currmask;
+ if (len != 0U) {
+ end = tempadr + len;
+ tempend = end;
+ /* Select L1 Data cache in CSSR */
+ mtcp(XREG_CP15_CACHE_SIZE_SEL, 0U);
+ if ((tempadr & (cacheline-1U)) != 0U) {
+ tempadr &= (~(cacheline - 1U));
+ Xil_DCacheFlushLine(tempadr);
+ if ((tempend & (cacheline-1U)) != 0U) {
+ tempend &= (~(cacheline - 1U));
+ Xil_DCacheFlushLine(tempend);
+ while (tempadr < tempend) {
+ /* Invalidate Data cache line */
+ asm_inval_dc_line_mva_poc(tempadr);
+ tempadr += cacheline;
+ dsb();
+ mtcpsr(currmask);
+* @brief Flush the entire Data cache.
+* @return None.
+void Xil_DCacheFlush(void)
+ register u32 CsidReg, C7Reg;
+ u32 CacheSize, LineSize, NumWays;
+ u32 Way, WayIndex, Set, SetIndex, NumSet;
+ u32 currmask;
+ /* Select cache level 0 and D cache in CSSR */
+ CsidReg = mfcp(XREG_CP15_CACHE_SIZE_ID);
+ mfcp(XREG_CP15_CACHE_SIZE_ID,CsidReg);
+#endif
+ /* Determine Cache Size */
+ CacheSize = (CsidReg >> 13U) & 0x000001FFU;
+ CacheSize += 0x00000001U;
+ CacheSize *= (u32)128; /* to get number of bytes */
+ /* Number of Ways */
+ NumWays = (CsidReg & 0x000003ffU) >> 3U;
+ NumWays += 0x00000001U;
+ /* Get the cacheline size, way size, index size from csidr */
+ LineSize = (CsidReg & 0x00000007U) + 0x00000004U;
+ NumSet = CacheSize/NumWays;
+ NumSet /= (((u32)0x00000001U) << LineSize);
+ Way = 0U;
+ Set = 0U;
+ /* Invalidate all the cachelines */
+ for (WayIndex = 0U; WayIndex < NumWays; WayIndex++) {
+ for (SetIndex = 0U; SetIndex < NumSet; SetIndex++) {
+ C7Reg = Way | Set;
+ /* Flush by Set/Way */
+ asm_clean_inval_dc_line_sw(C7Reg);
+ Set += (((u32)0x00000001U) << LineSize);
+ Set = 0U;
+ Way += 0x40000000U;
+ /* Wait for flush to complete */
+ dsb();
+ mtcpsr(currmask);
+ mtcpsr(currmask);
+* @brief Flush a Data cache line. If the byte specified by the address (adr)
+* is cached by the Data cache, the cacheline containing that byte is
+* invalidated. If the cacheline is modified (dirty), the entire
+* contents of the cacheline are written to system memory before the
+* line is invalidated.
+* @return None.
+void Xil_DCacheFlushLine(INTPTR adr)
+ u32 currmask;
+ mtcp(XREG_CP15_CLEAN_INVAL_DC_LINE_MVA_POC, (adr & (~0x1F)));
+ dsb();
+ mtcpsr(currmask);
+* @brief Flush the Data cache for the given address range.
+* Data cache, the cacheline containing those bytes is invalidated.If
+* the cacheline is modified (dirty), the written to system memory
+* before the lines are invalidated.
+* @param adr: 32bit start address of the range to be flushed.
+* @param len: Length of the range to be flushed in bytes
+* @return None.
+void Xil_DCacheFlushRange(INTPTR adr, u32 len)
+ u32 LocalAddr = adr;
+ u32 end;
+ u32 currmask;
+ if (len != 0x00000000U) {
+ /* Back the starting address up to the start of a cache line
+ * perform cache operations until adr+len
+ end = LocalAddr + len;
+ LocalAddr &= ~(cacheline - 1U);
+ while (LocalAddr < end) {
+ /* Flush Data cache line */
+ asm_clean_inval_dc_line_mva_poc(LocalAddr);
+ LocalAddr += cacheline;
+ dsb();
+ mtcpsr(currmask);
+* @brief Store a Data cache line. If the byte specified by the address
+* (adr) is cached by the Data cache and the cacheline is modified
+* (dirty), the entire contents of the cacheline are written to
+* system memory.After the store completes, the cacheline is marked
+* as unmodified (not dirty).
