warning...
    Ed Sutter
    edsutterjr at gmail.com
    Sat Jul 18 15:49:45 UTC 2015
Jarielle,
Ok, looks good.  I was able to do a full-range RAM test!
I pushed everything, including the cpuio.c change and also I
removed INCLUDE_DM and INCLUDE_PM from config.h because INCLUDE_MEMCMDS
pulls them all in.
Good work (again) !  :-)
Meanwhile, I'm just going to let my board soak with the memory test running..
"mt -vc 0x80100000 0x1fefffff"
Hopefully I'll come back in few hours and it will still be running!
Next is MMC right?
Two nice features come as a result of the MMC-write capability...
   1. You can boot from eMMC instead of uSD (so no need to hold down the button).
   2. You'll be able to do upgrades without manually needing to remove th uSD card.
That'll be sweet.
Ed
> Ed,
> Your assumption is right, it should have been cm_clksel_dpll_mpu.  Feel free to make the change as part of the push, otherwise let me know if I should resubmit the patches.
> Thanks.
> On Jul 18, 2015 6:24 AM, "Ed Sutter" <edsutterjr at gmail.com <mailto:edsutterjr at gmail.com>> wrote:
>     Jarielle,
>     Just pulled in the patches and built, but there's a warning generated
>     when cpuio.c is compiled...
>     > cpuio.c: In function 'mpu_pll_init':
>     > cpuio.c:286:21: warning: 'cm_clksel_dpll_mpu' is used uninitialized in this function [-Wuninitialized]
>     >   cm_clksel_dpll_mpu &= ~0x0007FF7F;
>     Without digging in too deep, it looks like a typo.
>     Line 285 should be initializing cm_clksel_dpll_mpu instead of cmclkmode_dpll_mpu...
>         // Set the ARM core frequency to 1 GHz
>         cm_clkmode_dpll_mpu = CM_WKUP_REG(CM_CLKSEL_DPLL_MPU);
>         cm_clksel_dpll_mpu &= ~0x0007FF7F; <<<<<This is line 286
>         cm_clksel_dpll_mpu |= 1000 << 8;
>         cm_clksel_dpll_mpu |= 23;
>         CM_WKUP_REG(CM_CLKSEL_DPLL_MPU) = cm_clksel_dpll_mpu;
>         cm_div_m2_dpll_mpu = CM_WKUP_REG(CM_DIV_M2_DPLL_MPU);
>         cm_div_m2_dpll_mpu &= ~0x0000001F;
>         cm_div_m2_dpll_mpu |= 0x00000001;
>         CM_WKUP_REG(CM_DIV_M2_DPLL_MPU) = cm_div_m2_dpll_mpu;
>     Assuming you have the same set of tools I have (from RTEMS), then you probably missed
>     the warning because it streamed off your screen quickly (it was at the top of the build
>     output).  To avoid that problem, just pipe all make output to a file...
>     make rebuild 2>&1 | tee make.out
>     Then grep for "arning" in the make.out file or just open the file and check it visually.
>     Lemme know if my above assumption is true.  If yes, I'll just make the change as
>     part of this push.
>     Ed
>     _______________________________________________
>     umon-devel mailing list
>     umon-devel at rtems.org <mailto:umon-devel at rtems.org>
>     http://lists.rtems.org/mailman/listinfo/umon-devel
URL: <http://lists.rtems.org/pipermail/umon-devel/attachments/20150718/3c024802/attachment.html>
More information about the umon-devel
