[PATCH 03/13] Replaced cpuio.c and cpuio.h in BBB port
Jarielle Catbagan jcatbagan93 at gmail.com
Sat Jun 20 02:57:53 UTC 2015
The former cpuio.* files contained code specific to CSB740.  It was replaced with
the template cpuio.* files with the getUartDivisor() function retained from the
previous cpuio.c
 ports/beagleboneblack/cpuio.c | 348 ++++++++++--------------------------------
 ports/beagleboneblack/cpuio.h |  77 +---------
 2 files changed, 79 insertions(+), 346 deletions(-)
diff --git a/ports/beagleboneblack/cpuio.c b/ports/beagleboneblack/cpuio.c
index 0a9a262..8f2fbed 100644
--- a/ports/beagleboneblack/cpuio.c
+++ b/ports/beagleboneblack/cpuio.c
@@ -1,64 +1,11 @@
-//      cpuio.c
-//      CPU/Board Specific IO
-// Author(s):    Luis Torrico, Cogent Computer Systems, Inc.
-// Date:         12/04/2008
-// Description:  This file contains the IO functions required by Micro Monitor
-//				 that are unique to the CSB740
 #include "config.h"
+#include "stddefs.h"
 #include "cpuio.h"
 #include "genlib.h"
-#include "ether.h"
-#include "stddefs.h"
+#include "cache.h"
 #include "warmstart.h"
-#include "omap3530.h"
-#include "omap3530_mem.h"
-#include "cpu_gpio.h"
-#include "fb_draw.h"
-#include "uart16550.h"
-#include "umongpio.h"
-#include "ad7843.h"
-#define __raw_readl(a)    (*(volatile unsigned int *)(a))
-extern ulong i2c_init(void);
-extern ulong getpsr(void);
-extern void putpsr(ulong);
-uchar bcolor=0;		// vga black
-// Delay for some usecs. - Not accurate, assumes ROM mode
-// and no Cache
-void udelay(int delay)
-  volatile int i;
-  for ( i = LOOPS_PER_USEC * delay; i ; i--);
+#include "timer.h"
- * Routine: wait_for_command_complete
- * Description: Wait for posting to finish on watchdog
-void wait_for_command_complete(unsigned int wd_base)
-	int pending = 1;
-	do {
-		pending = __raw_readl(wd_base + WD_WWPS);
-	} while (pending);
-// getUARTDivisor is called from UART16550.c
 int
 getUartDivisor(int baud, unsigned char *hi, unsigned char *lo)
@@ -67,247 +14,106 @@ getUartDivisor(int baud, unsigned char *hi, unsigned char *lo)
 	return(0);
-// Set pads (pins) to correct mode.  Refer to section 7.4.4
-	in TI omap35xx_tech_ref_manual for bit defines.
