[PATCH 13/13] Removed bdi2000.cfg in BBB port as it does not target the AM335x
Jarielle Catbagan jcatbagan93 at gmail.com
Sat Jun 20 02:58:03 UTC 2015
 ports/beagleboneblack/bdi2000.cfg | 188 --------------------------------------
 1 file changed, 188 deletions(-)
 delete mode 100644 ports/beagleboneblack/bdi2000.cfg
diff --git a/ports/beagleboneblack/bdi2000.cfg b/ports/beagleboneblack/bdi2000.cfg
deleted file mode 100644
index 93a82cf..0000000
--- a/ports/beagleboneblack/bdi2000.cfg
+++ /dev/null
@@ -1,188 +0,0 @@
-; bdiGDB configuration for TI OMAP3430 ES1.0
-; To halt the core as soon as possible after power-up,
-; select EMU1=1,EMU0=0 (Wait In Reset mode WIR).
-; Commands supported in the SCANINIT and SCANPOST strings:
-;  I<n>=<...b2b1b0>   write IR, b0 is first scanned
-;  D<n>=<...b2b1b0>   write DR, b0 is first scanned
-;                       n  : the number of bits 1..256
-;                       bx : a data byte, two hex digits
-;  W<n>               wait for n (decimal) micro seconds
-;  T1                 assert TRST
-;  T0                 release TRST
-;  R1                 assert RESET
-;  R0                 release RESET
-;  CH<n>              clock TCK n (decimal) times with TMS high
-;  CL<n>              clock TCK n (decimal) times with TMS low
-[INIT]
-WREG    CPSR        0x000001D3  ;select ARM / supervisor mode
-WM32    0x48314048  0x0000aaaa  ;disable watchdog WDT2
-WM32    0x48314048  0x00005555  ;disable watchdog WDT2
-WGPR    11          0x40200020  ;set frame pointer to free RAM
-WM32    0x40200020  0x40200028	;dummy stack frame
-;; Initialize Pins
-WM32	0x48002170	0x01190019	; Enable UART2 RX and TX
-WM32	0x48002a18	0x0018010f	; Enable SYS_CLKOUT1
-WM32	0x480021e0	0x0018010f	; Enable SYS_CLKOUT2
-;; Initialize Clocks
-;WM32	0x48306d70	0x00000000	; disable sys_clk1
-;WM32	0x4830729C	0x00000006	; set polarity
-WM32	0x48306814	0x00000000	; Enable Interface clock to be Free running
-WM32	0x48004e10	0x00000001	; Enable L3_ICLK and L4_ICLK
-WM32	0x48004a30	0x00006000	; Enable Auto Clock for UART1 and UART2
-;WM32	0x48004d70	0x00000000	; Enable source for SYS_CLKOUT2
-;WM32	0x48004d70	0x00000080	; Enable SYS_CLKOUT2
-WM32	0x48004a00	0xc3fffe01	; Turn on all available module clocks
-WM32	0x48004a10	0x7ffffedb	; Turn on all available peripheral clocks
-;WM32	0x48306d70	0x00000080	; enable sys_clk1
-; Initialize CS0
-WM32	0x6E000010	0x08		; Set No-idle, Normal Mode, CLK free running
-WM32	0x6E000078	0x00000C48	; Config7
-WM32	0x6E000060	0x00001200	; Config1
-WM32	0x6E000064  0x000f0f01	; Config2
-WM32	0x6E000068  0x00020201	; Config3
-WM32	0x6E00006C  0x0C060C06	; Config4
-WM32	0x6E000070  0x01131F1F	; Config5
-WM32	0x6E000074  0x0F030000	; Config6
-; Initialize DDR
-;/* SDRAM software reset */
-;/* No idle ack and RESET enable */
-;__raw_writel(0x1A, SDRC_REG(SYSCONFIG));
-WM32	0x6D000010	0x0000001A	; reset DDR
-;sdelay(100);
-DELAY 100
-;/* No idle ack and RESET disable */
-;__raw_writel(0x18, SDRC_REG(SYSCONFIG));
-WM32	0x6D000010	0x00000018	; release reset
-DELAY 100
-;/* SDRC Sharing register */
-;/* 32-bit SDRAM on data lane [31:0] - CS0 */
-;/* pin tri-stated = 1 */
-;__raw_writel(0x00000100, SDRC_REG(SHARING));
-WM32	0x6D000044	0x00000100
-;/* ----- SDRC Registers Configuration --------- */
