[PATCH 1/1] trace: build with c++17 if building against llvm 16+
Sebastian Huber
Fri Sep 22 04:47:32 UTC 2023
On 22.09.23 04:36, Joel Sherrill wrote:
> Are we doing something that particularly requires C++17? AFAIK we
> haven't needed it yet and why wouldn't it also be needed with gcc? If
> the default on recent gcc versions is that, ok but we should be precise
> in case an older gcc with a different default is used.
The problem is not that we use features of a particular standard. It is
that LLVM requires a particular standard for the header files it ships
and that we use.
I already fixed this some time ago:
https://lists.rtems.org/pipermail/devel/2023-May/075269.html
However, Chris didn't like the change.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
