[PATCH 1/2] hw/intc/arm_gic: Fix set pending of PPIs
Sebastian Huber
Tue May 7 12:56:23 UTC 2024
According to the GICv2 specification section 4.3.7, "Interrupt Set-Pending
Registers, GICD_ISPENDRn":
"In a multiprocessor implementation, GICD_ISPENDR0 is banked for each connected
processor. This register holds the Set-pending bits for interrupts 0-31."
Signed-off-by: Sebastian Huber <sebastian.huber at embedded-brains.de>
hw/intc/arm_gic.c | 4 +++-
1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/hw/intc/arm_gic.c b/hw/intc/arm_gic.c
index 4da5326ed6..20b3f701e0 100644
--- a/hw/intc/arm_gic.c
+++ b/hw/intc/arm_gic.c
@@ -1296,12 +1296,14 @@ static void gic_dist_writeb(void *opaque, hwaddr offset,
for (i = 0; i < 8; i++) {
if (value & (1 << i)) {
+ int cm = (irq < GIC_INTERNAL) ? (1 << cpu) : ALL_CPU_MASK;
if (s->security_extn && !attrs.secure &&
!GIC_DIST_TEST_GROUP(irq + i, 1 << cpu)) {
continue; /* Ignore Non-secure access of Group0 IRQ */
- GIC_DIST_SET_PENDING(irq + i, GIC_DIST_TARGET(irq + i));
+ GIC_DIST_SET_PENDING(irq + i, cm);
} else if (offset < 0x300) {
2.35.3
