Update: uMon is now booting from SD
Jarielle Catbagan jcatbagan93 at gmail.com
Wed Jul 8 01:39:12 UTC 2015
Ed,
Thank you.
I actually already finished the next set of drafts of the files and
modified the Makefile to build a uMon image for "raw" mode booting, as
well as updated the script to provide the ability to setup the SD for
either "raw" or FAT mode.
By coincidence I also created a configuration header source file when
I was updating the Makefile in order to build the "raw" mode image.  I
was able to boot from an SD card using both modes that was set up
using the script.
The files I updated/created are as follows:
README: https://github.com/jrcatbagan/umon/blob/dev/ports/beagleboneblack/README
config_header.S:
https://github.com/jrcatbagan/umon/blob/dev/ports/beagleboneblack/config_header.S
sd-setup.sh: https://github.com/jrcatbagan/umon/blob/dev/ports/beagleboneblack/sd-setup.sh
And these are the changes I made to the Makefile to build the image
for "raw" mode:
https://github.com/jrcatbagan/umon/commit/8246293254e3ce9e37cb8ed314077f35888af58c
Let me know what you think so far about the changes/additions.  If
they are ready, I'll be happy to send them to you as patches for
further testing/review.
Thanks.
On Tue, Jul 7, 2015 at 5:40 PM, Ed Sutter <edsutterjr at gmail.com> wrote:
> Jarielle,
> Since I already did it, attached is the cfg_header.S file I used for raw
> mode.
> Ed
> On Jul 7, 2015 4:49 AM, "Ed Sutter" <ed.sutter at alcatel-lucent.com> wrote:
>> Jarielle,
>> Great!
>> Two (last) minor suggestions...
>> 1. Mention the script in the documentation file.
>> 2. In the script you may as well include the final step that you have in
>> the documentation
>> for copying the MLO file to the card...
>>    cd ~
>>    mkdir mnt
>>    rmdir mnt
>> Other than that, it looks good to me.
>> Good hunting regarding the cluster error issue!
>> Ed
> Thanks.  Doc and script are now updated to reflect the minor suggestions.  I
> added a part in the "FAT Mode" section to refer to the script and I added
> the last remaining steps in the doc to the script.  The links to the files
> are the same as before.
> How are the doc and script so far?
> Just for completeness, I'm going to get the raw mode image built as well
> with the Configuration Header and GP Header prepended.  I'm thinking of also
> updating the script even further to allow the user to select whether they
> would want to format the SD card for "raw" or FAT mode.
> I'll then send another draft of the files for your review.
>>> Ed,
>>> Thank you for your suggestions.  I have taken them into account when
>>> improving the document.
>>> Here is the second draft of the doc:
>>> I have also created a script that automates the process of setting up
>>> the SD card.  It can be found here:
>>> I also looked into the error regarding the situation where there is
>>> not enough clusters and it turns out that the minimum size for the
>>> FAT32 primary partition is around 32MB.  FAT16 on the other hand has a
>>> minimum size of around 3MB.  I was using this document as reference:
>>> https://staff.washington.edu/dittrich/misc/fatgen103.pdf .   So I went
>>> ahead and had the script create the primary partition as FAT16.  I was
>>> able to boot uMon from an SD card that was setup with this script.
>>> Please let me know what you think about the doc and script so far.
>>> Thanks.
>>> On Mon, Jul 6, 2015 at 5:10 PM, Ed Sutter <edsutterjr at gmail.com> wrote:
>>>> Jarielle,
>>>> Excellent!
>>>> Couple of  comments...
>>>> 1. Since you've got so much detail in there, you may want to include the
>>>> names of
>>>> the TRM chapter and sections that you reference.  I say this because a
>>>> later
>>>> revision may insert
>>>> a chapter or a section and that will make the chapter/section numbers
>>>> you
>>>> have confusing.
>>>> 2. For raw mode description, in the 'dd' line, change "of=/dev/sdc" to
>>>> "of=<device>" (where <device> is the sd card).
>>>> 3. For fat mode description, you may want to add a "dd if=/dev/zero
>>>> of=<device> bs=1M count=1" as the first step just to
>>>>       make sure there is no partition table at the base of the SD card.
>>>> If
>>>> there is, then the first 'n' in your instructions
>>>>       may not do what you want.  I know you mention that the card is
>>>> assumed
>>>> to not be formatted.  This just
>>>>       makes sure of that.  So, I walked through your steps, using this
>>>> to
>>>> automate:
>>>> export SDDEV=/dev/sdc  # User should verify this device.
