[PATCH v2 2/3] dev/serial: Add ZYNQ_UART_[01]_BASE_ADDR
Kinsey Moore kinsey.moore at oarcorp.com
Thu Mar 28 15:48:41 UTC 2024
This patch set looks good to me. I'd suggest a different file for the
versal unless there's a good name that can easily cover both.
Kinsey
On Wed, Mar 27, 2024 at 9:26 PM Chris Johns <chrisj at rtems.org> wrote:
> On 28/3/2024 6:43 am, Sebastian Huber wrote:
> > This helps to provide a shared implementation of the kernel I/O support.
> >  bsps/aarch64/xilinx-zynqmp/console/console.c  |  4 +-
> >  bsps/aarch64/xilinx-zynqmp/include/bsp.h      |  2 +
> >  bsps/arm/xilinx-zynq/console/console-config.c |  5 +-
> >  bsps/arm/xilinx-zynq/include/bsp.h            |  1 +
> >  .../console/console-config.c                  |  4 +-
> >  bsps/arm/xilinx-zynqmp-rpu/include/bsp.h      |  2 +
> >  .../xilinx-zynqmp/console/console-config.c    |  4 +-
> >  bsps/arm/xilinx-zynqmp/include/bsp.h          |  2 +
> >  bsps/include/dev/serial/zynq-uart-zynq.h      | 66 +++++++++++++++++++
> >  bsps/include/dev/serial/zynq-uart-zynqmp.h    | 66 +++++++++++++++++++
> >  10 files changed, 148 insertions(+), 8 deletions(-)
> >  create mode 100644 bsps/include/dev/serial/zynq-uart-zynq.h
> >  create mode 100644 bsps/include/dev/serial/zynq-uart-zynqmp.h
> > diff --git a/bsps/aarch64/xilinx-zynqmp/console/console.c
> b/bsps/aarch64/xilinx-zynqmp/console/console.c
> > index 1e5df997e8..ce031a914e 100644
> > --- a/bsps/aarch64/xilinx-zynqmp/console/console.c
> > +++ b/bsps/aarch64/xilinx-zynqmp/console/console.c
> > @@ -188,11 +188,11 @@ RTEMS_SYSINIT_ITEM(
> >  static zynq_uart_context zynqmp_uart_instances[2] = {
> >      .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( "Zynq UART 0" ),
> > -    .regs = (volatile struct zynq_uart *) 0xff000000,
> > +    .regs = (volatile zynq_uart *) ZYNQ_UART_0_BASE_ADDR,
> >      .irq = ZYNQMP_IRQ_UART_0
> >      .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( "Zynq UART 1" ),
> > -    .regs = (volatile struct zynq_uart *) 0xff010000,
> > +    .regs = (volatile zynq_uart *) ZYNQ_UART_1_BASE_ADDR,
> >      .irq = ZYNQMP_IRQ_UART_1
> > diff --git a/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> > index 0ccca8b196..38a9fad768 100644
> > --- a/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> > +++ b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> > @@ -55,6 +55,8 @@
> >  #include <rtems.h>
> >  #include <rtems/termiostypes.h>
> > +#include <dev/serial/zynq-uart-zynqmp.h>
> >  #ifdef __cplusplus
> >  extern "C" {
> >  #endif /* __cplusplus */
> > diff --git a/bsps/arm/xilinx-zynq/console/console-config.c
> b/bsps/arm/xilinx-zynq/console/console-config.c
> > index d22ceb557d..42e64ee4dd 100644
> > --- a/bsps/arm/xilinx-zynq/console/console-config.c
> > +++ b/bsps/arm/xilinx-zynq/console/console-config.c
> > @@ -35,15 +35,16 @@
> >  #include <bsp/irq.h>
> >  #include <dev/serial/zynq-uart.h>
> > +#include <dev/serial/zynq-uart-regs.h>
> >  zynq_uart_context zynq_uart_instances[2] = {
> > -    .regs = (volatile struct zynq_uart *) 0xe0000000,
> >      .irq = ZYNQ_IRQ_UART_0
> > -    .regs = (volatile struct zynq_uart *) 0xe0001000,
> >      .irq = ZYNQ_IRQ_UART_1
> > diff --git a/bsps/arm/xilinx-zynq/include/bsp.h
> b/bsps/arm/xilinx-zynq/include/bsp.h
> > index 3311a99b50..5ffd5f573a 100644
> > --- a/bsps/arm/xilinx-zynq/include/bsp.h
> > +++ b/bsps/arm/xilinx-zynq/include/bsp.h
> > @@ -55,6 +55,7 @@
> >  #include <bsp/default-initial-extension.h>
> >  #include <bsp/start.h>
> > +#include <dev/serial/zynq-uart-zynq.h>
> >  #ifdef __cplusplus
> >  extern "C" {
> > diff --git a/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
> b/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
> > index eacf6ddcce..13eaa269c5 100644
> > --- a/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
> > +++ b/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
> > @@ -44,11 +44,11 @@
> > diff --git a/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
> b/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
> > index e386bd4b26..d80cedbd0d 100644
