arm/tms570ls3137_hdk_with_loader build failures
Sat Mar 9 21:39:24 UTC 2024
Hi
The build sweep using rtems-bsp-builder reports that 8 build configurations
of arm/tms570ls3137_hdk_with_loader fail. See the following for more
details.
https://lists.rtems.org/pipermail/build/2024-March/051698.html
The first reported configuration is:
1 debug arm/tms570ls3137_hdk_with_loader configure:
      configure: /home/tester/rtems-cron-6/rtems/waf configure\
      --prefix=/home/tester/rtems-cron-6/tools/6/bsps --top=/home/tester\
      /rtems-cron-6/rtems --rtems-config=config-arm-\
      tms570ls3137_hdk_with_loader-debug.ini
It would be appreciated if someone could look into that and fix it.
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240309/fd97cd23/attachment.htm>
