Improvements to SMP under the arch64 architecture
Wed May 8 14:36:31 UTC 2024
On 08.05.24 08:17, Sebastian Huber wrote:
> Hello,
> on the arm target, we use this:
> static inline struct Per_CPU_Control *_ARM_Get_current_per_CPU_control(
> void )
>    struct Per_CPU_Control *cpu_self;
>    /* Use PL1 only Thread ID Register (TPIDRPRW) */
>    __asm__ volatile (
>      "mrc p15, 0, %0, c13, c0, 4"
>      : "=r" ( cpu_self )
>    return cpu_self;
> to access the per-CPU control. I guess, AArch64 has also a thread ID
> register available for operating system use. With this we could
> implement _CPU_Get_current_processor() like this:
> return _Per_CPU_Get_index( _CPU_Get_current_per_CPU_control() );
> The BSP-specific startup code has to decode the MPIDR and set the thread
> ID register accordingly.
If we assume that we always run in EL1 or higher, then we can use the
TPIDR_EL1 for an _AArch64_Get_current_per_CPU_control().
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