-void pads_init()
-	// Set up chip selects
-	SCM_REG(PADCONFS_GPMC_NCS3) = 0x00180018;	// NCS3[15:0], NCS4[31:16]
-	SCM_REG(PADCONFS_GPMC_NCS5) = 0x011C0018;	// NCS5[15:0], EXP_INTX[31:16]
-	// Set LCD_BKL_X to output, pullup enabled, mode 4
-	// Set LCLK to output, no pull-type and disabled, mode 0
-	SCM_REG(PADCONFS_GPMC_NCS7) = 0x0000001C; 	// LCD_BKL_X[15:0], LCLK(or GPIO_59)[31:16]
-	// Set LCD pads to outputs, pull-type = up, pullud disabled, mode 0
-	SCM_REG(PADCONFS_DSS_PCLK) = 0x00100010;	// LCD_PCLK_X[15:0], LCD_HS_X[31:16]
-	SCM_REG(PADCONFS_DSS_VSYNC) = 0x00100010;	// LCD_VS_X[15:0], LCD_OE_X[31:16]
-	SCM_REG(PADCONFS_DSS_DATA0) = 0x00100010;	// LCD_B0_X[15:0], LCD_B1_X[31:16]
-	SCM_REG(PADCONFS_DSS_DATA2) = 0x00100010;	// LCD_B2_X[15:0], LCD_B3_X[31:16]
-	SCM_REG(PADCONFS_DSS_DATA4) = 0x00100010; 	// LCD_B4_X[15:0], LCD_B5_X[31:16]
-	SCM_REG(PADCONFS_DSS_DATA6) = 0x00100010;	// LCD_G0_X[15:0], LCD_G1_X[31:16]
-	SCM_REG(PADCONFS_DSS_DATA8) = 0x00100010;	// LCD_G2_X[15:0], LCD_G3_X[31:16]
-	SCM_REG(PADCONFS_DSS_DATA10) = 0x00100010; 	// LCD_G4_X[15:0], LCD_G5_X[31:16]
-	SCM_REG(PADCONFS_DSS_DATA12) = 0x00100010;	// LCD_R0_X[15:0], LCD_R1_X[31:16]
-	SCM_REG(PADCONFS_DSS_DATA14) = 0x00100010;	// LCD_R2_X[15:0], LCD_R3_X[31:16]
-	SCM_REG(PADCONFS_DSS_DATA16) = 0x00100010;	// LCD_R4_X[15:0], LCD_R5_X[31:16]
-	// Set D_TXD for output and D_RXD for input.  Set both to pullup enabled and mode 1
-	SCM_REG(PADCONFS_MCBSP3_CLKX) = 0x01190019;	// D_TXD[15:0], D_RXD[31:16]
-#ifdef AD7843_GPIOMODE
-	// Depending on AD7843_GPIOMODE setting, we either configure the SPI
-	// interface to the AD7843 as a real SPI device using the OMAP's SPI
-	// controller, or we set it up with GPIO bits...
-	SCM_REG(PADCONFS_DSS_DATA18) = 0x00040004;
-	SCM_REG(PADCONFS_DSS_DATA20) = 0x00040104;
-#else
-	SCM_REG(PADCONFS_DSS_DATA18) = 0x0002011A; 	// SPI1_CLK_X[15:0], SPI1_MOSI_X[31:16]
-	SCM_REG(PADCONFS_DSS_DATA20) = 0x001A011A; 	// SPI1_MISO_X[15:0], *SPI1_CS0_X[31:16]
-#endif
-	// Set PIRQ for ADS7843 touch interrupt.  Set both to pullup enabled and mode 4
-	SCM_REG(PADCONFS_MMC1_DAT4) = 0x01040104; 	// *I2C_INT_X[15:0], *PIRQ_X[31:16]
-	// GPIO1 is the push button on CSB703(set as input), GPIO0 is is LED on CSB703(set as output)
-	SCM_REG(PADCONFS_MMC1_DAT6) = 0x01040004; 	// GPIO0_X[15:0], GPIO1_X[31:16]
-	// Set E_INT* to be an input in GPIO mode
-	SCM_REG(PADCONFS_GPMC_WAIT2) = 0x011C011f; 	// NA[15:0], E_INTX[31:16]
-  	// Set SYS_CLKOUT1 for USB_CLK
-  	SCM_REG(PADCONFS_SYS_OFF_MODE) = 0x0000010f;   // OFF_MODE_X[15:0], SYS_CLKOUT1[31:16]
-  	// Set SYS_CLKOUT2 for debug purposes
-  	SCM_REG(PADCONFS_SYS_NIRQ) = 0x0000011f;   // FIQ[15:0], SYS_CLK2[31:16]
-int
+/* devInit():
+ * As a bare minimum, initialize the console UART here using the
+ * incoming 'baud' value as the baud rate.
