Update: uMon is now booting from SD
Ed Sutter edsutterjr at gmail.com
Wed Jul 8 10:59:16 UTC 2015
Jarielle,
Ok, great, just thought I'd save you some typing, but you beat me to it!
The files look excellent!
Ed
> Ed,
> Thank you.
> I actually already finished the next set of drafts of the files and
> modified the Makefile to build a uMon image for "raw" mode booting, as
> well as updated the script to provide the ability to setup the SD for
> either "raw" or FAT mode.
> By coincidence I also created a configuration header source file when
> I was updating the Makefile in order to build the "raw" mode image.  I
> was able to boot from an SD card using both modes that was set up
> using the script.
> The files I updated/created are as follows:
> README: https://github.com/jrcatbagan/umon/blob/dev/ports/beagleboneblack/README
> config_header.S:
> https://github.com/jrcatbagan/umon/blob/dev/ports/beagleboneblack/config_header.S
> sd-setup.sh: https://github.com/jrcatbagan/umon/blob/dev/ports/beagleboneblack/sd-setup.sh
> And these are the changes I made to the Makefile to build the image
> for "raw" mode:
> https://github.com/jrcatbagan/umon/commit/8246293254e3ce9e37cb8ed314077f35888af58c
> Let me know what you think so far about the changes/additions.  If
> they are ready, I'll be happy to send them to you as patches for
> further testing/review.
> Thanks.
> On Tue, Jul 7, 2015 at 5:40 PM, Ed Sutter <edsutterjr at gmail.com> wrote:
>> Jarielle,
>> Since I already did it, attached is the cfg_header.S file I used for raw
>> mode.
>> Ed
>> On Jul 7, 2015 4:49 AM, "Ed Sutter" <ed.sutter at alcatel-lucent.com> wrote:
>>> Jarielle,
>>> Great!
>>> Two (last) minor suggestions...
>>> 1. Mention the script in the documentation file.
>>> 2. In the script you may as well include the final step that you have in
>>> the documentation
>>> for copying the MLO file to the card...
>>>     cd ~
>>>     mkdir mnt
>>>     rmdir mnt
>>> Other than that, it looks good to me.
>>> Good hunting regarding the cluster error issue!
>>> Ed
>> Thanks.  Doc and script are now updated to reflect the minor suggestions.  I
>> added a part in the "FAT Mode" section to refer to the script and I added
>> the last remaining steps in the doc to the script.  The links to the files
>> are the same as before.
>> How are the doc and script so far?
>> Just for completeness, I'm going to get the raw mode image built as well
>> with the Configuration Header and GP Header prepended.  I'm thinking of also
>> updating the script even further to allow the user to select whether they
>> would want to format the SD card for "raw" or FAT mode.
>> I'll then send another draft of the files for your review.
>>>> Ed,
>>>> Thank you for your suggestions.  I have taken them into account when
>>>> improving the document.
>>>> Here is the second draft of the doc:
>>>> I have also created a script that automates the process of setting up
>>>> the SD card.  It can be found here:
>>>> I also looked into the error regarding the situation where there is
>>>> not enough clusters and it turns out that the minimum size for the
>>>> FAT32 primary partition is around 32MB.  FAT16 on the other hand has a
>>>> minimum size of around 3MB.  I was using this document as reference:
>>>> https://staff.washington.edu/dittrich/misc/fatgen103.pdf .   So I went
>>>> ahead and had the script create the primary partition as FAT16.  I was
>>>> able to boot uMon from an SD card that was setup with this script.
>>>> Please let me know what you think about the doc and script so far.
>>>> Thanks.
>>>> On Mon, Jul 6, 2015 at 5:10 PM, Ed Sutter <edsutterjr at gmail.com> wrote:
>>>>> Jarielle,
>>>>> Excellent!
>>>>> Couple of  comments...
>>>>> 1. Since you've got so much detail in there, you may want to include the
>>>>> names of
>>>>> the TRM chapter and sections that you reference.  I say this because a
>>>>> later
>>>>> revision may insert
>>>>> a chapter or a section and that will make the chapter/section numbers
>>>>> you
>>>>> have confusing.
>>>>> 2. For raw mode description, in the 'dd' line, change "of=/dev/sdc" to
>>>>> "of=<device>" (where <device> is the sd card).
>>>>> 3. For fat mode description, you may want to add a "dd if=/dev/zero
>>>>> of=<device> bs=1M count=1" as the first step just to
>>>>>        make sure there is no partition table at the base of the SD card.
