[PATCH 1/3] dev/serial: Simplify some Zynq UART functions
Sebastian Huber
Fri Mar 22 08:44:09 UTC 2024
Make the initialization and polled functions independent of the Termios
context. This helps to implement the kernel I/O support without a dependency
on the Termios framework.
bsps/aarch64/xilinx-zynqmp/console/console.c | 23 ++++-----------
bsps/arm/xilinx-zynq/console/debug-console.c | 15 ++--------
.../console/console-config.c | 23 ++++-----------
.../xilinx-zynqmp/console/console-config.c | 23 ++++-----------
bsps/include/dev/serial/zynq-uart-regs.h | 20 +++++++++++++
bsps/include/dev/serial/zynq-uart.h | 23 ---------------
bsps/shared/dev/serial/zynq-uart-polled.c | 28 ++++++-------------
bsps/shared/dev/serial/zynq-uart.c | 18 ++++++++----
8 files changed, 62 insertions(+), 111 deletions(-)
diff --git a/bsps/aarch64/xilinx-zynqmp/console/console.c b/bsps/aarch64/xilinx-zynqmp/console/console.c
index 9ce0b1da63..1e5df997e8 100644
--- a/bsps/aarch64/xilinx-zynqmp/console/console.c
+++ b/bsps/aarch64/xilinx-zynqmp/console/console.c
@@ -45,6 +45,7 @@
#include <bsp/irq.h>
#include <dev/serial/zynq-uart.h>
+#include <dev/serial/zynq-uart-regs.h>
#include <bspopts.h>
#include <libfdt.h>
@@ -236,42 +237,30 @@ rtems_status_code console_initialize(
void zynqmp_debug_console_flush(void)
- zynq_uart_reset_tx_flush(&zynqmp_uart_instances[BSP_CONSOLE_MINOR]);
+ zynq_uart_reset_tx_flush(zynqmp_uart_instances[BSP_CONSOLE_MINOR].regs);
static void zynqmp_debug_console_out(char c)
- rtems_termios_device_context *base =
- &zynqmp_uart_instances[BSP_CONSOLE_MINOR].base;
- zynq_uart_write_polled(base, c);
+ zynq_uart_write_char_polled(zynqmp_uart_instances[BSP_CONSOLE_MINOR].regs, c);
static void zynqmp_debug_console_init(void)
- zynq_uart_initialize(base);
+ zynq_uart_initialize(zynqmp_uart_instances[BSP_CONSOLE_MINOR].regs);
BSP_output_char = zynqmp_debug_console_out;
static void zynqmp_debug_console_early_init(char c)
zynqmp_debug_console_out(c);
static int zynqmp_debug_console_in(void)
- return zynq_uart_read_polled(base);
+ return zynq_uart_read_char_polled(zynqmp_uart_instances[BSP_CONSOLE_MINOR].regs);
BSP_output_char_function_type BSP_output_char = zynqmp_debug_console_early_init;
diff --git a/bsps/arm/xilinx-zynq/console/debug-console.c b/bsps/arm/xilinx-zynq/console/debug-console.c
index d398ca7988..4c636038af 100644
--- a/bsps/arm/xilinx-zynq/console/debug-console.c
+++ b/bsps/arm/xilinx-zynq/console/debug-console.c
@@ -44,24 +44,18 @@
static void zynq_debug_console_out(char c)
- &zynq_uart_instances[BSP_CONSOLE_MINOR].base;
+ zynq_uart_write_char_polled(zynq_uart_instances[BSP_CONSOLE_MINOR].regs, c);
static void zynq_debug_console_early_init(char c);
static void zynq_debug_console_init(void)
if (BSP_output_char != zynq_debug_console_early_init) {
return;
+ zynq_uart_initialize(zynq_uart_instances[BSP_CONSOLE_MINOR].regs);
BSP_output_char = zynq_debug_console_out;
@@ -73,10 +67,7 @@ static void zynq_debug_console_early_init(char c)
static int zynq_debug_console_in(void)
+ return zynq_uart_read_char_polled(zynq_uart_instances[BSP_CONSOLE_MINOR].regs);
BSP_output_char_function_type BSP_output_char = zynq_debug_console_early_init;
diff --git a/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c b/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
index f52e008f2b..eacf6ddcce 100644
--- a/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
+++ b/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
@@ -37,6 +37,7 @@
@@ -81,41 +82,29 @@ rtems_status_code console_initialize(
diff --git a/bsps/arm/xilinx-zynqmp/console/console-config.c b/bsps/arm/xilinx-zynqmp/console/console-config.c
index eadd7f11a2..ea148836a5 100644
--- a/bsps/arm/xilinx-zynqmp/console/console-config.c
+++ b/bsps/arm/xilinx-zynqmp/console/console-config.c
@@ -37,6 +37,7 @@
@@ -83,41 +84,29 @@ rtems_status_code console_initialize(
diff --git a/bsps/include/dev/serial/zynq-uart-regs.h b/bsps/include/dev/serial/zynq-uart-regs.h
index 3574532b85..5e872d16c3 100644
--- a/bsps/include/dev/serial/zynq-uart-regs.h
+++ b/bsps/include/dev/serial/zynq-uart-regs.h
@@ -43,6 +43,8 @@
#include <bsp/utility.h>
+#define ZYNQ_UART_DEFAULT_BAUD 115200
#define ZYNQ_UART_FIFO_DEPTH 64
typedef struct zynq_uart {
@@ -158,6 +160,24 @@ typedef struct zynq_uart {
#define ZYNQ_UART_TX_FIFO_TRG_LVL_TTRIG_SET(reg, val) BSP_FLD32SET(reg, val, 0, 5)
} zynq_uart;
+void zynq_uart_initialize(volatile zynq_uart *regs);
+int zynq_uart_read_char_polled(volatile zynq_uart *regs);
+void zynq_uart_write_char_polled(volatile zynq_uart *regs, char c);
+ * Flush TX FIFO and wait until it is empty. Used in bsp_reset.