+void
 devInit(int baud)
-	// Initialize pads
-    pads_init();
-	// Disable MPU Watchdog WDT2
-	WD2_REG(WD_WSPR) = 0x0000aaaa;
-	wait_for_command_complete(WD2_BASE_ADD);
-	WD2_REG(WD_WSPR) = 0x00005555;
-	// Initialize GPIO
-	GPIO_init();
-	// Setup UART pins to UART mode before calling InitUART from uart16550.c
-	UART2_REG(UART_MDR1) = 0x0000;
-    // Initialize the UART
-    InitUART(baud);
-	// Setup CS0 for 110ns Spansion Flash
-	GPMC_REG(GPMC_CS0_CONFIG7) = 0x00000c48;	// Base addr 0x08000000, 64M
-	GPMC_REG(GPMC_CS0_CONFIG1) = 0x00001210;
-	//GPMC_REG(GPMC_CS0_CONFIG5) = 0x00080808;	// Config5
-	// Setup CS4 for LAN9211, on the CSB740 it is refered to as CS2
-	// and mapped to E_CS
-	GPMC_REG(GPMC_CS4_CONFIG7) = 0x00000F6C;	// Base addr 0x2C000000, 16M
-	GPMC_REG(GPMC_CS4_CONFIG1) = 0x00001200;
-	return 0;
+	/* ADD_CODE_HERE */
-/* Referring to table 25-10 of the TRM, install
- * the RAM exception vectors...
+/* ConsoleBaudSet():
+ * Provide a means to change the baud rate of the running
+ * console interface.  If the incoming value is not a valid
+ * baud rate, then default to 9600.
+ * In the early stages of a new port this can be left empty.
+ * Return 0 if successful; else -1.
-void
-ram_vector_install(void)
+/*int
+ConsoleBaudSet(int baud)
-	extern unsigned long abort_data;
-	extern unsigned long abort_prefetch;
-	extern unsigned long undefined_instruction;
-	extern unsigned long software_interrupt;
-	extern unsigned long interrupt_request;
-	extern unsigned long fast_interrupt_request;
-	extern unsigned long not_assigned;
-	*(ulong **)0x4020ffe4 = &undefined_instruction;
-	*(ulong **)0x4020ffe8 = &software_interrupt;
-	*(ulong **)0x4020ffec = &abort_prefetch;
-	*(ulong **)0x4020fff0 = &abort_data;
-	*(ulong **)0x4020fff4 = &not_assigned;
-	*(ulong **)0x4020fff8 = &interrupt_request;
-	*(ulong **)0x4020fffc = &fast_interrupt_request;
-void
-initCPUio()
+	// ADD_CODE_HERE
+	return(0);
+/* target_console_empty():
+ * Target-specific portion of flush_console() in chario.c.
+ * This function returns 1 if there are no characters waiting to
+ * be put out on the UART; else return 0 indicating that the UART
+ * is still busy outputting characters from its FIFO.
+ * In the early stages of a new port this can simply return 1.
+/*int
+target_console_empty(void)
-	volatile unsigned register cntens;
-	volatile unsigned register usren;
-	volatile unsigned register pmnc;
-	ram_vector_install();
-	/* Do this stuff to enable the cycle counter
-	 * (for use by target_timer)...
-	/* Allow user mode to have access to performance monitor registers:
-   	asm volatile ("   MRC p15, 0, %0, c9, c14, 0" : "=r" (usren));
-	usren |= 1;
-   	asm volatile ("   MCR p15, 0, %0, c9, c14, 0" : : "r" (usren));
-	/* Enable all counters, and reset Cycle counter...
-	asm volatile ("   MRC p15, 0, %0, c9, c12, 0" : "=r" (pmnc));
-	pmnc |= 5;
-	asm volatile ("   MCR p15, 0, %0, c9, c12, 0" : : "r" (pmnc));
-	/* Enable all performance counter registers...
-	asm volatile ("   MRC p15, 0, %0, c9, c12, 1" : "=r" (cntens));
-	cntens |= 0x8000000f;
-	asm volatile ("   MCR p15, 0, %0, c9, c12, 1" : : "r" (cntens));
-/* target_reset():
- * Set the counter to 16 ticks before trigger, then enable the
- * watchdog timer (WDT2) and wait...
