RFC: Add API to get and set interrupt priorities for interrupt vectors
Thu Mar 21 19:28:07 UTC 2024
Two basic questions:
Does the priority field type need to be Architecture- or BSP-defined
or is uint32_t always going to be fine.
Does changing (increasing) the priority of a vector from within
interrupt context possibly cause a pending interrupt to post that was
previously at a lower priority than the currently masked priority
level? In that case, it would cause a preemption to occur. I'm
guessing this behavior could be architecture-specific.
I added those questions to the ticket also.
Gedare
On Wed, Mar 20, 2024 at 2:59 AM Sebastian Huber
> Hello,
> I added a ticket for a proposal for an API to get and set interrupt
> priorities for interrupt vectors:
> https://devel.rtems.org/ticket/5002
> I would like to implement this API at least for the BSPs using the
> ARM/AArch64 GIC.
> embedded brains GmbH & Co. KG
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
> devel mailing list
> devel at rtems.org
