[RSB PATCH] rtems: Update RTEMS packages to their HEAD
chrisj at rtems.org chrisj at rtems.org
Wed Apr 3 04:23:27 UTC 2024
 rtems/config/tools/rtems-kernel-6.cfg | 4 ++--
 rtems/config/tools/rtems-libbsd-6.cfg | 4 ++--
 rtems/config/tools/rtems-tools-6.cfg  | 6 +++---
 3 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/rtems/config/tools/rtems-kernel-6.cfg b/rtems/config/tools/rtems-kernel-6.cfg
index 1e90184..9219263 100644
--- a/rtems/config/tools/rtems-kernel-6.cfg
+++ b/rtems/config/tools/rtems-kernel-6.cfg
@@ -2,10 +2,10 @@
 # RTEMS 6
-%define rtems_kernel_version e7cb79c39d8dbc02ded1d6d9c37ee00323508bf3
+%define rtems_kernel_version 1ef5fa07aa87adc9925c75060a7888f110104fa7
 %hash sha512 rtems-kernel-%{rtems_kernel_version}.tar.bz2 \
-       ZLKEYfCw1B7bzEMixtVB8Ire77RqdidztgGj6bX9LL/fYqfG74UNkyLl9uMK4mGKML3xOszXKn+lURAhyfDhDg==
+              5WE5sLbkU9p3atZ9PV6Dcy1TGKXZKErJ+kEfe9j6IyXohS3vc76hFIrVt8I8beDDKEogNB8HAuVsZklPv3YViA==
 # The RTEMS build instructions.
diff --git a/rtems/config/tools/rtems-libbsd-6.cfg b/rtems/config/tools/rtems-libbsd-6.cfg
index 3dfc693..c71ba07 100644
--- a/rtems/config/tools/rtems-libbsd-6.cfg
+++ b/rtems/config/tools/rtems-libbsd-6.cfg
@@ -3,9 +3,9 @@
 #  branch: 6-freebsd-12
-%define rtems_libbsd_version 1524f95e93a0e0ff85d676d214e0e57cac44e4f5
+%define rtems_libbsd_version 388d46bb1b3080402c68ae11d14b2b36c3138952
 %hash sha512 rtems-libbsd-%{rtems_libbsd_version}.tar.bz2 \
-              QiNVx1kFPcX9tmkY2mdWO2gb/t32J+AJkXOBAkyjfsaUuvBz43oMeOrpBFJuuix6eTmmukSzAulUCLdqBJlAWQ==
+              zMyTB+Z7vJXpywhCbRCK/vz2KUbwdg1JwoQ/JPqFbicmo/W42D/fGjKFxhPrzg0mL4silqSJ4xPdfOhET5vrtw==
 %define rtems_waf_version ad08908c452c6a9bbb3bf7bbbcc9fc03fe46cc7f
 %hash sha512 rtems_waf-%{rtems_waf_version}.tar.bz2 \
               EyuEit0DsAR1gK9Ki1sjl416PFgFe7dcggH3H/hmdAPmMjEIIdX7TVOTDgOIK1Pt0DW6lZ9NcW7O87GZFyy8hg==
diff --git a/rtems/config/tools/rtems-tools-6.cfg b/rtems/config/tools/rtems-tools-6.cfg
index 8abfeea..9a1c625 100644
--- a/rtems/config/tools/rtems-tools-6.cfg
+++ b/rtems/config/tools/rtems-tools-6.cfg
@@ -10,14 +10,14 @@
  %define rtems_tools_source rtems-tools-%{rtems_tools_version}
  %define rtems_tools_ext xz
 %else
- %define rtems_tools_version 12971a8
+%define rtems_tools_version 12971a8b858add612833a43360e7a7ba95902d3e
  %define rtems_tools_ext bz2
 %endif
 %source set rtems-tools https://git.rtems.org/rtems-tools/snapshot/%{rtems_tools_source}.tar.%{rtems_tools_ext}
-%hash   sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
-  SrjY0gweRgWHmqBYj0wFnu1LFkaeNeS05SD1dKVzz2kvs3UCZ6AM8DrLbVe0q4H14DZwmrE3mMgbutsVev0Oxg==
+%hash sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
+              SpaYAsHhzHncHC0tlQOJwexUJ7i+l5yG1Vf8Twl61dAyOEYhkugjvRCtchN4GJQmzPrqjqFIdwciemveysouJA==
 # Optionally enable/disable building the RTEMS Tools via the command line.
2.42.0