+* @param adr: 32bit address of the data to be stored
+* @return None.
+void Xil_DCacheStoreLine(INTPTR adr)
+ u32 currmask;
+ mtcp(XREG_CP15_CLEAN_DC_LINE_MVA_POC, (adr & (~0x1F)));
+ /* Wait for store to complete */
+ dsb();
+ isb();
+ mtcpsr(currmask);
+* @brief Enable the instruction cache.
+* @return None.
+void Xil_ICacheEnable(void)
+ mfcp(XREG_CP15_SYS_CONTROL, CtrlReg);
+#endif
+ if ((CtrlReg & XREG_CP15_CONTROL_I_BIT)==0x00000000U) {
+ /* invalidate the instruction cache */
+ mtcp(XREG_CP15_INVAL_IC_POU, 0);
+ /* enable the instruction cache */
+ CtrlReg |= (XREG_CP15_CONTROL_I_BIT);
+* @brief Disable the instruction cache.
+* @return None.
+void Xil_ICacheDisable(void)
+ dsb();
+ /* disable the instruction cache */
+#endif
+ CtrlReg &= ~(XREG_CP15_CONTROL_I_BIT);
+* @brief Invalidate the entire instruction cache.
+* @return None.
+void Xil_ICacheInvalidate(void)
+ u32 currmask;
+ mtcp(XREG_CP15_CACHE_SIZE_SEL, 1);
+ dsb();
+ mtcpsr(currmask);
+* @brief Invalidate an instruction cache line.If the instruction specified
+* by the address is cached by the instruction cache, the
+* cacheline containing that instruction is invalidated.
+* @param adr: 32bit address of the instruction to be invalidated.
+* @return None.
+void Xil_ICacheInvalidateLine(INTPTR adr)
+ u32 currmask;
+ mtcp(XREG_CP15_INVAL_IC_LINE_MVA_POU, (adr & (~0x1F)));
+ dsb();
+ mtcpsr(currmask);
+* @brief Invalidate the instruction cache for the given address range.
+* Data cache, the cacheline containing that byte is invalidated.
+* If the cachelineis modified (dirty), the modified contents are
+* invalidated.
+* @param len: Length of the range to be invalidated in bytes.
+* @return None.
+void Xil_ICacheInvalidateRange(INTPTR adr, u32 len)
+ u32 end;
+ u32 currmask;
+ LocalAddr = LocalAddr & ~(cacheline - 1U);
+ /* Select cache L0 I-cache in CSSR */
+ mtcp(XREG_CP15_CACHE_SIZE_SEL, 1U);
+ /* Invalidate L1 I-cache line */
+ asm_inval_ic_line_mva_pou(LocalAddr);
+ dsb();
+ mtcpsr(currmask);
diff --git a/bsps/shared/xil/arm/cortexr5/xil_mpu.c b/bsps/shared/xil/arm/cortexr5/xil_mpu.c
index 0000000000..ae96f43117
--- /dev/null
+++ b/bsps/shared/xil/arm/cortexr5/xil_mpu.c
@@ -0,0 +1,641 @@
+* @file xil_mpu.c
+* This file provides APIs for enabling/disabling MPU and setting the memory
+* attributes for sections, in the MPU translation table.
+* <pre>
+* 6.8 aru 07/02/18 Returned the pointer instead of address
+* of that pointer in Xil_MemMap().
+* 7.5 asa 03/01/21 Ensure that Mpu_Config does not stay in .boot/.vector
+* sections which generally should be executable code
+* which can be allocated and not written.
+* Mpu_Config array is populated during boot time, hence
+* cannot be placed in .bss or .data section. Putting
+* Mpu_Config in a new .bootdata section.
+* 7.7 sk 01/10/22 Update int to u32 to fix misrac misra_c_2012_directive_4_6
+* violations.
