warning...
    Jarielle Catbagan
    jcatbagan93 at gmail.com
    Sat Jul 18 13:41:21 UTC 2015
Ed,
Your assumption is right, it should have been cm_clksel_dpll_mpu.  Feel
free to make the change as part of the push, otherwise let me know if I
should resubmit the patches.
Thanks.
On Jul 18, 2015 6:24 AM, "Ed Sutter" <edsutterjr at gmail.com> wrote:
> Jarielle,
> Just pulled in the patches and built, but there's a warning generated
> when cpuio.c is compiled...
> > cpuio.c: In function 'mpu_pll_init':
> > cpuio.c:286:21: warning: 'cm_clksel_dpll_mpu' is used uninitialized in
> this function [-Wuninitialized]
> >   cm_clksel_dpll_mpu &= ~0x0007FF7F;
> Without digging in too deep, it looks like a typo.
> Line 285 should be initializing cm_clksel_dpll_mpu instead of
> cmclkmode_dpll_mpu...
>     // Set the ARM core frequency to 1 GHz
>     cm_clkmode_dpll_mpu = CM_WKUP_REG(CM_CLKSEL_DPLL_MPU);
>     cm_clksel_dpll_mpu &= ~0x0007FF7F; <<<<<This is line 286
>     cm_clksel_dpll_mpu |= 1000 << 8;
>     cm_clksel_dpll_mpu |= 23;
>     CM_WKUP_REG(CM_CLKSEL_DPLL_MPU) = cm_clksel_dpll_mpu;
>     cm_div_m2_dpll_mpu = CM_WKUP_REG(CM_DIV_M2_DPLL_MPU);
>     cm_div_m2_dpll_mpu &= ~0x0000001F;
>     cm_div_m2_dpll_mpu |= 0x00000001;
>     CM_WKUP_REG(CM_DIV_M2_DPLL_MPU) = cm_div_m2_dpll_mpu;
> Assuming you have the same set of tools I have (from RTEMS), then you
> probably missed
> the warning because it streamed off your screen quickly (it was at the top
> of the build
> output).  To avoid that problem, just pipe all make output to a file...
> make rebuild 2>&1 | tee make.out
> Then grep for "arning" in the make.out file or just open the file and
> check it visually.
> Lemme know if my above assumption is true.  If yes, I'll just make the
> change as
> part of this push.
> Ed
> umon-devel mailing list
> umon-devel at rtems.org
> http://lists.rtems.org/mailman/listinfo/umon-devel
URL: <http://lists.rtems.org/pipermail/umon-devel/attachments/20150718/118926c4/attachment.html>
More information about the umon-devel
