Ada
Mon Jun 24 01:01:50 UTC 2024
On Sun, Jun 23, 2024, 12:43 PM John Howard <echosoft.llc at gmail.com> wrote:
> Hello.
> I need Ada for RTEMS on Raspberry Pi. I will settle for whichever versions
> work together.
> After moving to gitlab, is Ada continuously built and tested for RTEMS?
> Today, my non-gitlab RSB 5.3 build failed on Debian with error in GNAT
> 7.5.0 for the aspects.adb file. (That Python UTF-8 non-incremental parsing
> failure also occurred, but Chris Johns recently identified and fixed that
> problem.)
Building gnat is a bit tricky. You need to use a native compiler that is
the same version as what you are building cross. Sometimes it can be close
but the same is more reliable.
> I will move to gitlab only if necessary.
> -- John
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240623/1032f337/attachment.htm>
