BBB: "sd" command
Jarielle Catbagan jcatbagan93 at gmail.com
Tue Aug 4 00:52:24 UTC 2015
On Mon, Aug 3, 2015 at 5:30 PM, Ed Sutter <edsutterjr at gmail.com> wrote:
> Jarielle,
> Couple of things...
> - Just realized that I didn't test the 'sd cmd' command; however that's
> really only needed for
>   "special" interaction with the card.
As of right now, I didn't implement 'sd cmd' as it would require
modifying the core sd.c file.  The response content and length are
different in SD mode as opposed to SPI mode.  Perhaps, this could be
generalized to include SD mode as well?
> - I pushed two additional small fixes in the core code related to stuff I
> put in with the original
> tree.  A warning fix in xmodem.c and a fix for the verbose help text in the
> sd command.
Thanks!  I will pull in the changes to my local branch.
> Ed
> umon-devel mailing list
> umon-devel at rtems.org
> http://lists.rtems.org/mailman/listinfo/umon-devel
More information about the umon-devel mailing list