-;/* SDRC_MCFG0 register */
-;__raw_writel(0x02584099, SDRC_REG(MCFG_0));
-WM32 	0x6D000080	0x02584099
-;/* SDRC_RFR_CTRL0 register */
-;__raw_writel(0x54601, SDRC_REG(RFR_CTRL_0));
-WM32	0x6D0000a4	0x00054601
-;/* SDRC_ACTIM_CTRLA0 register */
-;__raw_writel(0xA29DB4C6, SDRC_REG(ACTIM_CTRLA_0));
-WM32	0x6D00009c	0xA29DB4C6
-;/* SDRC_ACTIM_CTRLB0 register */
-;__raw_writel(0x12214, SDRC_REG(ACTIM_CTRLB_0));
-WM32	0x6D0000A0	0x00012214
-;/* Disble Power Down of CKE due to 1 CKE on combo part */
-;__raw_writel(0x00000081, SDRC_REG(POWER));
-WM32	0x6D000070	0x00000081
-;/* SDRC_MANUAL command register */
-;/* NOP command */
-;__raw_writel(0x00000000, SDRC_REG(MANUAL_0));
-WM32	0x6D0000A8	0x00000000
-;/* Precharge command */
-;__raw_writel(0x00000001, SDRC_REG(MANUAL_0));
-WM32	0x6D0000A8	0x00000001
-;/* Auto-refresh command */
-;__raw_writel(0x00000002, SDRC_REG(MANUAL_0));
-WM32	0x6D0000A8	0x00000002
-;/* SDRC MR0 register Burst length=4 */
-;__raw_writel(0x00000032, SDRC_REG(MR_0));
-WM32	0x6D000084	0x00000032
-;/* SDRC DLLA control register */
-;__raw_writel(0x0000000A, SDRC_REG(DLLA_CTRL));
-WM32	0x6D000060	0x0000000A
-[TARGET]
-CPUTYPE     OMAP3430
-CLOCK       1					; JTAG clock
-POWERUP     2000                ; power-up delay
-TRST        PUSHPULL            ; TRST driver type (OPENDRAIN | PUSHPULL)
-RESET	    HARD		        ; NONE | HARD <n> (ms)
-STARTUP     HALT	            ; let boot code setup the system
-;STARTUP     RUN	            ; let boot code setup the system
-ENDIAN      LITTLE              ; memory model (LITTLE | BIG)
-;MEMACCESS   CORE  10            ; memory access via core (8 TCK's access delay)
-MEMACCESS	AHB   8             ; memory access via AHB  (64 TCK's access delay)
-;VECTOR CATCH	0x1B			; catch Abort, Undef, Reset
-SCANPRED    1 6                 ; count for ICEPick TAP
-SCANSUCC    1 8                 ; Xilinx
-; Configure ICEPick module to make Cortex-A8 DAP-TAP visible
-SCANINIT    t1:w1000:t0:w1000:  ; toggle TRST,
-SCANINIT    ch10:w1000:         ; clock TCK with TMS high and wait
-SCANINIT    i6=07:d8=89:i6=02:  ; connect and select router
-SCANINIT    d32=81000080:       ; IP control: KeepPowered
-SCANINIT    d32=a3002048:       ; TAP3: DebugConnect, ForcePower, ForceActive
-SCANINIT    d32=81000081:       ; IP control: KeepPowered, SysReset
-SCANINIT    d32=a3002148:       ; enable TAP3
-SCANINIT    cl10:i10=ffff       ; clock 10 times in RTI, scan bypass
-;assert SysSeset after debugger has setup
-;SCANPOST    i10=ffff:           ; scan bypass
-;SCANPOST    i10=002f:           ; IP(router) - TAP3(bypass)
-;SCANPOST    d33=0102000102:     ; IP control = SysReset
-;SCANPOST    i10=ffff            ; scan bypass
-[HOST]
-IP          192.168.1.3
-FILE       	build_csb740\ramtst.elf
-FORMAT      ELF
-LOAD        MANUAL      ;load file MANUAL or AUTO after reset
-PROMPT      CSB740_>
-TELNET		NOECHO
-[FLASH]
-WORKSPACE   0x80001000          ;workspace at 0x1000
-CHIPSIZE    0x4000000
-CHIPTYPE	MIRRORX16
-BUSWIDTH    16
-FILE       	build_csb740\boot.bin
-FORMAT      BIN 0x08000000
-ERASE		0x08000000
-ERASE		0x08020000
-ERASE		0x08040000
-ERASE		0x08060000
-ERASE		0x08080000
-[REGS]
-FILE		C:\els\abatron\arm11\regOMAP3430.def
2.3.3
More information about the umon-devel mailing list