>>>>> If
>>>>> there is, then the first 'n' in your instructions
>>>>>        may not do what you want.  I know you mention that the card is
>>>>> assumed
>>>>> to not be formatted.  This just
>>>>>        makes sure of that.  So, I walked through your steps, using this
>>>>> to
>>>>> automate:
>>>>> export SDDEV=/dev/sdc  # User should verify this device.
>>>>> sudo dd if=/dev/zero of=${SDDEV} bs=128K count=1
>>>>> echo "n\np\n1\n\n+1M\nt\nc\na\n1\np\nw\n" | fdisk ${SDDEV}
>>>>>        But when I did the mkfs line in your text, it returned an error:
>>>>> Not
>>>>> enough clusters for a 32bit FAT.
>>>>>        So, I just did "mkfs.vfat /dev/sdc1" and that worked fine.
>>>>> Honestly, I
>>>>> don't know the details here,
>>>>>        so if you can investigate this, that would be great.  Suggest
>>>>> adding
>>>>> something like the script above as
>>>>>        a shortcut.
>>>>> 4. For UART boot mode, mention that the uMon image that is transferred
>>>>> is
>>>>> boot.bin, not the MLO.
>>>>> Some other stuff you could add:
>>>>> - To know for sure what device is your uSD card in your linux box, run
>>>>> "cat
>>>>> /proc/partitions" before and after
>>>>> inserting the card and note the difference.
>>>>> Good stuff,
>>>>> Ed
>>>>> Ed,
>>>>> I finished the first draft of the document.  It can be found here:
>>>>> https://github.com/jrcatbagan/umon/commit/7f751486d5ca3ba5f6449adf5561df527a5cfde1
>>>>> . Please feel free to give me any suggestions on how I can improve it
>>>>> or if I am missing something.  Once you give the green light, I'll
>>>>> send it to umon-devel as a patch.
>>>>> Thanks.
>>>>> On Mon, Jul 6, 2015 at 5:21 AM, Ed Sutter <ed.sutter at alcatel-lucent.com>
>>>>> wrote:
>>>>> On 7/5/2015 6:46 PM, Chris Johns wrote:
>>>>> On 5/07/2015 4:19 am, Ed Sutter wrote:
>>>>> Ok, I managed to get it to boot using only Linux for formatting the
>>>>> card.
>>>>> It wasn't working for me until I just read your email and realized I did
>>>>> not mark
>>>>> the partition active.  After doing that it booted!
>>>>> So here are the steps I walked through
>>>>> (extracted from:
>>>>> http://forum.xda-developers.com/showthread.php?t=502095)
>>>>> 1. Verify the partition that the SD card installs as:
>>>>>         - cat /proc/paritions (without the uSD)
>>>>>         - Insert uSD card
>>>>>         - cat /proc/paritions (note the difference)
>>>>> Using /dev/sdc as our partition:
>>>>> 2. sudo fdisk /dev/sdc
>>>>>        - delete all paritions with 'd' command (d1/d2/d3/d4) as needed
>>>>>        - use 'n' command to create partition 1
>>>>>        - use 't' command to relabel partition 1 to 'c'
>>>>>        - use 'a' command to make the parition active
>>>>>        - use 'p' to show something like:
>>>>>       Device Boot      Start         End      Blocks   Id  System
>>>>> /dev/sdc1   *        2048     3932159     1965056    c  W95 FAT32 (LBA)
>>>>>         - use 'w' to write to the card
>>>>> 3. Run sudo mkfs.vfat /dev/sdc1
>>>>> 4. Mount /dev/sdc1 as /media/boot (or whatever)
>>>>> 5. Copy MLO to /media/boot
>>>>> 6. Run sync; unmount /media/boot
>>>>> 7. Put card in BBB, reset with boot button depressed.
>>>>> A simple request to place in the doco early is to create a root
>>>>> partition only as large as you need and not use whole disk size in the
>>>>> root partition. Users should be encouraged to add other partitions they
>>>>> can mount as read/write to store a kernel and/or user data.
>>>>> Chris
>>>>> _______________________________________________
>>>>> Yep, for sure... my example above was lame...
>>>>> Functionally ok, but not considering the fact that the SD card will have
>>>>> other "stuff".  Also, Chris, IIRC, you mentioned that FAT-booting may
>>>>> not be
>>>>> the right way to go ultimately.  So, for now at least, it will be good
>>>>> to
>>>>> cover
>>>>> both modes of booting until we get a better grip on which approach to
>>>>> take.
>>>>> Jarielle, I can add detail on raw mode to whatever you initially write
>>>>> up
>>>>> if you want me to...
>>>>> Ed
>>>>> umon-devel mailing list
>>>>> umon-devel at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/umon-devel
More information about the umon-devel mailing list
