[PATCH v3 1/2] bsps/clock: Import Xilinx TTC hardware definitions
Kinsey Moore
kinsey.moore at oarcorp.com
Tue Oct 24 14:58:41 UTC 2023
This imports the TTC hardware definitions for the triple timer counters
on various Xilinx platforms. This was imported as specified in the
VERSION file in this commit.
bsps/include/dev/clock/VERSION | 24 ++++
bsps/include/dev/clock/xttcps_hw.h | 207 +++++++++++++++++++++++++++++
2 files changed, 231 insertions(+)
create mode 100644 bsps/include/dev/clock/VERSION
create mode 100644 bsps/include/dev/clock/xttcps_hw.h
diff --git a/bsps/include/dev/clock/VERSION b/bsps/include/dev/clock/VERSION
new file mode 100644
index 0000000000..1ccbe7c216
--- /dev/null
+++ b/bsps/include/dev/clock/VERSION
@@ -0,0 +1,24 @@
+The information in this file describes the source of
+bsps/include/dev/clock/xttcps_hw.h.
+Import from:
+https://github.com/Xilinx/embeddedsw.git
+commit 5330a64c8efd14f0eef09befdbb8d3d738c33ec2
+Refs: <xilinx_v2022.2>
+Author: Nicole Baze <nicole.baze at xilinx.com>
+AuthorDate: Mon Oct 3 13:27:19 2022 -0700
+Commit: Siva Addepalli <sivaprasad.addepalli at xilinx.com>
+CommitDate: Fri Oct 7 10:26:16 2022 +0530
+ xilpm: versal: server: Fix bug in AIE2 zeroization
+ There is a bug in AIE2 zeriozation function when polling for memory
+ zeroization complete. Currently the entire memory register is being
+ checked against zero but instead we need to check the bits specific
+ to the memory tiles. This patch updates the zeroization check by
+ adding a mask so that only the desired bits are checked for zero.
+ Signed-off-by: Nicole Baze <nicole.baze at xilinx.com>
+ Acked-by: Jesus De Haro <jesus.de-haro at xilinx.com>
diff --git a/bsps/include/dev/clock/xttcps_hw.h b/bsps/include/dev/clock/xttcps_hw.h
index 0000000000..0559c4a00c
--- /dev/null
+++ b/bsps/include/dev/clock/xttcps_hw.h
@@ -0,0 +1,207 @@
+* Copyright (C) 2010 - 2021 Xilinx, Inc. All rights reserved.
+* SPDX-License-Identifier: MIT
+* @file xttcps_hw.h
+* @addtogroup ttcps_v3_15
+* This file defines the hardware interface to one of the three timer counters
+* in the Ps block.
+* <pre>
+* MODIFICATION HISTORY:
+* Ver Who Date Changes
+* 1.00a drg/jz 01/21/10 First release
+* 3.00 kvn 02/13/15 Modified code for MISRA-C:2012 compliance.
+* 3.5 srm 10/06/17 Updated XTTCPS_COUNT_VALUE_MASK,
+* XTTCPS_INTERVAL_VAL_MASK, XTTCPS_MATCH_MASK macros to
+* mask 16 bit values for zynq and 32 bit values for
+* zynq ultrascale+mpsoc "
+* </pre>
+#ifndef XTTCPS_HW_H /* prevent circular inclusions */
+#define XTTCPS_HW_H /* by using protection macros */
+#ifdef __cplusplus
+extern "C" {
+#endif
+/***************************** Include Files *********************************/
+#include "xil_types.h"
+#include "xil_assert.h"
+#include "xil_io.h"
+/************************** Constant Definitions *****************************/
+ * Flag for a9 processor
+ #if !defined (ARMR5) && !defined (__aarch64__) && !defined (ARMA53_32)
+ #define ARMA9
+ #endif
+/** @name Register Map
+ * Register offsets from the base address of the device.
