[PATCH] fixed warning related to spstdc17
zack leung
zakthertemsdev at gmail.com
Wed Oct 25 02:17:52 UTC 2023
that didn't work but i'm thinking of defining a char array that is equal
to the size of the processor lock and the isr lock? i figured that the
processor lock is 64 bits and isr lock is a one bit?
I'm confused on how to make an api define do you have a file i can look at?
On Tue, 24 Oct 2023 at 08:31, Sebastian Huber <
> On 24.10.23 14:02, zack leung wrote:
> > hi! sabestian did you mean the size of the structure?
> Yes, one option to get rid of the empty structures is to just provide
> typedefs, for example:
> #if defined(RTEMS_SMP)
> typedef struct Scheduler_Context {
> } Scheduler_Context;
> #else
> typedef struct Scheduler_Context Scheduler_Context;
> #endif
> Then you have to make sure that #if !defined(RTEMS_SMP) no objects of
> this type are used.
> For the ISR locks we can do something similar. However, in this case
> this affects also the API, so we probably need an API define for this as
> well. Suggestion: RTEMS_HAVE_INTERRUPT_LOCK_OBJECTS.
> The user can then do something like this:
> struct app {
> #if defined(RTEMS_HAVE_INTERRUPT_LOCK_OBJECTS)
> rtems_interrupt_lock lock;
> #endif
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax: +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20231024/d5b63433/attachment.htm>
