BBB: "sd" command
Ed Sutter edsutterjr at gmail.com
Tue Aug 4 01:04:54 UTC 2015
Thinking about it...
I don't even know what we would need the "cmd" command for anyway;
so, for now, I suggest you just move on to Ethernet.
(it's your call)
Ed
> On Mon, Aug 3, 2015 at 5:30 PM, Ed Sutter <edsutterjr at gmail.com> wrote:
>> Jarielle,
>> Couple of things...
>> - Just realized that I didn't test the 'sd cmd' command; however that's
>> really only needed for
>>    "special" interaction with the card.
> As of right now, I didn't implement 'sd cmd' as it would require
> modifying the core sd.c file.  The response content and length are
> different in SD mode as opposed to SPI mode.  Perhaps, this could be
> generalized to include SD mode as well?
>> - I pushed two additional small fixes in the core code related to stuff I
>> put in with the original
>> tree.  A warning fix in xmodem.c and a fix for the verbose help text in the
>> sd command.
> Thanks!  I will pull in the changes to my local branch.
>> Ed
>> umon-devel mailing list
>> umon-devel at rtems.org
>> http://lists.rtems.org/mailman/listinfo/umon-devel
More information about the umon-devel mailing list