+* 7.7 sk 01/10/22 Typecast variables from signed to unsigned to fix
+* misra_c_2012_rule_10_4 violation.
+* 7.7 sk 01/10/22 Add explicit parentheses for region_size and region_size[0]
+* to fix misra_c_2012_rule_12_1 violation.
+* 7.7 sk 01/10/22 Remove unsigned sign to fix misra_c_2012_rule_10_3 violation.
+* 7.7 sk 01/10/22 Modify if condition to fix misra_c_2012_rule_10_1 violation.
+* violation.
+* 7.7 sk 01/10/22 Update conditional expression to fix misra_c_2012_rule_14_4
+* violation.
+* 7.7 sk 01/10/22 Add braces for the if statement to make it a compound
+* statement to fix misra_c_2012_rule_15_6 violation.
+* </pre>
+ * Origin: https://github.com/Xilinx/embeddedsw/blob/master/lib/bsp/standalone/src/arm/cortexr5/xil_mpu.c
+ * __rtems__ changes:
+ * - un-include xdebug.h and add macro for xdbg_printf
+ * - relocate XMpu_Config
+ * - form Xilinx link script section(".bootdata")
+ * - to RTEMS link script section(".bsp_start_data")
+#include "xil_mpu.h"
+#ifndef __rtems__
+#include "xdebug.h"
+#else
+#define xdbg_printf(...)
+#endif
+#include "xstatus.h"
+#define MPU_REGION_SIZE_MIN 0x20
+static const struct {
+ u64 size;
+ u32 encoding;
+}region_size[] = {
+ { 0x20, REGION_32B },
+ { 0x40, REGION_64B },
+ { 0x80, REGION_128B },
+ { 0x100, REGION_256B },
+ { 0x200, REGION_512B },
+ { 0x400, REGION_1K },
+ { 0x800, REGION_2K },
+ { 0x1000, REGION_4K },
+ { 0x2000, REGION_8K },
+ { 0x4000, REGION_16K },
+ { 0x8000, REGION_32K },
+ { 0x10000, REGION_64K },
+ { 0x20000, REGION_128K },
+ { 0x40000, REGION_256K },
+ { 0x80000, REGION_512K },
+ { 0x100000, REGION_1M },
+ { 0x200000, REGION_2M },
+ { 0x400000, REGION_4M },
+ { 0x800000, REGION_8M },
+ { 0x1000000, REGION_16M },
+ { 0x2000000, REGION_32M },
+ { 0x4000000, REGION_64M },
+ { 0x8000000, REGION_128M },
+ { 0x10000000, REGION_256M },
+ { 0x20000000, REGION_512M },
+ { 0x40000000, REGION_1G },
+ { 0x80000000, REGION_2G },
+ { 0x100000000, REGION_4G },
+XMpu_Config Mpu_Config __attribute__((section(".bootdata")));
+#pragma default_function_attributes = @ ".bootdata"
+XMpu_Config Mpu_Config;
+#endif
+void Xil_InitializeExistingMPURegConfig(void);
+* @brief This function sets the memory attributes for a section covering
+* 1MB, of memory in the translation table.
+* @param addr: 32-bit address for which memory attributes need to be set.
+* @param attrib: Attribute for the given memory region.
+* @return None.
+ INTPTR Localaddr = addr;
+ Localaddr &= (INTPTR)(~(0xFFFFFU));
+ /* Setting the MPU region with given attribute with 1MB size */
+ Xil_SetMPURegion(Localaddr, 0x100000, attrib);
+* @brief Set the memory attributes for a section of memory in the
+* translation table.
+* @param addr: 32-bit address for which memory attributes need to be set..
+* @param size: size is the size of the region.
+* @return None.
