[PATCH v2 3/4] bsps/xil: Adjust Xilinx support code for Cortex-R5
Kinsey Moore
kinsey.moore at oarcorp.com
Thu Oct 12 17:01:49 UTC 2023
This fixes some issues in the Xilinx support code that are critical to
support the Cortex-R5F cores present in my Xilinx SoCs. The imported
Cortex-R5 xil_cache.c matches the existing information in
bsps/shared/xil/VERSION.
bsps/include/xil/arm/ARMv8/32bit/xil_system.h | 37 ++++++++++++++++++
bsps/include/xil/arm/ARMv8/64bit/xil_system.h | 37 ++++++++++++++++++
bsps/include/xil/arm/cortexa9/xil_system.h | 38 +++++++++++++++++++
bsps/include/xil/arm/cortexr5/xil_system.h | 38 +++++++++++++++++++
bsps/include/xil/microblaze/xil_system.h | 37 ++++++++++++++++++
bsps/include/xil/xdebug.h | 2 +
bsps/shared/xil/{ => arm/ARMv8}/xil_cache.c | 0
bsps/shared/xil/arm/cortexr5/xil_mpu.c | 4 ++
spec/build/bsps/objxilinxsupport.yml | 1 -
spec/build/bsps/objxilinxsupportilp32.yml | 3 +-
spec/build/bsps/objxilinxsupportlp64.yml | 3 +-
spec/build/bsps/objxilinxsupportr5.yml | 5 ++-
12 files changed, 201 insertions(+), 4 deletions(-)
create mode 100644 bsps/include/xil/arm/ARMv8/32bit/xil_system.h
create mode 100644 bsps/include/xil/arm/ARMv8/64bit/xil_system.h
create mode 100644 bsps/include/xil/arm/cortexa9/xil_system.h
create mode 100644 bsps/include/xil/arm/cortexr5/xil_system.h
create mode 100644 bsps/include/xil/microblaze/xil_system.h
create mode 100644 bsps/include/xil/xdebug.h
rename bsps/shared/xil/{ => arm/ARMv8}/xil_cache.c (100%)
diff --git a/bsps/include/xil/arm/ARMv8/32bit/xil_system.h b/bsps/include/xil/arm/ARMv8/32bit/xil_system.h
new file mode 100644
index 0000000000..7269e5c8d9
--- /dev/null
+++ b/bsps/include/xil/arm/ARMv8/32bit/xil_system.h
@@ -0,0 +1,37 @@
+ * COPYRIGHT (c) 2023.
+ * On-Line Applications Research Corporation (OAR).
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef LIBBSP_SHARED_XIL_SYSTEM_H
+#define LIBBSP_SHARED_XIL_SYSTEM_H
+ * This file defines anything necessary for the Xilinx support infrastructure to
+ * function properly on a particular platform.
+#endif
diff --git a/bsps/include/xil/arm/ARMv8/64bit/xil_system.h b/bsps/include/xil/arm/ARMv8/64bit/xil_system.h
--- /dev/null
+++ b/bsps/include/xil/arm/ARMv8/64bit/xil_system.h
@@ -0,0 +1,37 @@
+ * are met:
+#endif
diff --git a/bsps/include/xil/arm/cortexa9/xil_system.h b/bsps/include/xil/arm/cortexa9/xil_system.h
index 0000000000..88d5b9aa6e
--- /dev/null
+++ b/bsps/include/xil/arm/cortexa9/xil_system.h
@@ -0,0 +1,38 @@
+ * are met:
+#define ARMA9
+#endif
diff --git a/bsps/include/xil/arm/cortexr5/xil_system.h b/bsps/include/xil/arm/cortexr5/xil_system.h
index 0000000000..4274d6916a
--- /dev/null
+++ b/bsps/include/xil/arm/cortexr5/xil_system.h
@@ -0,0 +1,38 @@
+ * are met:
+#define ARMR5
+#endif
diff --git a/bsps/include/xil/microblaze/xil_system.h b/bsps/include/xil/microblaze/xil_system.h
--- /dev/null
+++ b/bsps/include/xil/microblaze/xil_system.h
@@ -0,0 +1,37 @@
+ * are met:
+#endif
diff --git a/bsps/include/xil/xdebug.h b/bsps/include/xil/xdebug.h
index 0000000000..416a2f2cb3
--- /dev/null
+++ b/bsps/include/xil/xdebug.h
@@ -0,0 +1,2 @@
+/* Minimal stub file for Xilinx driver compatibility. */
+#define xdbg_printf(...)