+#define XTTCPS_CLK_CNTRL_OFFSET 0x00000000U /**< Clock Control Register */
+#define XTTCPS_CNT_CNTRL_OFFSET 0x0000000CU /**< Counter Control Register*/
+#define XTTCPS_COUNT_VALUE_OFFSET 0x00000018U /**< Current Counter Value */
+#define XTTCPS_INTERVAL_VAL_OFFSET 0x00000024U /**< Interval Count Value */
+#define XTTCPS_MATCH_0_OFFSET 0x00000030U /**< Match 1 value */
+#define XTTCPS_MATCH_1_OFFSET 0x0000003CU /**< Match 2 value */
+#define XTTCPS_MATCH_2_OFFSET 0x00000048U /**< Match 3 value */
+#define XTTCPS_ISR_OFFSET 0x00000054U /**< Interrupt Status Register */
+#define XTTCPS_IER_OFFSET 0x00000060U /**< Interrupt Enable Register */
+/** @name Clock Control Register
+ * Clock Control Register definitions
+#define XTTCPS_CLK_CNTRL_PS_EN_MASK 0x00000001U /**< Prescale enable */
+#define XTTCPS_CLK_CNTRL_PS_VAL_MASK 0x0000001EU /**< Prescale value */
+#define XTTCPS_CLK_CNTRL_PS_VAL_SHIFT 1U /**< Prescale shift */
+#define XTTCPS_CLK_CNTRL_PS_DISABLE 16U /**< Prescale disable */
+#define XTTCPS_CLK_CNTRL_SRC_MASK 0x00000020U /**< Clock source */
+#define XTTCPS_CLK_CNTRL_EXT_EDGE_MASK 0x00000040U /**< External Clock edge */
+/** @name Counter Control Register
+ * Counter Control Register definitions
+#define XTTCPS_CNT_CNTRL_DIS_MASK 0x00000001U /**< Disable the counter */
+#define XTTCPS_CNT_CNTRL_INT_MASK 0x00000002U /**< Interval mode */
+#define XTTCPS_CNT_CNTRL_DECR_MASK 0x00000004U /**< Decrement mode */
+#define XTTCPS_CNT_CNTRL_MATCH_MASK 0x00000008U /**< Match mode */
+#define XTTCPS_CNT_CNTRL_RST_MASK 0x00000010U /**< Reset counter */
+#define XTTCPS_CNT_CNTRL_EN_WAVE_MASK 0x00000020U /**< Enable waveform */
+#define XTTCPS_CNT_CNTRL_POL_WAVE_MASK 0x00000040U /**< Waveform polarity */
+#define XTTCPS_CNT_CNTRL_RESET_VALUE 0x00000021U /**< Reset value */
+/** @name Current Counter Value Register
+ * Current Counter Value Register definitions
+#if defined(ARMA9)
+#define XTTCPS_COUNT_VALUE_MASK 0x0000FFFFU /**< 16-bit counter value */
+#else
+#define XTTCPS_COUNT_VALUE_MASK 0xFFFFFFFFU /**< 32-bit counter value */
+#endif
+/** @name Interval Value Register
+ * Interval Value Register is the maximum value the counter will count up or
+ * down to.
+#if defined(ARMA9)
+#define XTTCPS_INTERVAL_VAL_MASK 0x0000FFFFU /**< 16-bit Interval value*/
+#else
+#define XTTCPS_INTERVAL_VAL_MASK 0xFFFFFFFFU /**< 32-bit Interval value*/
+#endif
+/** @name Match Registers
+ * Definitions for Match registers, each timer counter has three match
+ * registers.
+#if defined(ARMA9)
+#define XTTCPS_MATCH_MASK 0x0000FFFFU /**< 16-bit Match value */
+#else
+#define XTTCPS_MATCH_MASK 0xFFFFFFFFU /**< 32-bit Match value */
+#endif
+#define XTTCPS_NUM_MATCH_REG 3U /**< Num of Match reg */
+/** @name Interrupt Registers
+ * Following register bit mask is for all interrupt registers.
+#define XTTCPS_IXR_INTERVAL_MASK 0x00000001U /**< Interval Interrupt */
+#define XTTCPS_IXR_MATCH_0_MASK 0x00000002U /**< Match 1 Interrupt */
+#define XTTCPS_IXR_MATCH_1_MASK 0x00000004U /**< Match 2 Interrupt */
+#define XTTCPS_IXR_MATCH_2_MASK 0x00000008U /**< Match 3 Interrupt */
+#define XTTCPS_IXR_CNT_OVR_MASK 0x00000010U /**< Counter Overflow */
+#define XTTCPS_IXR_ALL_MASK 0x0000001FU /**< All valid Interrupts */
+/***************** Macros (Inline Functions) Definitions *********************/
+* Read the given Timer Counter register.
+* @param BaseAddress is the base address of the timer counter device.
+* @param RegOffset is the register offset to be read
+* @return The 32-bit value of the register
+* @note C-style signature:
+* u32 XTtcPs_ReadReg(u32 BaseAddress, u32 RegOffset)
+#define XTtcPs_ReadReg(BaseAddress, RegOffset) \
+ (Xil_In32((BaseAddress) + (u32)(RegOffset)))
+* Write the given Timer Counter register.
+* @param RegOffset is the register offset to be written
+* @param Data is the 32-bit value to write to the register
+* @return None.
+* void XTtcPs_WriteReg(XTtcPs BaseAddress, u32 RegOffset,
+* u32 Data)
+#define XTtcPs_WriteReg(BaseAddress, RegOffset, Data) \
+ (Xil_Out32((BaseAddress) + (u32)(RegOffset), (u32)(Data)))
+* Calculate a match register offset using the Match Register index.
+* @param MatchIndex is the 0-2 value of the match register
+* @return MATCH_N_OFFSET.
+* u32 XTtcPs_Match_N_Offset(u8 MatchIndex)
+#define XTtcPs_Match_N_Offset(MatchIndex) \
+ ((u32)XTTCPS_MATCH_0_OFFSET + ((u32)(12U) * (u32)(MatchIndex)))
+/************************** Function Prototypes ******************************/
+/************************** Variable Definitions *****************************/
+#ifdef __cplusplus
+#endif
+#endif /* end of protection macro */
2.39.2