+void zynq_uart_reset_tx_flush(volatile zynq_uart *regs);
+int zynq_cal_baud_rate(
+ uint32_t baudrate,
+ uint32_t* brgr,
+ uint32_t* bauddiv,
+ uint32_t modereg
#endif /* LIBBSP_ARM_XILINX_ZYNQ_UART_REGS_H */
diff --git a/bsps/include/dev/serial/zynq-uart.h b/bsps/include/dev/serial/zynq-uart.h
index e7854af5f1..002adcdbd6 100644
--- a/bsps/include/dev/serial/zynq-uart.h
+++ b/bsps/include/dev/serial/zynq-uart.h
@@ -59,29 +59,6 @@ typedef struct {
extern const rtems_termios_device_handler zynq_uart_handler;
-#define ZYNQ_UART_DEFAULT_BAUD 115200
-void zynq_uart_initialize(rtems_termios_device_context *base);
-int zynq_uart_read_polled(rtems_termios_device_context *base);
-void zynq_uart_write_polled(
- rtems_termios_device_context *base,
- char c
- * Flush TX FIFO and wait until it is empty. Used in bsp_reset.
-void zynq_uart_reset_tx_flush(zynq_uart_context *ctx);
-int zynq_cal_baud_rate(
- uint32_t baudrate,
- uint32_t* brgr,
- uint32_t* bauddiv,
- uint32_t modereg
#ifdef __cplusplus
#endif /* __cplusplus */
diff --git a/bsps/shared/dev/serial/zynq-uart-polled.c b/bsps/shared/dev/serial/zynq-uart-polled.c
index 7d5dd8ff1a..dbf75539f6 100644
--- a/bsps/shared/dev/serial/zynq-uart-polled.c
+++ b/bsps/shared/dev/serial/zynq-uart-polled.c
@@ -124,10 +124,8 @@ int zynq_cal_baud_rate(uint32_t baudrate,
return 0;
- zynq_uart_context *ctx = (zynq_uart_context *) base;
- volatile zynq_uart *regs = ctx->regs;
uint32_t brgr = 0x3e;
uint32_t bauddiv = 0x6;
uint32_t mode_clks = regs->mode & ZYNQ_UART_MODE_CLKS;
@@ -154,18 +152,15 @@ void zynq_uart_initialize(rtems_termios_device_context *base)
| ZYNQ_UART_MODE_CHRL(ZYNQ_UART_MODE_CHRL_8)
| mode_clks;
- while (zynq_uart_read_polled(base) >= 0) {
+ while (zynq_uart_read_char_polled(regs) >= 0) {
/* Drop */
- zynq_uart_reset_tx_flush(ctx);
+ zynq_uart_reset_tx_flush(regs);
if ((regs->channel_sts & ZYNQ_UART_CHANNEL_STS_REMPTY) != 0) {
return -1;
} else {
@@ -173,14 +168,8 @@ int zynq_uart_read_polled(rtems_termios_device_context *base)
- char c
while ((regs->channel_sts & ZYNQ_UART_CHANNEL_STS_TNFUL) != 0) {
/* Wait */
@@ -188,13 +177,12 @@ void zynq_uart_write_polled(
regs->tx_rx_fifo = ZYNQ_UART_TX_RX_FIFO_FIFO(c);
- int c = 4;
+ int c = 4;
while (c-- > 0)
- zynq_uart_write_polled(&ctx->base, '\r');
+ zynq_uart_write_char_polled(regs, '\r');
while ((regs->channel_sts & ZYNQ_UART_CHANNEL_STS_TEMPTY) == 0 ||
(regs->channel_sts & ZYNQ_UART_CHANNEL_STS_TACTIVE) != 0) {
diff --git a/bsps/shared/dev/serial/zynq-uart.c b/bsps/shared/dev/serial/zynq-uart.c
index 390ee1f527..0489288271 100644
--- a/bsps/shared/dev/serial/zynq-uart.c
+++ b/bsps/shared/dev/serial/zynq-uart.c
@@ -67,14 +67,14 @@ static bool zynq_uart_first_open(
rtems_libio_open_close_args_t *args
-#ifdef ZYNQ_CONSOLE_USE_INTERRUPTS
+#ifdef ZYNQ_CONSOLE_USE_INTERRUPTS
rtems_status_code sc;
#endif
rtems_termios_set_initial_baud(tty, ZYNQ_UART_DEFAULT_BAUD);
+ zynq_uart_initialize(regs);
regs->rx_fifo_trg_lvl = 1;
@@ -109,15 +109,23 @@ static void zynq_uart_last_close(
#endif
+#ifndef ZYNQ_CONSOLE_USE_INTERRUPTS
+static int zynq_uart_read_polled(rtems_termios_device_context *base)
+ zynq_uart_context *ctx = (zynq_uart_context *) base;
+ return zynq_uart_read_char_polled(ctx->regs);
+#endif
static void zynq_uart_write_support(
const char *buf,
size_t len
regs->irq_dis = ZYNQ_UART_TEMPTY;
@@ -135,9 +143,9 @@ static void zynq_uart_write_support(
regs->irq_en = ZYNQ_UART_TEMPTY;
#else
- ssize_t i;
+ size_t i;
for (i = 0; i < len; ++i) {
- zynq_uart_write_polled(base, buf[i]);
+ zynq_uart_write_char_polled(regs, buf[i]);
#endif
2.35.3
