target version...
Jarielle Catbagan
jcatbagan93 at gmail.com
Thu Aug 6 01:11:15 UTC 2015
On Aug 5, 2015 5:57 PM, "Ed Sutter" <edsutterjr at gmail.com> wrote:
> Jarielle,
> I just noticed that the target_version.h file still had remnants of
csb740,
> so I cleared it out, and set the target version to zero.
> Typically I don't start incrementing that number until the port is
complete.
> Then it changes to '1', and usually only increments if there are bug fixes
> or features added to the port.
Thanks for the clarification, I will be keeping that in mind.
> Also, the main/glib code is updated. This should be transparent to you,
> but I figured I'd let you know in case you notice the changes...
> I did this to clean up some question on where the files that I didn't
write
> came from (most are BSD, but a few are elsewhere). This is documented in
> the getglib script in that directory.
> Ed
Thanks for the update. I'll make sure to pull in the changes to my local
branch.
> umon-devel mailing list
> umon-devel at rtems.org
> http://lists.rtems.org/mailman/listinfo/umon-devel
URL: <http://lists.rtems.org/pipermail/umon-devel/attachments/20150805/ae017746/attachment.html>
More information about the umon-devel