>>>> sudo dd if=/dev/zero of=${SDDEV} bs=128K count=1
>>>> echo "n\np\n1\n\n+1M\nt\nc\na\n1\np\nw\n" | fdisk ${SDDEV}
>>>>       But when I did the mkfs line in your text, it returned an error:
>>>> Not
>>>> enough clusters for a 32bit FAT.
>>>>       So, I just did "mkfs.vfat /dev/sdc1" and that worked fine.
>>>> Honestly, I
>>>> don't know the details here,
>>>>       so if you can investigate this, that would be great.  Suggest
>>>> adding
>>>> something like the script above as
>>>>       a shortcut.
>>>> 4. For UART boot mode, mention that the uMon image that is transferred
>>>> is
>>>> boot.bin, not the MLO.
>>>> Some other stuff you could add:
>>>> - To know for sure what device is your uSD card in your linux box, run
>>>> "cat
>>>> /proc/partitions" before and after
>>>> inserting the card and note the difference.
>>>> Good stuff,
>>>> Ed
>>>> Ed,
>>>> I finished the first draft of the document.  It can be found here:
>>>> https://github.com/jrcatbagan/umon/commit/7f751486d5ca3ba5f6449adf5561df527a5cfde1
>>>> . Please feel free to give me any suggestions on how I can improve it
>>>> or if I am missing something.  Once you give the green light, I'll
>>>> send it to umon-devel as a patch.
>>>> Thanks.
>>>> On Mon, Jul 6, 2015 at 5:21 AM, Ed Sutter <ed.sutter at alcatel-lucent.com>
>>>> wrote:
>>>> On 7/5/2015 6:46 PM, Chris Johns wrote:
>>>> On 5/07/2015 4:19 am, Ed Sutter wrote:
>>>> Ok, I managed to get it to boot using only Linux for formatting the
>>>> card.
>>>> It wasn't working for me until I just read your email and realized I did
>>>> not mark
>>>> the partition active.  After doing that it booted!
>>>> So here are the steps I walked through
>>>> (extracted from:
>>>> http://forum.xda-developers.com/showthread.php?t=502095)
>>>> 1. Verify the partition that the SD card installs as:
>>>>        - cat /proc/paritions (without the uSD)
>>>>        - Insert uSD card
>>>>        - cat /proc/paritions (note the difference)
>>>> Using /dev/sdc as our partition:
>>>> 2. sudo fdisk /dev/sdc
>>>>       - delete all paritions with 'd' command (d1/d2/d3/d4) as needed
>>>>       - use 'n' command to create partition 1
>>>>       - use 't' command to relabel partition 1 to 'c'
>>>>       - use 'a' command to make the parition active
>>>>       - use 'p' to show something like:
>>>>      Device Boot      Start         End      Blocks   Id  System
>>>> /dev/sdc1   *        2048     3932159     1965056    c  W95 FAT32 (LBA)
>>>>        - use 'w' to write to the card
>>>> 3. Run sudo mkfs.vfat /dev/sdc1
>>>> 4. Mount /dev/sdc1 as /media/boot (or whatever)
>>>> 5. Copy MLO to /media/boot
>>>> 6. Run sync; unmount /media/boot
>>>> 7. Put card in BBB, reset with boot button depressed.
>>>> A simple request to place in the doco early is to create a root
>>>> partition only as large as you need and not use whole disk size in the
>>>> root partition. Users should be encouraged to add other partitions they
>>>> can mount as read/write to store a kernel and/or user data.
>>>> Chris
>>>> _______________________________________________
>>>> Yep, for sure... my example above was lame...
>>>> Functionally ok, but not considering the fact that the SD card will have
>>>> other "stuff".  Also, Chris, IIRC, you mentioned that FAT-booting may
>>>> not be
>>>> the right way to go ultimately.  So, for now at least, it will be good
>>>> to
>>>> cover
>>>> both modes of booting until we get a better grip on which approach to
>>>> take.
>>>> Jarielle, I can add detail on raw mode to whatever you initially write
>>>> up
>>>> if you want me to...
>>>> Ed
>>>> umon-devel mailing list
>>>> umon-devel at rtems.org
>>>> http://lists.rtems.org/mailman/listinfo/umon-devel
More information about the umon-devel mailing list
