[PATCH 9/16] Removed ad7843.* from BBB port
Jarielle Catbagan
jcatbagan93 at gmail.com
Wed Jun 17 18:11:36 UTC 2015
Removed ad7843.* from the Beaglebone Black port since an Analog
devices AD7843 Touch Screen Controller is not used. Fixed syntax of
some invalid comments in am335x.h.
ports/beagleboneblack/Makefile | 41 ++---
ports/beagleboneblack/ad7843.c | 334 -----------------------------------------
ports/beagleboneblack/ad7843.h | 35 -----
ports/beagleboneblack/am335x.h | 10 +-
4 files changed, 29 insertions(+), 391 deletions(-)
delete mode 100644 ports/beagleboneblack/ad7843.c
delete mode 100644 ports/beagleboneblack/ad7843.h
diff --git a/ports/beagleboneblack/Makefile b/ports/beagleboneblack/Makefile
index 511b8e2..73d6860 100644
--- a/ports/beagleboneblack/Makefile
+++ b/ports/beagleboneblack/Makefile
@@ -4,7 +4,7 @@
PLATFORM = BEAGLEBONEBLACK
-# From the perspective of this file, UMONTOP is ../../umon_main
+# From the perspective of this file, UMONTOP is ../../main
TOPDIR = $(UMONTOP)
TGTDIR = beagleboneblack
CPUTYPE = arm
@@ -43,22 +43,29 @@ include $(TOPDIR)/make/common.make
# Build each variable from a list of individual filenames...
-LOCSSRC =
+LOCSSRC =
CPUSSRC = vectors_arm.S
-LOCCSRC = ad7843.c cpuio.c etherdev.c nand740.c omap3530_gpio.c \
- omap3530_lcd.c omap3530_sdmmc.c
-COMCSRC = arp.c cast.c cache.c chario.c cmdtbl.c \
- docmd.c dhcp_00.c dhcpboot.c dns.c edit.c env.c ethernet.c \
- flash.c gdb.c icmp.c if.c ledit_vt100.c monprof.c \
- fbi.c font.c mprintf.c memcmds.c malloc.c moncom.c memtrace.c \
- misccmds.c misc.c nand.c password.c redirect.c \
- reg_cache.c sbrk.c sd.c \
- start.c struct.c symtbl.c syslog.c tcpstuff.c tfs.c tfsapi.c \
- tfsclean1.c tfscli.c tfsloader.c tfslog.c tftp.c timestuff.c \
- tsi.c xmodem.c
-CPUCSRC = ldatags.c except_arm.c misc_arm.c strace_arm.c
-IODEVSRC = smsc911x.c uart16550.c fb_draw.c
-FLASHSRC = s29gl512n_16x1.c
+LOCCSRC =
+COMCSRC =
+CPUCSRC =
+IODEVSRC =
+FLASHSRC =
+#LOCSSRC =
+#CPUSSRC = vectors_arm.S
+#LOCCSRC = cpuio.c etherdev.c nand740.c omap3530_gpio.c \
+# omap3530_lcd.c omap3530_sdmmc.c
+#COMCSRC = arp.c cast.c cache.c chario.c cmdtbl.c \
+# docmd.c dhcp_00.c dhcpboot.c dns.c edit.c env.c ethernet.c \
+# flash.c gdb.c icmp.c if.c ledit_vt100.c monprof.c \
+# fbi.c font.c mprintf.c memcmds.c malloc.c moncom.c memtrace.c \
+# misccmds.c misc.c nand.c password.c redirect.c \
+# reg_cache.c sbrk.c sd.c \
+# start.c struct.c symtbl.c syslog.c tcpstuff.c tfs.c tfsapi.c \
+# tfsclean1.c tfscli.c tfsloader.c tfslog.c tftp.c timestuff.c \
+# tsi.c xmodem.c
+#CPUCSRC = ldatags.c except_arm.c misc_arm.c strace_arm.c
+#IODEVSRC = smsc911x.c uart16550.c fb_draw.c
+#FLASHSRC = s29gl512n_16x1.c
include $(TOPDIR)/make/objects.make
@@ -92,7 +99,7 @@ ramtst: $(BUILDDIR)/ramtst.$(FILETYPE)
@ls $(BUILDDIR)/ramtst*
$(BUILDDIR)/boot.$(FILETYPE): $(BUILDDIR) $(OBJS) libz.a \
- libg.a makefile
+ libg.a Makefile
$(CC) $(ASMFLAGS) -o rom_reset.o rom_reset.S
$(MAKE_MONBUILT)
sed -e s/ROMBASE/$(BOOTROMBASE)/ -e s/ROMLEN/$(BOOTROMLEN)/ \
diff --git a/ports/beagleboneblack/ad7843.c b/ports/beagleboneblack/ad7843.c
deleted file mode 100644
index 79e37ba..0000000
--- a/ports/beagleboneblack/ad7843.c
+++ /dev/null
@@ -1,334 +0,0 @@
-// ad7843.c
-// Author(s): Michael Kelly - Cogent Computer Systems, Inc.
