[PATCH 14/16] Updated CPU_TYPE, CPU_NAME, PLATFORM_TYPE and PLATFORM_NAME in BBB config.h
Jarielle Catbagan
jcatbagan93 at gmail.com
Wed Jun 17 18:24:45 UTC 2015
ports/beagleboneblack/config.h | 8 ++++----
1 file changed, 4 insertions(+), 4 deletions(-)
diff --git a/ports/beagleboneblack/config.h b/ports/beagleboneblack/config.h
index 096bbda..754aeb6 100644
--- a/ports/beagleboneblack/config.h
+++ b/ports/beagleboneblack/config.h
@@ -132,10 +132,10 @@
* The 'TYPE' definition is used for ifdefs in the code and the 'NAME'
* is used for printfs in the code.
-#define CPU_TYPE OMAP3530
-#define CPU_NAME "TI OMAP3530 Cortex-A8"
-#define PLATFORM_TYPE CSB740
-#define PLATFORM_NAME "Cogent CSB740"
+#define CPU_TYPE AM3358
+#define CPU_NAME "TI AM3358 Cortex-A8"
+#define PLATFORM_TYPE BEAGLEBONEBLACK
+#define PLATFORM_NAME "Beaglebone Black"
/* Specify the size of the memory block (in monitor space) that is to be
* allocated to malloc in the monitor. Note that this size can be dynamically
2.3.3
More information about the umon-devel
