arm/tms570ls3137_hdk_with_loader build failures
Mon Mar 11 05:14:53 UTC 2024
On 09.03.24 22:39, Joel Sherrill wrote:
> Hi
> The build sweep using rtems-bsp-builder reports that 8 build
> configurations of arm/tms570ls3137_hdk_with_loader fail. See the
> following for more details.
> https://lists.rtems.org/pipermail/build/2024-March/051698.html
> <https://lists.rtems.org/pipermail/build/2024-March/051698.html>
> The first reported configuration is:
> 1 debug arm/tms570ls3137_hdk_with_loader configure:
>        configure: /home/tester/rtems-cron-6/rtems/waf configure\
>        --prefix=/home/tester/rtems-cron-6/tools/6/bsps --top=/home/tester\
>        /rtems-cron-6/rtems --rtems-config=config-arm-\
>        tms570ls3137_hdk_with_loader-debug.ini
> It would be appreciated if someone could look into that and fix it.
This should be fixed by:
commit 9fdaa4e7c7577710405dab0da828ff9d0710a2d0
Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
Date:   Sat Jan 20 21:55:47 2024 +0100
     config: Update BSPs
     Update #4982.
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