+ u32 Regionsize = 0;
+ u32 NextAvailableMemRegion;
+ u32 i;
+ NextAvailableMemRegion = Xil_GetNextMPURegion();
+ if (NextAvailableMemRegion == 0xFFU) {
+ xdbg_printf(DEBUG, "No regions available\r\n");
+ return XST_FAILURE;
+ Xil_ICacheInvalidate();
+ mtcp(XREG_CP15_MPU_MEMORY_REG_NUMBER,NextAvailableMemRegion);
+ isb();
+ /* Lookup the size. */
+ for (i = 0; i < (sizeof (region_size) / sizeof (region_size[0])); i++) {
+ if (size <= region_size[i].size) {
+ Regionsize = region_size[i].encoding;
+ break;
+ Localaddr &= (INTPTR)(~(region_size[i].size - 1U));
+ Regionsize <<= 1;
+ Regionsize |= REGION_EN;
+ dsb();
+ mtcp(XREG_CP15_MPU_REG_BASEADDR, Localaddr); /* Set base address of a region */
+ mtcp(XREG_CP15_MPU_REG_ACCESS_CTRL, attrib); /* Set the control attribute */
+ mtcp(XREG_CP15_MPU_REG_SIZE_EN, Regionsize); /* set the region size and enable it*/
+ dsb();
+ isb();
+ Xil_UpdateMPUConfig(NextAvailableMemRegion, Localaddr, Regionsize, attrib);
+ return XST_SUCCESS;
+* @brief Enable MPU for Cortex R5 processor. This function invalidates I
+* cache and flush the D Caches, and then enables the MPU.
+* @return None.
+ u32 CtrlReg, Reg;
+ s32 DCacheStatus=0, ICacheStatus=0;
+#endif
+ if ((CtrlReg & XREG_CP15_CONTROL_C_BIT) != 0x00000000U) {
+ DCacheStatus=1;
+ if ((CtrlReg & XREG_CP15_CONTROL_I_BIT) != 0x00000000U) {
+ ICacheStatus=1;
+ if(DCacheStatus != 0) {
+ Xil_DCacheDisable();
+ if(ICacheStatus != 0){
+ Xil_ICacheDisable();
+ Reg = mfcp(XREG_CP15_SYS_CONTROL);
+ mfcp(XREG_CP15_SYS_CONTROL,Reg);
+#endif
+ Reg |= 0x00000001U;
+ dsb();
+ mtcp(XREG_CP15_SYS_CONTROL, Reg);
+ isb();
+ /* enable caches only if they are disabled in routine*/
+ Xil_DCacheEnable();
+ if(ICacheStatus != 0) {
+ Xil_ICacheEnable();
+* @brief Disable MPU for Cortex R5 processors. This function invalidates I
+* cache and flush the D Caches, and then disabes the MPU.
+* @return None.
+ u32 CtrlReg, Reg;
+#endif
+ DCacheStatus=1;
+ ICacheStatus=1;
+ mtcp(XREG_CP15_INVAL_BRANCH_ARRAY, 0);
+#endif
+ Reg &= ~(0x00000001U);
+ dsb();
+ isb();
+* @brief Update the MPU configuration for the requested region number in
+* the global MPU configuration table.
+* @param reg_num: The requested region number to be updated information for.
+* @param address: 32 bit address for start of the region.
+* @param size: Requested size of the region.
+* @param attrib: Attribute for the corresponding region.
+* @return XST_FAILURE: When the requested region number if 16 or more.
+* XST_SUCCESS: When the MPU configuration table is updated.
+ u32 ReturnVal = XST_SUCCESS;
+ u32 Tempsize = size;
+ u32 Index;
+ if (reg_num >= MAX_POSSIBLE_MPU_REGS) {
+ xdbg_printf(DEBUG, "Invalid region number\r\n");
+ ReturnVal = XST_FAILURE;
+ goto exit;
+ if ((size & REGION_EN) != 0) {
+ Mpu_Config[reg_num].RegionStatus = MPU_REG_ENABLED;
+ Mpu_Config[reg_num].BaseAddress = address;
+ Tempsize &= (~REGION_EN);
+ Tempsize >>= 1;
+ for (Index = 0; Index <
+ (sizeof (region_size) / sizeof (region_size[0])); Index++) {
+ if (Tempsize <= region_size[Index].encoding) {
+ Mpu_Config[reg_num].Size = region_size[Index].size;
+ break;
+ Mpu_Config[reg_num].Attribute = attrib;
+ } else {
+ Mpu_Config[reg_num].RegionStatus = 0U;
+ Mpu_Config[reg_num].BaseAddress = 0;
+ Mpu_Config[reg_num].Size = 0U;
+ Mpu_Config[reg_num].Attribute = 0U;
+exit:
+ return ReturnVal;
+* @brief The MPU configuration table is passed to the caller.
