[PATCH] BBB: sd_setup.sh: Change /bin/bash -> /bin/sh to solely adhere to POSIX shell constructs
Jarielle Catbagan jcatbagan93 at gmail.com
Sat Jul 11 15:06:09 UTC 2015
Ed,
Is there any indication as to why 'echo' is failing?  'echo' is not a
built-in command for either shell interpreter as I was able to locate
it as a separate program using both shells.  The -e option is to allow
interpretation of backslash characters as I was using it for newlines
and tabs.
On Sat, Jul 11, 2015 at 7:51 AM, Jarielle Catbagan
<jcatbagan93 at gmail.com> wrote:
> On Jul 11, 2015 7:17 AM, "Ed Sutter" <edsutterjr at gmail.com> wrote:
>> Jarielle,
>> Did you try running the script with that change?
>> I applied the patch, then tried running it and it failed.
>> Apparently 'echo' in sh is different than 'echo' in bash, at least it is
>> for my system.
>> Let me know.
>> I had to remove the -e from the echo lines for it to work on my
>> ubuntu14.04 system.
>> You wanna test that and resubmit the patch or should I do it?
>> Ed
> Hi Ed,
> After I changed it to 'sh' I was able to run it.  Ok, I'll look into it to
> see what the issue might be.
>> umon-devel mailing list
>> umon-devel at rtems.org
>> http://lists.rtems.org/mailman/listinfo/umon-devel
More information about the umon-devel mailing list
