What to do with rtems_cache_disable_data()?
Fri Jun 21 09:35:05 UTC 2024
On 14.06.24 11:47, Sebastian Huber wrote:
> Hello,
> an user noticed that for example on the Xilinx Zynq 7000 BSP, the
> rtems_cache_disable_data() doesn't work.
> I had a look at this and managed to disable the L1 and L2 caches,
> however, afterwards I got not that far. On the Cortex-A cores it seems
> at least the L1 data cache is required to provide support for atomic
> operations:
> https://stackoverflow.com/questions/76207164/disabled-dcache-will-prevent-atomic-flag-from-being-set
> I guess we have this situation on most modern chips with caches since
> the reservation granule is usually a cache line. How do we want to deal
> with rtems_cache_disable_data() in this case? From my point of view,
> this function as no real use case and adding it in the first place was a
> mistake.
> We have a couple of options:
> * Make the rtems_cache_disable_data() directive a no-operation.
> Afterwards the cache is still enabled, and an user may get confused.
> * Issue a fatal error if someone calls rtems_cache_disable_data().
> * Really disable the cache and let the user figure out that the atomic
> operations no longer work. Disabling the data cache can be a quite
> complex thing to do.
> * Add a return status code to rtems_cache_disable_data() and let it
> return RTEMS_UNSATISFIED for example.
Removing the ability to disable the data cache leads to further issues.
Since in this case I am no longer able to test the
rtems_cache_invalidate_entire_data() function. So, if you cannot disable
the data cache, then invalidating the entire data cache needs to be a
fatal error also.
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