+* @param mpuconfig: This is of type XMpu_Config which is an array of
+* 16 entries of type structure representing the MPU config table
+* @return none
+void Xil_GetMPUConfig (XMpu_Config mpuconfig) {
+ u32 Index = 0U;
+ while (Index < MAX_POSSIBLE_MPU_REGS) {
+ mpuconfig[Index].RegionStatus = Mpu_Config[Index].RegionStatus;
+ mpuconfig[Index].BaseAddress = Mpu_Config[Index].BaseAddress;
+ mpuconfig[Index].Attribute = Mpu_Config[Index].Attribute;
+ mpuconfig[Index].Size = Mpu_Config[Index].Size;
+ Index++;
+* @brief Returns the total number of free MPU regions available.
+* @return Number of free regions available to users
+u32 Xil_GetNumOfFreeRegions (void) {
+ u32 Index = 0U;
+ u32 NumofFreeRegs = 0U;
+ if (MPU_REG_DISABLED == Mpu_Config[Index].RegionStatus) {
+ NumofFreeRegs++;
+ Index++;
+ return NumofFreeRegs;
+* @brief Returns the total number of free MPU regions available in the form
+* of a mask. A bit of 1 in the returned 16 bit value represents the
+* corresponding region number to be available.
+* For example, if this function returns 0xC0000, this would mean, the
+* regions 14 and 15 are available to users.
+* @return The free region mask as a 16 bit value
+u16 Xil_GetMPUFreeRegMask (void) {
+ u32 Index = 0U;
+ u16 FreeRegMask = 0U;
+ FreeRegMask |= ((u16)1U << Index);
+ Index++;
+ return FreeRegMask;
+* @brief Disables the corresponding region number as passed by the user.
+* @param reg_num: The region number to be disabled
+* @return XST_SUCCESS: If the region could be disabled successfully
+* XST_FAILURE: If the requested region number is 16 or more.
+u32 Xil_DisableMPURegionByRegNum (u32 reg_num) {
+ u32 Temp = 0U;
+ u32 ReturnVal = XST_FAILURE;
+ if (reg_num >= 16U) {
+ goto exit1;
+ mtcp(XREG_CP15_MPU_MEMORY_REG_NUMBER,reg_num);
+ Temp = mfcp(XREG_CP15_MPU_REG_SIZE_EN);
+ mfcp(XREG_CP15_MPU_REG_SIZE_EN,Temp);
+#endif
+ Temp &= (~REGION_EN);
+ dsb();
+ mtcp(XREG_CP15_MPU_REG_SIZE_EN,Temp);
+ dsb();
+ isb();
+ Xil_UpdateMPUConfig(reg_num, 0, 0U, 0U);
+ ReturnVal = XST_SUCCESS;
+exit1:
+ return ReturnVal;
+* @brief Enables the corresponding region number as passed by the user.
+* @param reg_num: The region number to be enabled
+* @param addr: 32 bit address for start of the region.
+* @return XST_SUCCESS: If the region could be created successfully
+ u32 Index;
+ goto exit2;
+ if (Mpu_Config[reg_num].RegionStatus == MPU_REG_ENABLED) {
+ xdbg_printf(DEBUG, "Region already enabled\r\n");
+ goto exit2;
+ isb();
+ if (size <= region_size[Index].size) {
+ Regionsize = region_size[Index].encoding;
+ break;
+ Localaddr &= (INTPTR)(~(region_size[Index].size - 1U));
+ Regionsize <<= 1;
+ dsb();
+ dsb();
+ isb();
+ Xil_UpdateMPUConfig(reg_num, Localaddr, Regionsize, attrib);
+exit2:
+ return ReturnVal;
+* @brief Initializes the MPU configuration table that are setup in the
+* R5 boot code in the Init_Mpu function called before C main.
