arm/tms570ls3137_hdk_with_loader build failures
Mon Mar 11 14:24:55 UTC 2024
On Mon, Mar 11, 2024 at 12:14 AM Sebastian Huber <
> On 09.03.24 22:39, Joel Sherrill wrote:
> > Hi
> > The build sweep using rtems-bsp-builder reports that 8 build
> > configurations of arm/tms570ls3137_hdk_with_loader fail. See the
> > following for more details.
> > https://lists.rtems.org/pipermail/build/2024-March/051698.html
> > <https://lists.rtems.org/pipermail/build/2024-March/051698.html>
> > The first reported configuration is:
> > 1 debug arm/tms570ls3137_hdk_with_loader configure:
> >        configure: /home/tester/rtems-cron-6/rtems/waf configure\
> >        --prefix=/home/tester/rtems-cron-6/tools/6/bsps
> --top=/home/tester\
> >        /rtems-cron-6/rtems --rtems-config=config-arm-\
> >        tms570ls3137_hdk_with_loader-debug.ini
> > It would be appreciated if someone could look into that and fix it.
> This should be fixed by:
> commit 9fdaa4e7c7577710405dab0da828ff9d0710a2d0
> Author: Sebastian Huber <sebastian.huber at embedded-brains.de>
> Date:   Sat Jan 20 21:55:47 2024 +0100
>      config: Update BSPs
>      Update #4982.
Thanks. The RSB is still referencing an RTEMS tool hash from August. I will
fix that and the newlib hash once the fdset limit is pushed.
It would be nice to have a way to check that ./rtems-bsps and the
rtems-bsp-builder sets of BSPs match.
Thanks.
--joel
> embedded brains GmbH & Co. KG
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240311/4d12f2a6/attachment.htm>