+	// if (UART_OUTPUT_BUFFER_IS_EMPTY())  <- FIX CODE HERE
+		return(0);
+	return(1);
+/* intsoff():
+ * Disable all system interrupts here and return a value that can
+ * be used by intsrestore() (later) to restore the interrupt state.
-void
-target_reset(void)
+ulong
+intsoff(void)
-	// Preload the count-up register...
-	WD2_REG(WD_WCRR) = 0xfffffff0;
-	// Start MPU Watchdog WDT2
-	WD2_REG(WD_WSPR) = 0x0000bbbb;
-	WD2_REG(WD_WSPR) = 0x00004444;
+	ulong status;
-	// Now just wait...
-	while(1);
+	return(status);
+/* intsrestore():
+ * Re-establish system interrupts here by using the status value
+ * that was returned by an earlier call to intsoff().
 void
-intsrestore(psr)
-ulong     psr;
+intsrestore(ulong status)
-    putpsr(psr);
- * Read the program status register (CPSR)
- * and set the FIQ and IRQ bits.
+/* cacheInitForTarget():
+ * Establish target specific function pointers and
+ * enable i-cache...
+ * Refer to $core/cache.c for a description of the function pointers.
+ * NOTE:
+ * If cache (either I or D or both) is enabled, then it is important
+ * that the appropriate cacheflush/invalidate function be established.
+ * This is very important because programs (i.e. cpu instructions) are
+ * transferred to memory using data memory accesses and could
+ * potentially result in cache coherency problems.
-ulong
-intsoff(void)
+void
+cacheInitForTarget(void)
-    ulong  psr;
-    psr = getpsr();
-     * Set bit 6, bit 7 to disable interrupts.
-    putpsr(psr | 0x000000c0);
-    return(psr);
-/* show_revision():
- * Called when the system banner is printed...
+/* target_reset():
+ * The default (absolute minimum) action to be taken by this function
+ * is to call monrestart(INITIALIZE).  It would be better if there was
+ * some target-specific function that would really cause the target
+ * to reset...
 void
-show_revision(int center)
+target_reset(void)
-	int	(*pfunc)(char *, ...);
-	volatile unsigned register main_id;
-	volatile unsigned register silicon_id;
-	if (center)
-		pfunc = cprintf;
-	else
-		pfunc = printf;
-	asm("   MRC p15, 0, %0, c0, c0, 0" : "=r" (main_id));
-	asm("   MRC p15, 1, %0, c0, c0, 7" : "=r" (silicon_id));
-	pfunc("Silicon ID: %d.%d\n",
-		((silicon_id & 0xf0)>>4),(silicon_id & 0xf));
-	pfunc("CPU Rev: %d, Variant: %d\n",
-		main_id & 0xf,(main_id & 0x00f00000) >> 20);
-	pfunc("CM Rev: %d.%d, PRM Rev: %d.%d\n",
-		CM_REV_MAJ(),CM_REV_MIN(),PRM_REV_MAJ(),PRM_REV_MIN());
+//	flushDcache(0,0);
+//	disableDcache();
+//	invalidateIcache(0,0);
+//	disableIcache();
+	monrestart(INITIALIZE);
-/* target_timer():
- * Used in conjunction with INCLUDE_HWTMR and TIMER_TICKS_PER_MSEC
- * to set up a hardware based time base.
+/* If any CPU IO wasn't initialized in reset.S, do it here...
+ * This just provides a "C-level" IO init opportunity.