+* @return none
+ u32 Index = 0U;
+ u32 Index1 = 0U;
+ u32 MPURegSize;
+ INTPTR MPURegBA;
+ u32 MPURegAttrib;
+ u32 Tempsize;
+ mtcp(XREG_CP15_MPU_MEMORY_REG_NUMBER,Index);
+ MPURegSize = mfcp(XREG_CP15_MPU_REG_SIZE_EN);
+ MPURegBA = mfcp(XREG_CP15_MPU_REG_BASEADDR);
+ MPURegAttrib = mfcp(XREG_CP15_MPU_REG_ACCESS_CTRL);
+ mfcp(XREG_CP15_MPU_REG_SIZE_EN,MPURegSize);
+ mfcp(XREG_CP15_MPU_REG_BASEADDR, MPURegBA);
+ mfcp(XREG_CP15_MPU_REG_ACCESS_CTRL, MPURegAttrib);
+#endif
+ if ((MPURegSize & REGION_EN) != 0) {
+ Mpu_Config[Index].RegionStatus = MPU_REG_ENABLED;
+ Mpu_Config[Index].BaseAddress = MPURegBA;
+ Mpu_Config[Index].Attribute = MPURegAttrib;
+ Tempsize = MPURegSize & (~REGION_EN);
+ Tempsize >>= 1;
+ for (Index1 = 0; Index1 <
+ (sizeof (region_size) / sizeof (region_size[0])); Index1++) {
+ if (Tempsize <= region_size[Index1].encoding) {
+ Mpu_Config[Index].Size = region_size[Index1].size;
+ break;
+ Index++;
+* @brief Returns the next available free MPU region
+* @return The free MPU region available
+ u32 Index = 0U;
+ u32 NextAvailableReg = 0xFF;
+ if (Mpu_Config[Index].RegionStatus != MPU_REG_ENABLED) {
+ NextAvailableReg = Index;
+ break;
+ Index++;
+ return NextAvailableReg;
+#ifdef __GNUC__
+#define u32overflow(a, b) ({typeof(a) s; __builtin_uadd_overflow(a, b, &s); })
+#else
+#define u32overflow(a, b) ((a) > ((a) + (b)))
+#endif /* __GNUC__ */
+* @brief Memory mapping for Cortex-R5F. If successful, the mapped
+* region will include all of the memory requested, but may
+* include more. Specifically, it will be a power of 2 in
+* size, aligned on a boundary of that size.
+* @param Physaddr is base physical address at which to start mapping.
+* NULL in Physaddr masks possible mapping errors.
+* @param size of region to be mapped.
+* @param flags used to set translation table.
+* @return Physaddr on success, NULL on error. Ambiguous if Physaddr==NULL
+* @cond Xil_MemMap_internal
+* @note: u32overflow() is defined for readability and (for __GNUC__) to
+* - force the type of the check to be the same as the first argument
+* - hide the otherwise unused third argument of the builtin
+* - improve safety by choosing the explicit _uadd_ version.
+* Consider __builtin_add_overflow_p() when available.
+* Use an alternative (less optimal?) for compilers w/o the builtin.
+* @endcond
+void *Xil_MemMap(UINTPTR Physaddr, size_t size, u32 flags)
+ size_t Regionsize = MPU_REGION_SIZE_MIN;
+ UINTPTR Basephysaddr = 0, end = Physaddr + size;
+ if (flags == 0U) {
+ return (void *)Physaddr;
+ if (u32overflow(Physaddr, size)) {
+ return NULL;
+ for ( ; Regionsize != 0U; Regionsize <<= 1) {
+ if (Regionsize >= size) {
+ Basephysaddr = Physaddr & ~(Regionsize - 1U);
+ if (u32overflow(Basephysaddr, Regionsize)) {
+ break;
+ if ((Basephysaddr + Regionsize) >= end) {
+ return ((Xil_SetMPURegion(Basephysaddr,
+ Regionsize, flags) == XST_SUCCESS) ?
+ (void *)Physaddr : NULL);
+ return NULL;
2.39.2
