false positive, but a workaround...
Ed Sutter ed.sutter at alcatel-lucent.com
Wed Jun 24 14:40:21 UTC 2015
On 6/24/2015 10:41 AM, Jarielle Catbagan wrote:
> On Wed, Jun 24, 2015 at 6:10 AM, Ed Sutter <ed.sutter at alcatel-lucent.com> wrote:
>> Jarielle,
>> Well, it took almost 5 hours to build the tools last night. Obviously I need
>> to upgrade the machine I have
>> this stuff running on at home!
>> Anyway, this AM I was able to walk through what I thought I had done in work
>> yesterday, and unfortunately due
>> to the fact that I am working in two different locations on two different
>> machines (very very inefficient, but I'm
>> stuck in this mode at the moment); I fooled myself yesterday thinking I had
>> stubbed out the __ctype_ptr__
>> declarations from docmd.c...  Unfortunately, I didn't :-(, so what I thought
>> built clean didn't.
>> Anyway, I want to get you over this hump quickly 'cause this isn't what I'd
>> like you to be working on.  I really
>> want you to concentrate on beaglebone-specific stuff.   That's the important
>> stuff.  Today I brought my beaglebone
>> board to the office, and I've got it working clean now using a local set of
>> ctype.h and ctypetbl.c files as I had in
>> umon1.19.  For now this is temporary, but it may turn out to be the most
>> efficient way to get around this.
> These files would conflict with the licenses, am I right?  Would a
> permanent solution be to implement a new local ctype.h?
Yep, that's exactly what I'm looking in to.  :-)
Just wanted to get you rolling meanwhile...
>> So, attached to this are three files:
>> ctypetbl.c:  put this under main/glib
>> ctype.h:      put this under main/common
>> mydiffs:     small list of diffs based on the tree after installing your
>> initial set of 24 patches.
>>                     most of these changes you probably have, the important
>> one is in main/make/common.make so that ctypetbl.c is built.
>> If you can incorporate these changes into a tree that starts with the master
>> and has your initial 24 patches applied,
>> you should be good to go.  I know I should be using git to email you
>> patches, but I'm still trying to figure out how to
>> do that and I don't want you to be delayed by that.
>> Does this make sense to you?
> Yes.  Ok, I'll incorporate those files and I believe you are right
> that everything should be all set.
>> Ed
>> umon-devel mailing list
>> umon-devel at rtems.org
>> http://lists.rtems.org/mailman/listinfo/umon-devel
Ed Sutter
Alcatel-Lucent Technologies -- Bell Laboratories
Phone: 908-582-2351
Email: ed.sutter at alcatel-lucent.com
More information about the umon-devel mailing list
