[PATCH] BBB: sd_setup.sh: Change /bin/bash -> /bin/sh to solely adhere to POSIX shell constructs
Jarielle Catbagan jcatbagan93 at gmail.com
Sat Jul 11 14:51:41 UTC 2015
On Jul 11, 2015 7:17 AM, "Ed Sutter" <edsutterjr at gmail.com> wrote:
> Jarielle,
> Did you try running the script with that change?
> I applied the patch, then tried running it and it failed.
> Apparently 'echo' in sh is different than 'echo' in bash, at least it is
for my system.
> Let me know.
> I had to remove the -e from the echo lines for it to work on my
ubuntu14.04 system.
> You wanna test that and resubmit the patch or should I do it?
> Ed
Hi Ed,
After I changed it to 'sh' I was able to run it.  Ok, I'll look into it to
see what the issue might be.
> umon-devel mailing list
> umon-devel at rtems.org
> http://lists.rtems.org/mailman/listinfo/umon-devel
URL: <http://lists.rtems.org/pipermail/umon-devel/attachments/20150711/ce9a0350/attachment.html>
More information about the umon-devel mailing list
