BBB: Add "mmc" command that interfaces to the onboard eMMC
Ed Sutter edsutterjr at gmail.com
Tue Aug 4 23:17:36 UTC 2015
Jarielle,
Great!  Looks good.  Couple of thoughts...
- Similar to the sd command, the outer edges of the mmc command code should probably be in the main/common
   directory as mmc.c; but for now I pushed it as is.
- I turned on INCLUDE_XMODEM in config.h just so that we can update without pulling the uSD card all the time.
- Should the 'write' command for sd and mmc include a "are you sure?" prompt?  I'm mixed on that one.
   That was optionally covered by the user levels in uMon a while ago, so maybe we just leave it for that
   (making it up to the user).
Hey, this is really shaping up!!!
Good work.  Its all pulled into the master.
Ed
> I just want to add that I was able to transfer the uMon image from the
> SD card to the eMMC.  I then removed the SD card and power-cycled the
> BBB, and I was able to boot uMon from the eMMC.
> The sequence steps I took are as follows:
>          sd init
>          mmc init
>          sd read 0x80100000 0 102
>          mmc write 0x80100000 0 102
> The '102' is the number of 512 byte blocks required to transfer the uMon image.
> On Tue, Aug 4, 2015 at 11:03 AM, Jarielle Catbagan
> <jcatbagan93 at gmail.com> wrote:
>> These series of patches add the "mmc" command which is the interface to the onboard eMMC on the BBB.
>> The "mmc" command is implemented with initialization, reading, and writing functionality.
>> Furthermore, the MMC0 and MMC1 clock enable are moved to initCPUio() in cpuio.c to ensure that the
>> MMC modules are enabled before they are accessed.
> umon-devel mailing list
> umon-devel at rtems.org
> http://lists.rtems.org/mailman/listinfo/umon-devel
More information about the umon-devel mailing list
