[PATCH] BBB: sd_setup.sh: Change /bin/bash -> /bin/sh to solely adhere to POSIX shell constructs
Sat Jul 11 15:19:03 UTC 2015
On July 11, 2015 10:06:09 AM CDT, Jarielle Catbagan <jcatbagan93 at gmail.com> wrote:
>Ed,
>Is there any indication as to why 'echo' is failing?  'echo' is not a
>built-in command for either shell interpreter as I was able to locate
>it as a separate program using both shells.  The -e option is to allow
>interpretation of backslash characters as I was using it for newlines
>and tabs.
Do  sh -x and then try the command by hand at a prompt.
>On Sat, Jul 11, 2015 at 7:51 AM, Jarielle Catbagan
>> On Jul 11, 2015 7:17 AM, "Ed Sutter" <edsutterjr at gmail.com> wrote:
>>> Jarielle,
>>> Did you try running the script with that change?
>>> I applied the patch, then tried running it and it failed.
>>> Apparently 'echo' in sh is different than 'echo' in bash, at least
>it is
>>> for my system.
>>> Let me know.
>>> I had to remove the -e from the echo lines for it to work on my
>>> ubuntu14.04 system.
>>> You wanna test that and resubmit the patch or should I do it?
>>> Ed
>> Hi Ed,
>> After I changed it to 'sh' I was able to run it.  Ok, I'll look into
>it to
>> see what the issue might be.
>>> umon-devel mailing list
>>> umon-devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/umon-devel
--joel
More information about the umon-devel mailing list
