[PATCH 02/13] Updated header comment in BEAGLEBONEBLACK_boot.ldt
Jarielle Catbagan jcatbagan93 at gmail.com
Sat Jun 20 02:57:52 UTC 2015
 ports/beagleboneblack/BEAGLEBONEBLACK_boot.ldt | 9 +++++----
 1 file changed, 5 insertions(+), 4 deletions(-)
diff --git a/ports/beagleboneblack/BEAGLEBONEBLACK_boot.ldt b/ports/beagleboneblack/BEAGLEBONEBLACK_boot.ldt
index c8bc089..c37ebd6 100644
--- a/ports/beagleboneblack/BEAGLEBONEBLACK_boot.ldt
+++ b/ports/beagleboneblack/BEAGLEBONEBLACK_boot.ldt
@@ -1,9 +1,10 @@
-/* CSB740_boot.ld:
- * This is the memory map file used for the boot-flash based version
- * of MicroMonitor.  The only value that should be considered adjustable
- * here is the base address of the 'dram' memory block.
+/* BEAGLEBONEBLACK_boot.ld:
+ * This is the memory map file used for the boot version of Umon.  The only value
+ * that should be considered adjustable here is the base address of the 'dram'
+ * memory block.
 MEMORY
 	rom :	org = ROMBASE, 	len = ROMLEN
2.3.3
More information about the umon-devel mailing list
