removing unused third-party headers (objbsd)?
Gedare Bloom
gedare at rtems.org
Sat Jun 29 00:30:17 UTC 2024
On Fri, Jun 28, 2024 at 10:41 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Thu, Jun 27, 2024 at 11:39 PM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > On 28.06.24 00:42, Gedare Bloom wrote:
> > > I've been doing back through my third-party source code attribution.
> > > I've found that there is a chunk of header files that are apparently
> > > not included anywhere in rtems, and that are third-party headers. Is
> > > there any reason we can't get rid of them?
> > These files are included from Newlib header files and are used by the
> > legacy network stack and libbsd.
> Ok, thanks. The legacy network stack is maintenance-only. Any updates
> to these files will result in divergence and breakage?
> I think we need to split these files out of rtems.git. Likely the
> current versions need to be copied into legacy network stack, and the
> libbsd should provide its own versions?
> -Gedare
This got me to thinking there may be other header files that are
potentially not used in rtems.git, and of questionable value to keep
there:
cpukit/include/rtems/vmeintr.h
cpukit/include/rtems/spurious.h
cpukit/include/rtems/score/smplockseq.h
cpukit/include/rtems/score/smplockmcs.h
cpukit/include/rtems/rtemsdialer.h
cpukit/include/rtems/mptables.h
Anyone have insight on whether these headers are unused, or are used
in other dependent repos and should be considered for migration?