diff --git a/bsps/shared/xil/xil_cache.c b/bsps/shared/xil/arm/ARMv8/xil_cache.c
similarity index 100%
rename from bsps/shared/xil/xil_cache.c
rename to bsps/shared/xil/arm/ARMv8/xil_cache.c
diff --git a/bsps/shared/xil/arm/cortexr5/xil_mpu.c b/bsps/shared/xil/arm/cortexr5/xil_mpu.c
index ae96f43117..a50133d51e 100644
--- a/bsps/shared/xil/arm/cortexr5/xil_mpu.c
+++ b/bsps/shared/xil/arm/cortexr5/xil_mpu.c
@@ -115,12 +115,16 @@ static const struct {
{ 0x100000000, REGION_4G },
+#ifndef __rtems__
#if defined (__GNUC__)
XMpu_Config Mpu_Config __attribute__((section(".bootdata")));
#elif defined (__ICCARM__)
#pragma default_function_attributes = @ ".bootdata"
XMpu_Config Mpu_Config;
#endif
+#else
+XMpu_Config Mpu_Config __attribute__((section(".bsp_start_data")));
+#endif
/************************** Function Prototypes ******************************/
void Xil_InitializeExistingMPURegConfig(void);
diff --git a/spec/build/bsps/objxilinxsupport.yml b/spec/build/bsps/objxilinxsupport.yml
index d686ae9cfd..f67316ebdb 100644
--- a/spec/build/bsps/objxilinxsupport.yml
+++ b/spec/build/bsps/objxilinxsupport.yml
@@ -38,7 +38,6 @@ links:
- role: build-dependency
uid: optxilsupportpath
source:
-- bsps/shared/xil/xil_cache.c
- bsps/shared/xil/xil_assert.c
- bsps/shared/xil/xil_mem.c
type: build
diff --git a/spec/build/bsps/objxilinxsupportilp32.yml b/spec/build/bsps/objxilinxsupportilp32.yml
index 2db5d12bef..0fc4fb0f35 100644
--- a/spec/build/bsps/objxilinxsupportilp32.yml
+++ b/spec/build/bsps/objxilinxsupportilp32.yml
@@ -17,5 +17,6 @@ install:
- bsps/include/xil/arm/ARMv8/32bit/xpseudo_asm.h
- bsps/include/xil/arm/ARMv8/32bit/xreg_cortexa53.h
links: []
-source: []
+source:
+- bsps/shared/xil/arm/ARMv8/xil_cache.c
type: build
diff --git a/spec/build/bsps/objxilinxsupportlp64.yml b/spec/build/bsps/objxilinxsupportlp64.yml
index efb2e8d58a..330ffc34fd 100644
--- a/spec/build/bsps/objxilinxsupportlp64.yml
+++ b/spec/build/bsps/objxilinxsupportlp64.yml
@@ -19,5 +19,6 @@ install:
- bsps/include/xil/arm/ARMv8/64bit/xpseudo_asm.h
- bsps/include/xil/arm/ARMv8/64bit/xreg_cortexa53.h
links: []
-source: []
+source:
type: build
diff --git a/spec/build/bsps/objxilinxsupportr5.yml b/spec/build/bsps/objxilinxsupportr5.yml
index 4f7fe33606..db402af8ca 100644
--- a/spec/build/bsps/objxilinxsupportr5.yml
+++ b/spec/build/bsps/objxilinxsupportr5.yml
@@ -14,6 +14,9 @@ install:
- bsps/include/xil/arm/cortexr5/xil_exception.h
- bsps/include/xil/arm/cortexr5/xpseudo_asm.h
- bsps/include/xil/arm/cortexr5/xreg_cortexr5.h
+ - bsps/include/xil/arm/cortexr5/xil_mpu.h
links: []
-source: []
+source:
+- bsps/shared/xil/arm/cortexr5/xil_cache.c
+- bsps/shared/xil/arm/cortexr5/xil_mpu.c
type: build
2.39.2