-unsigned long
-target_timer(void)
-	volatile unsigned register ccr;
-   	asm("   MRC p15, 0, %0, c9, c13, 0" : "=r" (ccr));
-	return(ccr);
-/* cacheInitForTarget():
-    Enable instruction cache only...
 void
-cacheInitForTarget()
+initCPUio(void)
-    asm("   MRC p15, 0, r0, c1, c0, 0");
-    asm("   ORR r0, r0, #0x1000");  /* bit 12 is ICACHE enable*/
-    asm("   MCR p15, 0, r0, c1, c0, 0");
-    /* Flush instruction cache */
-    asm("   MCR p15, 0, r0, c7, c5, 0");
diff --git a/ports/beagleboneblack/cpuio.h b/ports/beagleboneblack/cpuio.h
index 64ff49c..2021851 100644
--- a/ports/beagleboneblack/cpuio.h
+++ b/ports/beagleboneblack/cpuio.h
@@ -1,76 +1,3 @@
-//      cpuio.h
-// Date:         05-16-2008
-//				 that are unique to each CPU/Board combination
-// cpuio.h for the CSB740 OMAP3530 Cortex-A8
-// board specific defines for micro monitor
-#define DEFAULT_BAUD_RATE   	38400
-#define MON_CPU_CLOCK       	400000000
-#define LOOPS_PER_USEC			5
-#define BASE_OF_NAND			0x1000
-#define SIZE_OF_NAND			0x100000
-// SMSC LAN9211 Ethernet
-#define SMSC911X_BASE_ADDRESS	0x2C000000	// CS4 on OMAP3530 but we call it CS2
-// LCD Defines
-// The LCD frame buffer is fixed at 0x80200000, which is 2Mbyte from the
-// beginning of SDRAM space.  Note that we access it 16-bits at a time.
-#define LCD_BUF_ADD				0x80200000
-#define LCD_BUF(_x_)			*(vushort *)(LCD_BUF_ADD + _x_)	// Frame Buffer
-#define USE_FONT8X8
-#define LCD_GET_PIXEL_ADD(_X_, _Y_)	(((_Y_ * PIXELS_PER_ROW) + _X_)*2)
-// defines for the display geometry - OSD043TN24 480x272 TFT
-// (some of these defines are also used by uMon's frame buffer interface)
-#define PIXELS_PER_ROW			480		//
-#define PIXELS_PER_COL			272		//
-#define BITS_PER_PIXEL			16		//
-#define PIXFMT_IS_RGB565		1
-#define FBDEV_SETSTART			fbdev_setstart
-#define FRAME_BUFFER_BASE_ADDR	LCD_BUF_ADD
-#define LCD_H_WIDTH 			41		// pulse width in pixels
-#define LCD_H_FRONT 			2		// front porch (sync to enable)
-#define LCD_H_BACK 				2		// back porch (enable to sync)
-#define LCD_V_WIDTH 			10		// pulse width in lines
-#define LCD_V_FRONT 			2		// front porch (sync to enable)
-#define LCD_V_BACK 				2		// back porch (enable to sync)
-//#define LCD_PCD					2		// LCD PERCLK3 = 32Mhz/PCD +1 = Pixel Clock ~ 4Mhz
-#define TOP						1
-#define BOTTOM					(PIXELS_PER_COL-1)
-#define LEFT					0
-#define RIGHT					(PIXELS_PER_ROW-1)
-#define CENTER_X				(PIXELS_PER_ROW/2)
-#define CENTER_Y				(PIXELS_PER_COL/2)
-#define ROWS_PER_SCREEN			17
-#define COLS_PER_SCREEN			60
-#define LCD_BG_DEF				9
-#define LCD_FG_DEF				15
-#define LCD_FB_SIZE(_depth_)				(((PIXELS_PER_COL * PIXELS_PER_ROW) * _depth_) / 8)
-#define LCD_ROW_SIZE(_depth_)				((PIXELS_PER_ROW * _depth_) / 8)
-#define LCD_GET_ADD(_row_, _col_, _depth_)	(((((_row_ * PIXELS_PER_ROW) * FONT_HEIGHT) \
-											  + (_col_ * FONT_WIDTH)) \
-											  * _depth_) / 8)
+#define DEFAULT_BAUD_RATE 38400
+#define MONARGV0 "umon"
2.3.3
More information about the umon-devel mailing list
