[PATCH 2/2] hw/intc/arm_gic: Fix writes to GICD_ITARGETSRn
Tue May 7 12:56:24 UTC 2024
According to the GICv2 specification section 4.3.12, "Interrupt Processor
Targets Registers, GICD_ITARGETSRn":
"Any change to a CPU targets field value:
* Has an effect on any pending interrupts. This means:
  - adding a CPU interface to the target list of a pending interrupt makes that
    interrupt pending on that CPU interface
  - removing a CPU interface from the target list of a pending interrupt
    removes the pending state of that interrupt on that CPU interface."
Signed-off-by: Sebastian Huber <sebastian.huber at embedded-brains.de>
 hw/intc/arm_gic.c | 7 +++++++
 1 file changed, 7 insertions(+)
diff --git a/hw/intc/arm_gic.c b/hw/intc/arm_gic.c
index 20b3f701e0..79aee56053 100644
--- a/hw/intc/arm_gic.c
+++ b/hw/intc/arm_gic.c
@@ -1397,6 +1397,13 @@ static void gic_dist_writeb(void *opaque, hwaddr offset,
                 value = ALL_CPU_MASK;
             s->irq_target[irq] = value & ALL_CPU_MASK;
+            if (irq >= GIC_INTERNAL && s->irq_state[irq].pending) {
+                 * Changing the target of an interrupt that is currently
+                 * pending updates the set of CPUs it is pending on.
+                GIC_DIST_SET_PENDING(irq, value);
     } else if (offset < 0xf00) {
         /* Interrupt Configuration.  */
2.35.3
