[PATCH] Fix the CPU count calculation error.
zhengxiaojun 17935334 at qq.com
Tue May 7 04:02:27 UTC 2024
在 2024/4/19 16:50, Sebastian Huber 写道:
> On 19.04.24 09:16, zhengxiaojun wrote:
>> I tested on arm64, the cpu_count do not increase when
>> (redist->icrtyper & GIC_REDIST_ICRTYPER_LAST != 0),but it is the last
>> core.
> The current code assumes that you have exactly one interrupt export
                                          I'm not quite clear about it.
Could you explain it?
> port. With which SoC are you working currently? One option could be to
> make the number of interrupt export ports configurable.