> > --- a/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
> > +++ b/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
> > @@ -61,6 +61,8 @@
> >  #include <peripheral_maps/xilinx_zynqmp.h>
> >  #ifdef __cplusplus
> >  extern "C" {
> > diff --git a/bsps/arm/xilinx-zynqmp/console/console-config.c
> b/bsps/arm/xilinx-zynqmp/console/console-config.c
> > index ea148836a5..787ee05dd6 100644
> > --- a/bsps/arm/xilinx-zynqmp/console/console-config.c
> > +++ b/bsps/arm/xilinx-zynqmp/console/console-config.c
> > @@ -44,11 +44,11 @@
> > +    .regs = (volatile struct zynq_uart *) ZYNQ_UART_0_BASE_ADDR,
> > +    .regs = (volatile struct zynq_uart *) ZYNQ_UART_1_BASE_ADDR,
> > diff --git a/bsps/arm/xilinx-zynqmp/include/bsp.h
> b/bsps/arm/xilinx-zynqmp/include/bsp.h
> > index a08a5feee9..cdc37b79a4 100644
> > --- a/bsps/arm/xilinx-zynqmp/include/bsp.h
> > +++ b/bsps/arm/xilinx-zynqmp/include/bsp.h
> > @@ -60,6 +60,8 @@
> >  #ifdef __cplusplus
> >  extern "C" {
> > diff --git a/bsps/include/dev/serial/zynq-uart-zynq.h
> b/bsps/include/dev/serial/zynq-uart-zynq.h
> > new file mode 100644
> > index 0000000000..169037b33a
> > --- /dev/null
> > +++ b/bsps/include/dev/serial/zynq-uart-zynq.h
> > @@ -0,0 +1,66 @@
> > +/* SPDX-License-Identifier: BSD-2-Clause */
> > + * @file
> > + * @ingroup zynq_uart
> > + * @brief This header file provides interfaces with respect to the Zynq
> > + *   platform.
> > + * Copyright (C) 2024 embedded brains GmbH & Co. KG
> > + * Redistribution and use in source and binary forms, with or without
> > + * modification, are permitted provided that the following conditions
> > + * are met:
> > + * 1. Redistributions of source code must retain the above copyright
> > + *    notice, this list of conditions and the following disclaimer.
> > + * 2. Redistributions in binary form must reproduce the above copyright
> > + *    notice, this list of conditions and the following disclaimer in
> the
> > + *    documentation and/or other materials provided with the
> distribution.
> > + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> > + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
> TO, THE
> > + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> > + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
> CONTRIBUTORS BE
> > + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> > + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> > + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> > + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
> IN
> > + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
> OTHERWISE)
> > + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
> OF THE
> > + * POSSIBILITY OF SUCH DAMAGE.
> > +#ifndef _DEV_SERIAL_ZYNQ_UART_ZYNQ_H
> > +#define _DEV_SERIAL_ZYNQ_UART_ZYNQ_H
> > +#ifdef __cplusplus
> > +extern "C" {
> > +#endif /* __cplusplus */
> > + * @addtogroup zynq_uart
> > + * @brief This constant defines the Xilinx Zynq UART 0 base address.
> > +#define ZYNQ_UART_0_BASE_ADDR 0xe0000000
> > + * @brief This constant defines the Xilinx Zynq UART 1 base address.
> > +#define ZYNQ_UART_1_BASE_ADDR 0xe0001000
> > +#ifdef __cplusplus
> > +#endif /* _DEV_SERIAL_ZYNQ_UART_ZYNQ_H */
> > diff --git a/bsps/include/dev/serial/zynq-uart-zynqmp.h
> b/bsps/include/dev/serial/zynq-uart-zynqmp.h
> > index 0000000000..9f29003053
> > --- /dev/null
> > +++ b/bsps/include/dev/serial/zynq-uart-zynqmp.h
> > @@ -0,0 +1,66 @@
> > + * @file
> > + *   UltraScale+ MPSoC and RFSoC platforms.
> > + * are met:
> the
> distribution.
> "AS IS"
> TO, THE
> PURPOSE
> CONTRIBUTORS BE
> BUSINESS
> IN
> OTHERWISE)
> OF THE
> > +#ifndef _DEV_SERIAL_ZYNQ_UART_ZYNQMP_H
> > +#define _DEV_SERIAL_ZYNQ_UART_ZYNQMP_H
> > +#ifdef __cplusplus
> > +extern "C" {
> > +#define ZYNQ_UART_0_BASE_ADDR 0xff000000
> > +#define ZYNQ_UART_1_BASE_ADDR 0xff010000
> This is the same as the Versal so is the name of this file OK for use in
> the
> Versal? I do not have a better name?
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240328/49269be6/attachment-0001.htm>