-// Date: 03/06/03
-// Description: AD7843 Interface routines for CSB740
-// Modified from MC9328mxl version to use SPI1
-#include "config.h"
-#include "cpuio.h"
-#include "genlib.h"
-#include "stddefs.h"
-#include "omap3530.h"
-#include "cpu_gpio.h"
-#include "ad7843.h"
-#include "cli.h"
-#include "umongpio.h"
-// function prototypes
-int ads_init(void);
-int ads_rd(uchar ads_ctl);
-extern void udelay(int delay);
-#ifdef AD7843_GPIOMODE
-// After several days trying to get the OMAP's SPI3 controller to interface
-// to the AD7843, I gave up and implemented the protocol with GPIO...
-// SPI_CS: GPIO_91
-// SPI_CLK: GPIO_88
-// SPI_MOSI: GPIO_89
-// SPI_MISO: GPIO_90
-#define clrSpiCs() GPIO3_REG(GPIO_DATAOUT) &= ~BIT27
-#define setSpiCs() GPIO3_REG(GPIO_DATAOUT) |= BIT27
-#define clrSpiClk() GPIO3_REG(GPIO_DATAOUT) &= ~BIT24
-#define setSpiClk() GPIO3_REG(GPIO_DATAOUT) |= BIT24
-#define clrSpiMosi() GPIO3_REG(GPIO_DATAOUT) &= ~BIT25
-#define setSpiMosi() GPIO3_REG(GPIO_DATAOUT) |= BIT25
-#define getSpiMiso() (GPIO3_REG(GPIO_DATAIN) & BIT26) ? 1 : 0
-// ads_rd():
-// A bit-banged implementation of the SPI access for AD7843...
-// Slow and steady gets the job done!
-int
-ads_rd(uchar ads_ctl)
- ushort mask, val;
- clrSpiClk();
- clrSpiCs();
- for(mask = 0x80;mask != 0;mask >>= 1) {
- if (ads_ctl & mask)
- setSpiMosi();
- else
- clrSpiMosi();
- setSpiClk();
- clrSpiClk();
- val = 0;
- for(mask = 0x8000;mask != 0;mask >>= 1) {
- setSpiClk();
- if (getSpiMiso())
- val |= mask;
- clrSpiClk();
- clrSpiClk();
- setSpiCs();
- return(val);
-int
-ads_init(void)
- GPIO3_REG(GPIO_OE) &= ~(BIT27 | BIT25 | BIT24); // 0 = out
- GPIO3_REG(GPIO_OE) |= BIT26;
- setSpiCs();
- clrSpiClk();
- clrSpiMosi();
- return(0);
-#else
-// ads_init()/ads_rd():
-// This routine sets up the OMAP3530 SPI3 port. It also turns on
-// the AD7843 pen interrupt via a dummy read. We are using CS0 on SPI3.
-// Can't get this to work. Signals look good on scope, but we're not
-// able to read the data back; hence the need for a GPIO version (above).
-int
- volatile ulong rxval;
- SPI3_REG(SPI_IRQSTATUS) = 0x0003777f;
- SPI3_REG(SPI_IRQENABLE) = 0x0000007f;
- SPI3_REG(SPI_CH0_CTRL) = 0x00000001; // Enable SPI3 Channel 0
- // We have this OMAP3530 SPI ctrlr set up in 24-bit data mode, full
- // duplex transmit/receive. So, put the byte to be transferred in the
- // upper 8 bits of the 24-bit word, then read back the next 16 bits...
- SPI3_REG(SPI_TXD0) = ads_ctl << 16;
- // Wait for the receive channel to be full...
- while (!(SPI3_REG(SPI_CH0_STAT) & SPI_CH_RX0_FULL));
- // Read the value...
