[PATCH] bsps/arm: Improve GICv3 support
Tue Apr 16 08:24:41 UTC 2024
In addtion to 1023, the GICC_IAR register may return 1022 as a special value.
Simply check for a valid interrupt vector for the dispatching.
Check the GICC_IAR again after the dispatch to quickly process a next interrupt
without having to go through the interrupt prologue and epiloge.
 bsps/shared/dev/irq/arm-gicv3.c | 16 +++++++++++-----
 1 file changed, 11 insertions(+), 5 deletions(-)
diff --git a/bsps/shared/dev/irq/arm-gicv3.c b/bsps/shared/dev/irq/arm-gicv3.c
index 88ac3c8293..dcfada6cd0 100644
--- a/bsps/shared/dev/irq/arm-gicv3.c
+++ b/bsps/shared/dev/irq/arm-gicv3.c
@@ -42,12 +42,18 @@
 void bsp_interrupt_dispatch(void)
-  uint32_t icciar = READ_SR(ICC_IAR1);
-  rtems_vector_number vector = GIC_CPUIF_ICCIAR_ACKINTID_GET(icciar);
-  rtems_vector_number spurious = 1023;
+  while (true) {
+    uint32_t icciar = READ_SR(ICC_IAR1);
+    rtems_vector_number vector = GIC_CPUIF_ICCIAR_ACKINTID_GET(icciar);
+    uint32_t status;
-  if (vector != spurious) {
-    arm_interrupt_handler_dispatch(vector);
+    if (!bsp_interrupt_is_valid_vector(vector)) {
+      break;
+    status = arm_interrupt_enable_interrupts();
+    bsp_interrupt_handler_dispatch_unchecked(vector);
+    arm_interrupt_restore_interrupts(status);
     WRITE_SR(ICC_EOIR1, icciar);
2.35.3
