false positive, but a workaround...
Jarielle Catbagan jcatbagan93 at gmail.com
Wed Jun 24 14:41:39 UTC 2015
On Wed, Jun 24, 2015 at 6:10 AM, Ed Sutter <ed.sutter at alcatel-lucent.com> wrote:
> Jarielle,
> Well, it took almost 5 hours to build the tools last night. Obviously I need
> to upgrade the machine I have
> this stuff running on at home!
> Anyway, this AM I was able to walk through what I thought I had done in work
> yesterday, and unfortunately due
> to the fact that I am working in two different locations on two different
> machines (very very inefficient, but I'm
> stuck in this mode at the moment); I fooled myself yesterday thinking I had
> stubbed out the __ctype_ptr__
> declarations from docmd.c...  Unfortunately, I didn't :-(, so what I thought
> built clean didn't.
> Anyway, I want to get you over this hump quickly 'cause this isn't what I'd
> like you to be working on.  I really
> want you to concentrate on beaglebone-specific stuff.   That's the important
> stuff.  Today I brought my beaglebone
> board to the office, and I've got it working clean now using a local set of
> ctype.h and ctypetbl.c files as I had in
> umon1.19.  For now this is temporary, but it may turn out to be the most
> efficient way to get around this.
These files would conflict with the licenses, am I right?  Would a
permanent solution be to implement a new local ctype.h?
> So, attached to this are three files:
> ctypetbl.c:  put this under main/glib
> ctype.h:      put this under main/common
> mydiffs:     small list of diffs based on the tree after installing your
> initial set of 24 patches.
>                    most of these changes you probably have, the important
> one is in main/make/common.make so that ctypetbl.c is built.
> If you can incorporate these changes into a tree that starts with the master
> and has your initial 24 patches applied,
> you should be good to go.  I know I should be using git to email you
> patches, but I'm still trying to figure out how to
> do that and I don't want you to be delayed by that.
> Does this make sense to you?
Yes.  Ok, I'll incorporate those files and I believe you are right
that everything should be all set.
> Ed
> umon-devel mailing list
> umon-devel at rtems.org
> http://lists.rtems.org/mailman/listinfo/umon-devel
More information about the umon-devel mailing list
