RFC: Add API to get and set interrupt priorities for interrupt vectors
Sebastian Huber
Mon Mar 25 08:17:23 UTC 2024
On 21.03.24 20:28, Gedare Bloom wrote:
> Two basic questions:
> Does the priority field type need to be Architecture- or BSP-defined
> or is uint32_t always going to be fine.
In theory, the priority range depends on the interrupt controller
implementation. However, an uint32_t should be more than enough. The
maximum priority value defines also the maximum interrupt nesting depth.
So, even 256 interrupt priority levels would be quite a lot.
> Does changing (increasing) the priority of a vector from within
> interrupt context possibly cause a pending interrupt to post that was
> previously at a lower priority than the currently masked priority
> level? In that case, it would cause a preemption to occur. I'm
> guessing this behavior could be architecture-specific.
This behaviour is entirely interrupt-controller specific. Changing the
priority while an interrupt is active is usually a bad idea since this
can confuse the hardware interrupt priority stack. I guess we have to
add some interrupt-controller specific information to the notes, for
example:
For the Armv7-M NVIC, there are 256 priority levels supported. The
granularity of the priority levels depends on the interrupt controller
configuration. Some lower bits of a priority value may be read-as-zero.
Interrupts with a priority value less than 128 are not disabled by the
RTEMS interrupt disable directive. Such interrupts shall not use
operating system services.
For the Arm GICv2, ...
For the Arm GICv3, ...
> I added those questions to the ticket also.
> Gedare
> On Wed, Mar 20, 2024 at 2:59 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> Hello,
>> I added a ticket for a proposal for an API to get and set interrupt
>> priorities for interrupt vectors:
>> https://devel.rtems.org/ticket/5002
>> I would like to implement this API at least for the BSPs using the
>> ARM/AArch64 GIC.
>> embedded brains GmbH & Co. KG
>> Herr Sebastian HUBER
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: sebastian.huber at embedded-brains.de
>> phone: +49-89-18 94 741 - 16
>> fax: +49-89-18 94 741 - 08
>> Registergericht: Amtsgericht München
>> Registernummer: HRB 157899
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
>> devel mailing list
>> devel at rtems.org
Dornierstr. 4
82178 Puchheim
Germany