- rxval = SPI3_REG(SPI_RXD0);
- SPI3_REG(SPI_CH0_CTRL) = 0x00000000; // Disable SPI3 Channel 0
-// if (rxval)
-// printf("%08x\n",rxval);
- return (rxval);
-int
-ads_init()
- unsigned long conf;
- // Soft reset...
- SPI3_REG(SPI_SYSCONFIG) = 0x00000002;
- // Wait for reset done...
- while((SPI3_REG(SPI_SYSSTATUS) & 1) == 0);
- // Configure chan zero of SPI3...
- SPI3_REG(SPI_MODULCTRL) = 0x00000000; // Master, auto CS generation
- conf = SPI_CH_CONF_DPE0
- | SPI_CH_CONF_TRM_TR
- | SPI_CH_CONF_WL(23) // 24-bit data mode
- | SPI_CH_CONF_EPOL // CS is active low
- | SPI_CH_CONF_SB_POL //
- | SPI_CH_CONF_CLKD(9); // divide by 512 = 93Khz
- SPI3_REG(SPI_CH0_CONF) = conf;
- // enable the AD7843 so it can generate a touch interrupt.
- // this consists of reading any channel, but setting the
- // power down mode in the control byte to 00b. note we
- // flush the returned data
- if (ads_rd(AD7843_S | AD7843_ADD_DFR_Y | AD7843_PD_MOD0) == -1)
- printf("Error returned from ads_rd(0x%02x)!\n", (AD7843_S |
AD7843_ADD_DFR_Y | AD7843_PD_MOD0));
- return -1;
- return 0;
-#endif
-char *adsHelp[] = {
- "Screen touch demo using AD7843 and OMAP3530 SPI port.",
- "Detect screen touches and display the x,y values via",
- "the AD7843 and OMAP3530 SPI port.",
- 0
-int ads(int argc, char *argv[])
- uchar c;
- int pen, i;
- //int last_x, last_y;
- int sum_x, sum_y, average_x, average_y;
- // init the SPI and AD7843
- if (ads_init() == -1)
- printf("Error intializing AD7843!\n");
- return (CMD_FAILURE);
- printf("Waiting for Touch (Press \'X\' to end test)...\n");
- pen = 0;
- while (1)
- if (gotachar())
- c = getchar();
- if ((c == 'X') || (c == 'x')) goto done;
- if (c == 'L') {
- printf("In ads_rd loop...\n");
- while(1)
- ads_rd(AD7843_S | AD7843_PD_MOD0 | AD7843_ADD_DFR_X);
- if (GPIO_tst(PIRQ) == 0)
- printf("Pen Down....\n");
- pen = 1;
- //last_x = last_y = 0;
- while(GPIO_tst(PIRQ) == 0) // keep reading until touch goes away
- sum_x = sum_y = 0;
- // display every 4 samples
- for (i = 0; i < 64 ; i++)
- sum_x += ads_rd(AD7843_S | AD7843_PD_MOD0 | AD7843_ADD_DFR_X);
- sum_y += ads_rd(AD7843_S | AD7843_PD_MOD0 | AD7843_ADD_DFR_Y);
- average_x = sum_x/4;
- average_y = sum_y/4;
- //if ((average_x != last_x) || (average_y != last_y))
- printf("X = %04d, Y = %04d\n", average_x, average_y);
- //last_x = average_x;
- //last_y = average_y;
- } // while pen is down
- if (pen)
- printf("Pen Up....\n");
- pen = 0;
-done:
- return(CMD_SUCCESS);
-/* The next four functions are required for the "scribble" feature in
- * the FBI command to work...
-#include "tsi.h"
-#define TOUCH_MAX_YVAL 32760
-#define TOUCH_MAX_XVAL 30752
-/* tsi_init():
- * Used to initialize the touch screen interface.
-int
-tsi_init(void)
- return(ads_init());
-/* tsi_active():
- * Return 1 if the screen is being touched, else 0.
-int
-tsi_active(void)
- return(1);
- return(0);
-/* tsi_getx()/tsi_gety():
- * Return the current 'x' or 'y' position detected by the touch screen.
- * Notice that these functions return a value that is relative to the
- * frame-buffer coordinates, not raw the coordinates generated by the
- * touch-screen hardware.
- * This requires not only that the incoming value from the AD7843 be
- * normalized to the range of the X/Y coordinates of the frame buffer,
- * but it also requires that the 'Y' coordinate be adjusted to be from
- * top-down, not bottom up.
