[PATCH 2/3] dev/serial: Add ZYNQ_UART_[01]_BASE_ADDR
Mon Mar 25 06:31:31 UTC 2024
On 22.03.24 16:10, Kinsey Moore wrote:
> Putting these UART addresses in BSP options suggests that they're
> user-configurable when they aren't. ZynqMP can use the ZYNQMP_UART0/1
> from bsps/include/peripheral_maps/xilinx_zynqmp.h, but Zynq would need
> its own peripheral map to reference.
This UART support is used by four BSP families. Currently a lot of copy
and past is involved. Defining the two UART base addresses though a BSP
option was the easiest approach I found to do this. I would remove the
xilinx_zynqmp.h header file since normally you use the xparameters.h for
your application depending on the system configuration.
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
