Ada
John Howard echosoft.llc at gmail.com
Mon Jun 24 20:36:45 UTC 2024
Thanks.
I will do that.
-- John
(Sorry for all my top-posting. I try to use an iPhone. ‘nuff said.)
On Jun 23, 2024, at 8:01 PM, Joel Sherrill <joel at rtems.org> wrote:
> On Sun, Jun 23, 2024, 12:43 PM John Howard <echosoft.llc at gmail.com> wrote:
> Johns recently identified and fixed that problem.)
Building gnat is a bit tricky. You need to use a native compiler that is the same version as what you are building cross. Sometimes it can be close but the same is more reliable.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240624/bf93fd15/attachment.htm>
