[PATCH] fixed warning related to spstdc17
Sebastian Huber
Tue Oct 24 12:31:12 UTC 2023
On 24.10.23 14:02, zack leung wrote:
> hi! sabestian did you mean the size of the structure?
Yes, one option to get rid of the empty structures is to just provide
typedefs, for example:
#if defined(RTEMS_SMP)
typedef struct Scheduler_Context {
} Scheduler_Context;
#else
typedef struct Scheduler_Context Scheduler_Context;
#endif
Then you have to make sure that #if !defined(RTEMS_SMP) no objects of
this type are used.
For the ISR locks we can do something similar. However, in this case
this affects also the API, so we probably need an API define for this as
well. Suggestion: RTEMS_HAVE_INTERRUPT_LOCK_OBJECTS.
The user can then do something like this:
struct app {
#if defined(RTEMS_HAVE_INTERRUPT_LOCK_OBJECTS)
rtems_interrupt_lock lock;
#endif
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
