BBB: Add "mmc" command that interfaces to the onboard eMMC
Ed Sutter ed.sutter at alcatel-lucent.com
Tue Aug 4 18:35:57 UTC 2015
Outstanding!!!
> I just want to add that I was able to transfer the uMon image from the
> SD card to the eMMC.  I then removed the SD card and power-cycled the
> BBB, and I was able to boot uMon from the eMMC.
> The sequence steps I took are as follows:
>          sd init
>          mmc init
>          sd read 0x80100000 0 102
>          mmc write 0x80100000 0 102
> The '102' is the number of 512 byte blocks required to transfer the uMon image.
> On Tue, Aug 4, 2015 at 11:03 AM, Jarielle Catbagan
> <jcatbagan93 at gmail.com> wrote:
>> These series of patches add the "mmc" command which is the interface to the onboard eMMC on the BBB.
>> The "mmc" command is implemented with initialization, reading, and writing functionality.
>> Furthermore, the MMC0 and MMC1 clock enable are moved to initCPUio() in cpuio.c to ensure that the
>> MMC modules are enabled before they are accessed.
> umon-devel mailing list
> umon-devel at rtems.org
> http://lists.rtems.org/mailman/listinfo/umon-devel
More information about the umon-devel mailing list
