[PATCH 8/16] Fixed BASE variable in common.make
Jarielle Catbagan
jcatbagan93 at gmail.com
Wed Jun 17 18:06:19 UTC 2015
$(TOPDIR)/target -> $(TOPDIR) as the 'target' directory's contents
were moved to the same level as the directory itself. The BASE
variable in /main/make/common.make was updated to reflect this change.
main/make/common.make | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/main/make/common.make b/main/make/common.make
index 161ae77..b12780d 100644
--- a/main/make/common.make
+++ b/main/make/common.make
@@ -8,7 +8,7 @@
# Various relative directories used to build the monitor:
-BASE = $(TOPDIR)/target
+BASE = $(TOPDIR)
CPUDIR = $(BASE)/cpu/$(CPUTYPE)
ZLIBDIR = $(BASE)/zlib
GLIBDIR = $(BASE)/glib
2.3.3
More information about the umon-devel