-int
-tsi_getx(void)
- int i, val, tot, stot, tmp;
- tot = stot = 0;
- /* Attempt 8 samples, then average...
- for(i=0;i<8;i++) {
- tmp = ads_rd(AD7843_S | AD7843_PD_MOD0 | AD7843_ADD_DFR_X);
- if ((tmp > 0) && (tmp < TOUCH_MAX_XVAL)) {
- tot += tmp;
- stot++;
- tot /= stot;
- val = tot / (TOUCH_MAX_XVAL/PIXELS_PER_ROW);
- return(val);
-int
-tsi_gety(void)
- tot = stot = 0;
- tmp = ads_rd(AD7843_S | AD7843_PD_MOD0 | AD7843_ADD_DFR_Y);
- if ((tmp > 0) && (tmp < TOUCH_MAX_YVAL)) {
- tot += tmp;
- stot++;
- tot /= stot;
- val = PIXELS_PER_COL - (tot/(TOUCH_MAX_YVAL/PIXELS_PER_COL));
- return(val);
diff --git a/ports/beagleboneblack/ad7843.h b/ports/beagleboneblack/ad7843.h
index f4a0b71..0000000
--- a/ports/beagleboneblack/ad7843.h
+++ /dev/null
@@ -1,35 +0,0 @@
-// ad7843.h
-// Author(s): Michael Kelly, Cogent Computer Systems, Inc.
-// Contributors:
-// Date: 03/06/03
-// Description: This file contains register offsets and bit defines
-// for the Analog Devices AD7843 Touch Screen Controller
-// Bit positions for AD7843 Control byte
-#define AD7843_S 0x80 // Start bit, always 1
-#define AD7843_8BIT 0x08 // 0 = 12-bit conversion, 1 = 8-bits
-#define AD7843_SER 0x04 // 0 = Differential, 1 = Single ended
-// Address select defines for Single-Ended mode
-#define AD7843_ADD_SER_Y (AD7843_SER | (0x1 << 4)) // Y position measurement
-#define AD7843_ADD_SER_IN3 (AD7843_SER | (0x2 << 4)) // auxillary
input 1 measurement
-#define AD7843_ADD_SER_X (AD7843_SER | (0x5 << 4)) // X position measurement
-#define AD7843_ADD_SER_IN4 (AD7843_SER | (0x6 << 4)) // auxillary
input 2 measurement
-// Address select defines for Differential mode
-#define AD7843_ADD_DFR_Y (0x1 << 4) // Y position measurement
-#define AD7843_ADD_DFR_X (0x5 << 4) // X position measurement
-// Power Down Modes
-#define AD7843_PD_MOD0 0x0 // low-power mode, no power-up delay, *IRQ
is enabled
-#define AD7843_PD_MOD1 0x1 // same as low-power mode, except *IRQ is disabled
-#define AD7843_PD_MOD2 0x2 // device on, *IRQ is enabled
-#define AD7843_PD_MOD3 0x3 // device on, *IRQ is disabled
-//#define AD7843_GPIOMODE
diff --git a/ports/beagleboneblack/am335x.h b/ports/beagleboneblack/am335x.h
index 6d7782a..9dc0649 100644
--- a/ports/beagleboneblack/am335x.h
+++ b/ports/beagleboneblack/am335x.h
@@ -45,7 +45,7 @@
- * L4_WKUP Peripherals
+/* L4_WKUP Peripherals */
/* Clock Module Peripheral Registers */
#define CM_PER_BASE (L4_WKUP_BASE + 0x00200000)
@@ -131,7 +131,7 @@
- * L4_PER Peripherals
+/* L4_PER Peripherals */
/* UART1 Registers */
#define UART1_BASE (L4_PER_BASE + 0x00022000)
@@ -254,7 +254,7 @@
- * L4_FAST Peripherals
+/* L4_FAST Peripherals */
#define L4_FAST_BASE 0x4A000000
/* Ethernet Switch Subsystem Registers */
@@ -294,7 +294,7 @@
- * UART Register offsets
+/* UART Register offsets */
#define UART_THR 0x00 // Transmit Holding Register (write only)
#define UART_RHR 0x00 // Receive Holding Register (read only)
@@ -348,7 +348,7 @@
- * USB
+/* USB */
#define USB_SUBSYS_BASE_ADDR 0x47400000
2.3.3
More information about the umon-devel
